.:-- 5th Annual KY/TN March 2017 Land Between the Lakes Meet--:.
Discussion in 'Tennessee' started by Breezy, Jan 2, 2017.
  1. Feb 1, 2017 at 1:07 PM
    #1681
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    And?? You like?
    BTW, those interior LEDs excite the fuck outta me every time I open my doors :D
    Now for some license plate bulbs
    MedlinAround[QUOTED] likes this.
  2. Feb 1, 2017 at 1:10 PM
    #1682
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I keep my SWR meter in the glove box of my truck. It takes all of 5 minutes to tune an antenna. It's a good practice to check them occasionally anyway. Way out in the boonies away from cell towers, light poles, overhead wires, buildings and signs is the BEST place to set it. LBL just could be the SWR Mecca!
    11TRDTX[QUOTED] and presta24 like this.
  3. Feb 1, 2017 at 1:13 PM
    #1683
    dirty deeds
    Nick
    Eastern KY
    Cell service at LBL?
    If not, that's B. E. A. Utiful!
    Bluegrass Taco likes this.
  4. Feb 1, 2017 at 1:14 PM
    #1684
    NKYTaco
    NKYTaco Well-Known Member
    Brandon
    South Eastern Indiana
    2014 MGM TRD Pinstripe Edition
    @Bluegrass Taco I may ask you to help me set mine while at LBL, if I don't get it done here soon.
    Bluegrass Taco and Mr.Bl0nde like this.
  5. Feb 1, 2017 at 1:21 PM
    #1685
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    me too!
  6. Feb 1, 2017 at 1:23 PM
    #1686
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Another dirty little secret to setting up a CB, they work best when the antenna has a proper ground plane. Best place for an antenna is on the roof, trunk lid, or hood of a vehicle. (Flat surface, 90 degrees to antenna mast) Antenna mounts should be grounded to the chassis if not on a grounded surface. Do NOT run a ground from antenna mount directly to the battery. You are NOT grounding the 12v dc current of the vehicle or radio, you are grounding RF "radio waves". Running a ground directly to the battery will often result in ignition noise from the radio. My mount is in the bed, on the front bulkhead. Not the BEST place mind you, but plenty good enough since I have a ground strap run from the steel mount down to the chassis of the truck. The plastic inner bed of a Tacoma is a lousy mounting point. It NEEDS an adequate ground strap to eliminate noise and increase modulation. When running a dedicated ground, use flat "ground strap" rather that round stranded wire for best results. Also, ideally, you want 2/3rds or more of the antenna above the roof line of the vehicle. A typical "wound" antenna (ie, "Firestik") is "top loaded" with most of the 102" of winding in the upper portion of the mast. Personally, I shoot for 75% or more above roof line. Makes for better long distance reception.
    dirty deeds likes this.
  7. Feb 1, 2017 at 1:26 PM
    #1687
    dirty deeds
    Nick
    Eastern KY
    Did you see the 3D printed thread here about bed brackets?
    One was a corner mount option, but not really flat for mounting, say, a CB antenna.
    The other IS flat, and seems you could mount an antenna on it, but still need to ground it.
  8. Feb 1, 2017 at 1:26 PM
    #1688
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Mine will be turned off, left in the console, OR, under a tire in a mud hole.
    presta24 and dirty deeds[QUOTED] like this.
  9. Feb 1, 2017 at 1:27 PM
    #1689
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Did NOT see it. I make my own but would LOVE to see better options.
    dirty deeds[QUOTED] likes this.
  10. Feb 1, 2017 at 1:28 PM
    #1690
    dirty deeds
    Nick
    Eastern KY
  11. Feb 1, 2017 at 1:34 PM
    #1691
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Good idea....They should be steel rather than plastic for the best results.....then grounded to the chassis. Those bed rails are NOT adequately grounded. (BTDT, wasn't happy with the results.) I've made a couple aluminum mounts, which work "ok" but steel with a good chassis ground works BETTER.
    Under MOST conditions, you won't notice a poorly grounded antenna. Where it shows up is in areas where there is marginal reception. For CB's used in close proximity (within a mile) you can get away with poor grounds.
    RF waves send heat back into a radio if the Standing Wave Ratio is far off or the antenna ground is not good. This can destroy the "primaries" in the radio, slowly eroding the performance.
  12. Feb 1, 2017 at 2:04 PM
    #1692
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Haven't used it in my truck. In my Rzr I've used it (Mostly the PA for yelling at people to get out of the way) but I don't think the antenna is correctly placed/grounded because I get a little static. I also don't know much about CB's
  13. Feb 1, 2017 at 2:16 PM
    #1693
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Because it's called "Loves".... :hattip:
  14. Feb 1, 2017 at 2:21 PM
    #1694
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Ya know what? I know that. Cannot tell you why I typed bLOWES,
  15. Feb 1, 2017 at 2:34 PM
    #1695
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Multiple people who will be there have swr meters and can tune a cb radio. Its not fucking rocket science.
    Red Demon and dirty deeds like this.
  16. Feb 1, 2017 at 2:35 PM
    #1696
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I wonder how many people read this whole thing ....
  17. Feb 1, 2017 at 2:35 PM
    #1697
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Nope.....It's radio science.
    dirty deeds, KRAMERICA and presta24 like this.
  18. Feb 1, 2017 at 3:18 PM
    #1698
    Breezy
    Breezy [OP] vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Shit I need(want) to buy and/or install before LBL:
    PS rack
    PS pump
    Rear axle seal
    Full size spare
    Door handle
    Rear bumpstops
    Rear shocks
    Tent
    Sleeping bag
    Winning lottery ticket
    dirty deeds and Bluegrass Taco like this.
  19. Feb 1, 2017 at 3:20 PM
    #1699
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Shocks and that ps pump should be top since your fucking shock is broken.
    dirty deeds and 11TRDTX like this.
  20. Feb 1, 2017 at 3:21 PM
    #1700
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    No reason to buy nice shocks when your bumps fell off 30,000 miles ago :anonymous:
    tacabode, 11TRDTX and Kerleyfries like this.
