.:-- 5th Annual KY/TN March 2017 Land Between the Lakes Meet--:.
Discussion in 'Tennessee' started by Breezy, Jan 2, 2017.
  1. Jan 27, 2017 at 6:22 AM
    #1261
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    16ish
  2. Jan 27, 2017 at 6:23 AM
    #1262
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    that's what I am getting now with 31s and winter fuel o_O
  3. Jan 27, 2017 at 6:24 AM
    #1263
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I'm factory suspension and tire size. In my 4 banger, I smile if I hit 350 miles before the light comes on
  4. Jan 27, 2017 at 6:24 AM
    #1264
    Kerleyfries
    Zack
    Lebanon
    I'm getting 14.5-15 on winter gas.
  5. Jan 27, 2017 at 6:30 AM
    #1265
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    11.7 :anonymous:
    dirty deeds likes this.
  6. Jan 27, 2017 at 6:31 AM
    #1266
    tacabode
    tacabode Well-Known Member
    Ohio
    '14 MGM DCSB TRD OR
    i did... :anonymous:
    google maps allows you to downloads sections of map and use them with your phone on airplane mode. i've done this backpacking and hunting, and at lbl last year
    https://www.youtube.com/watch?v=r0HX4a5P8eE
    corrected? that's actually not too bad. considering i'm in the 17-18 range on winter gas, and 19-20 otherwise. and that's on my 32" b-rated road tires :anonymous:
    mwc273[QUOTED] and dirty deeds like this.
  7. Jan 27, 2017 at 6:43 AM
    #1267
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    I was getting 17-18 mpg before. Since adding the 255 75/17 Cooper Stt Max, I'm getting 13-14 mpg. Yep, I've measured it multiple times and I cannot get more than 220 miles on a tank of fuel. Luckily, I mostly work from home and only have a 5 mile commute when I do go to the office.
  8. Jan 27, 2017 at 6:45 AM
    #1268
    tacotim448
    Tim
    Nashville
    2011 Money Pit
    What's the size of the union?
  9. Jan 27, 2017 at 6:48 AM
    #1269
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
  10. Jan 27, 2017 at 6:49 AM
    #1270
    presta24
    chris
    Cincinnati
    Good to know, thanks man
  11. Jan 27, 2017 at 6:56 AM
    #1271
    Kenstaroni
    Kenstaroni Well-Known Member
    Ken
    Nashville, TN
    2018 T4R TRD Offroad
    Icon Stage 2 285 KO2's RCI Sliders Rhino Rack Pioneer CB
    You need Union Part # 90404-51319
    Cool Springs Toyota Parts sells at wholesale prices to the public, mine was $6.52 from them.
    You also need the breather for the other end of your hose, I can't recall that part number but should be easy to find a write up on the net. Other than that get 6-7' of 3/8 fuel line and a 4 pack of hose clamps, couple zip ties, and you're GTG.
    tacotim448 likes this.
  12. Jan 27, 2017 at 7:42 AM
    #1272
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    15ish. I can get 17ish if I do 67mph on the interstate...which is why I get 15ish.
    rngr likes this.
  13. Jan 27, 2017 at 7:42 AM
    #1273
    Kerleyfries
    Zack
    Lebanon
    Closer to 15.5 corrected.
  14. Jan 27, 2017 at 8:03 AM
    #1274
    presta24
    chris
    Cincinnati
    what size are your tires?
  15. Jan 27, 2017 at 8:08 AM
    #1275
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    corrected?
    how you do that?
  16. Jan 27, 2017 at 8:09 AM
    #1276
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Speedometer calibrator. I actually have one and corrected it wrong so my speedo is still off. Haha
    beertimecontinuum likes this.
  17. Jan 27, 2017 at 8:15 AM
    #1277
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    My kit is 1/4"npt brass fitting with push-lock in 1/4 id, 5' or 6' of 1/4"od tube, 1/2" npt brass fitting with 1/4" push lock, 1/2" FIP coupler, 1/2" sintered brass filter.
  18. Jan 27, 2017 at 8:21 AM
    #1278
    Dave41079
    Dave...
    Nashville, TN
    I just math when I do my mpg calculations. Truck came stock with 31s, I now have 35s. 35/31 = 1.129. When I fill up at let's say 220 miles and it's 16 gallons, then I do 220/16 = 13.75. To get my corrected mpg, 13.75x1.13 = 15.54.
    tacotim448 and beertimecontinuum like this.
  19. Jan 27, 2017 at 8:24 AM
    #1279
    presta24
    chris
    Cincinnati
    Lets do this
  20. Jan 27, 2017 at 8:26 AM
    #1280
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Wait, you bought a brand new set of nice wheels, then you're going to paint them? What color did you buy?
