5th gear on my automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tucsontoast, Sep 16, 2007.
  1. Sep 16, 2007 at 7:18 PM
    tucsontoast
    tucsontoast [OP] Active Member
    Hey, all!
    First of all, I love my YOCA, but I have two gripes and am wondering if anyone has any info for me. I have the 5 speed auto 2007 4.0 PreRun2wd 4dr with just over 6000 miles . It shifts great 1st through 4th but when it kicks into 5th (at say, normal cruising speed, not under hard acceleration) it feels clunky or sloppy, not tight. This really makes it feel kinda junky to me, like there's slop in the driveline or the rear end, but I'm thinking it's just because it's more of a cruising gear, and much higher so it's more noticeable. I don't beat my truck. Anyone else notice this?
    Second, I don't like the "shaky" feel of the suspension when I hit a small pothole or small road ruts, for instance, when I hit a certain bump in my neighborhood the truck is pulled hard to the side of the pothole, and if I was to overcorrect, it would be a problem, however, my 95 Ford 3/4 ton 2wd hits the same bump and doesn't swerve at all, and neither does my wife's 99nissan altima.The truck feels "light and out of touch" with the road in bumpier situations. Anyway, I'm thinking a suspension upgrade from the factory bilstein setup would do the trick and looking for suggestions. I'll add that I want to lift the truck about 3 inches (not including larger tires) but hoping not to spend a mint doing it. Six hundred or less? Do-able?
    Thanks in advance for any info!
  2. Sep 16, 2007 at 7:58 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Your 5th is your "over drive" gear hence it has no balls ;). If you like "tight" (we all do), shift your gear to 4th and leave it there till you are ready for something loose. But dont complain that your truck is thirsty for gas. Switch between 4th and 5th as you deem fit.
  3. Sep 16, 2007 at 11:04 PM
    tucsontoast
    Thanks for the response, but it wasn't a complaint so much as a query as to whether this is "normal" or something I should be concerned about and have addressed by my dealer. Maybe you noticed my comment that I figured it was the taller "overdrive" gear, but just wanted a general consensus. Didn't want to find out later that my truck had a "characteristic" not typical of the Tacoma.
    Like the quote.
  4. Sep 17, 2007 at 4:53 AM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
    Its normal. Nothing to worry about. Get used to switching between 4th and 5th and you'll love it. :thumbsup:
  5. Sep 17, 2007 at 5:37 PM
    tucsontoast
    Right on. I was just following the owner's manual too carefully I guess. I was actually messin' with the 3 through 5 gear range off road the other day and it was a blast! Thanks!
  6. Sep 17, 2007 at 9:15 PM
    Bluestreak
    Bluestreak Active Member
    mine is fine in 5th, matter of fact i run in d all the time, when i need power just punch it, no clunk, just get up and go. really mine works fine all the way around, i live on a bumpy curvy road and it handles great, i can go slow in drive, fast in drive, i can use my gears for performance driving (late for dinner) but really all is good and tight.
  7. Sep 18, 2007 at 9:24 PM
    tucsontoast
    I run in D all the time too, but when I'm light on the pedal and the truck is just going through the gears casually, when it gets to fifth there's a slight noticeable loose transition. It doesn't happen every time, but enough to where I'm concerned.
  8. Sep 20, 2007 at 3:47 PM
    CharlieX
    CharlieX Well-Known Member
    I get that sorta clunky switch to 5th too in light city driving. Often my 07 holds onto 4th for 10 to 15 seconds after I've locked in a cruising speed of say 45, and then decides its time to drop into 5th reluctantly. but up on the highway it's smooth as a whistle.
    but you shouldn't have any shaking problems. mine rides beautiful at all speeds (well, when you get around 80mph, it's a little bit of a wild ride compared to my girl's lexus IS250... but it's a truck, not a sports car)
  9. Nov 5, 2008 at 9:45 AM
    TCTACOSURPREME
    TCTACOSURPREME LAOTION IN 4 WHEEL MOTION
    TWIN CITIES MN
    08 RUGGED TRAIL
    VIPER 5901 ALARM W/ AUTOSTART, AFE CAI STAGE 2, LUND HOOD DEFLECTOR, BULL BAR, GARMIN GPS, IPF LIGHTS, DEBADGED, TOYTEC FRONT FULL COILOVERS, DIFF. DROP, REAR BILLIES 5125, TSB 1.5" AAL'S, OME driveshaft carrier bearing drop. (driveline vibrations are gone!!!) 33's firestone destination m/t's. spidertraxx wheel spacers in the front.
    do any of you guys have problems goin up a slight incline, like a bogging feeling around 40-50mph? thats normal too right?:confused:
  10. Nov 5, 2008 at 10:16 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I live in Louisiana so Its flat as can be, but when I went to Tx I noticed what you could call bogging when climing the hills. Seems norm just digging down to ensure enough power. Most likely getting out of 5th and into 4th
  11. Nov 5, 2008 at 1:36 PM
    TCTACOSURPREME
    TWIN CITIES MN
    08 RUGGED TRAIL
    thanks luk, just need some reassurance that i aint having tranny problems or air problems. If its normal then i don't have to worry about it. Just a pain when goin on a slight incline i gotta shift to 4 and it goes up fine. yeah i used to live up in new iberia before i moved up here. i wouldn't have any bogging in LA.
  12. Nov 5, 2008 at 1:51 PM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    I have an 09, and don't notice bad shifting from 4th to 5th. However, I do notice that at really low coasting speeds that it really kicks from 1st to 2nd. Almost like it's shifting late and trying to comensate. It usually happens when I do a "rolling stop" at a stop sign.
  13. Nov 5, 2008 at 3:22 PM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    Hey toytec offers a 3 in lift, since you have the DC I would suggest the 885 coil and rear AAL package. As for shocks the 5100 bilstein's appear to have a great rep all around
