5th Wheel Hitch Installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jflames05, Jan 20, 2012.
  1. Jan 21, 2012 at 1:44 PM
    #41
    beaker1214
    beaker1214 Well-Known Member
    St. Louis
    09 TRD SR5
    You would think....But just being around them for a long time I know those are the correct brackets...but I think on a taco I am not sure the frame is strong enough to handle them. But if you look at how a fifth wheel is mounted on a larger truck it looks just like that...but I don't remember there being two brackets on the front. I always just remember there being 4 brackets all together!
  2. Jan 21, 2012 at 8:07 PM
    #42
    cc350
    cc350 Retired Member
    This is what it should look like.
  3. Jan 21, 2012 at 8:31 PM
    #43
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    OP, I'm rooting for you but your design needs some help. You need to support that weight across a wide surface of the frame, not at 4 bolts on each side. Those bolts will have all the weight on them, which places a hell of a lot of strain on the frame in those places.
    I'd recommend boxing the frame in, running a cross brace or two across between the frame spars, and mounting the weight on top of the boxed portion of the frame. Put the cross braces equal with each mount. Gusset your leaf spring mounts and invest in some Timbrem bump stops.
  4. Jan 21, 2012 at 8:34 PM
    #44
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    This x's 100000000
  5. Jan 21, 2012 at 8:37 PM
    #45
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    with a plate like that, the only way it will help keep the bolts from "tearing" the frame or wollowing out the holes, is if it were welded on. otherwise it stiffens the frame from bending, but does not help support the weight.
  6. Jan 21, 2012 at 9:20 PM
    #46
    jflames05
    jflames05 [OP] Active Member
    James
    Greenville
    Silver 05 SR5 4x4 Lifted
    3" Toyo Tech Lift, 33x12.50 Toyo Open Country Mud Terrains on 18x9 Gear Double Pump, AFE Cold Air Intake System, Flow Master 40 Series Dual Exhast, Knaack Toolbox, Custom Tint/Graphics, Custom 5th Wheel Rails/Gooseneck Hitch, Rear View Camera, JBL Speaker System
    Alright, improvements have been noted.
    Rails will be blocked underneath, giving extra support.
    Frame will be boxed as well, strengthening it and helping it hold the weight.
    To keep it from Tearing (already added a 3/8 Plate on the back side of the frame), but i will also have the brackets welded on each side, extending support to the whole bracket instead of just the bolt holes.
    Its hard to see in the pictures but underneath the Rail there is a 1/2in Steel Plate (42inx6in). These go from one side of the frame to the other in place of the bed that was cut out. It also adds support for the 12 carriage bolts that will be holding the rails down. If you look where the bed is cut on each slot there are frame supports running from one side of the frame to the other, ironically just where they needed to be.
    Last but not least, there will be blocks put on the frame above the shocks, welded to the frame and the adjacent bracket.
    I appreciate all the suggestions, this is how the reese rails install instructions were (except with 4 angle brackets and not as many blocks). I've seen both the frame plates, like cc350 posted, and these angle brackets.
    I'll be workin a lot the first couple days of this week, so it'll be thursday/friday before I can get this stuff done.
    Thanks.
  7. Jan 21, 2012 at 9:25 PM
    #47
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Right on. The blocks and boxing the frame will be good additions.
  8. Jan 22, 2012 at 4:30 PM
    #48
    beaker1214
    St. Louis
    09 TRD SR5
    Post pics once you hook up your 5er! I really want to see this! I can't imagine pulling a 5er with a tacoma but anything is possible! This is my first smaller truck (came from a 2500 Duramax) and I have been used to pulling all kinds of loads up to 20k. Now I just pull my rhino around and that is probably less then 2k behind the truck and I know its there....but then again I have always pulled stuff with the duramax and never felt it behind me. But good luck man, I think the plate idea is a great idea to help strengthen the frame. I have always installed and pulled with hitches that use the angle brackets and I know in your case they are not the weak point based off the loads I have pulled with them. It sounds like you have things figured out and there has been allot of good input on here....I am rooting for you but if I was going any where far with it I would upgrade / downgrade (however you look at it) to a larger truck.
  9. Jan 22, 2012 at 6:04 PM
    #49
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I'd go with the air bags. They will really help with the stability.
  10. Jan 23, 2012 at 10:07 AM
    #50
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Not saying it is or isn't strong enough but... OP says the maximum tongue weight would be 600 lbs and that's way lower than the 1/2 ton or so rated capacity.
    This weight... and the 6500lb towed weight... will be carried on the same frame that an OEM hitch is attached to. But a 5th wheel would handle it with a lot more stability?
  11. Jan 23, 2012 at 5:00 PM
    #51
    beaker1214
    St. Louis
    09 TRD SR5
    You have a good point there with the tongue weight and I didn't realize it was just 600 lbs of tongue weight. I would rather have this weight on a fifth wheel vs a bumper pull.
    The truck will handle the weight better on a fifth wheel since the weight will be distributed on truck more evenly.The more I think about this the more I think its possible...would I do it?...probably not but its a pretty cool idea and it seems like it could be done. The trailer will be pushing all the towing specs to the max but just for close camping trips it might work!
    Sorry if I came off negative about the idea of this, but I honestly can't imagine pulling a fifth wheel with my tacoma but hey anything is possible!
  12. Jan 24, 2012 at 9:56 AM
    #52
    buddywh1
    Philly PA
    07 DC SR5 4x4
    When I think of 5th wheels I also envision a truck with duallies hauling a 20,000lb horse trailer. Not a scenario I imagine a taco in at all. But OP has said his trailer is around 6500lb with 600lb tongue weight. Keep it to that and I'm having trouble sharing in all the bad mojo goin' on.
    One thing I do note.. the way this is mounted to the frame ALL the tow loads of the trailer (both static and dynamic) are handled by the mounting bolts in shear. I'm sure the hitch mfr. considered this in design, but their assumption is you'll use the holes as drilled and prepped them.
    It's very important to make sure the holes OP puts in the brackets and frame are correctly sized, clean drilled and de-burred and in alignment with those in the frame. This is prolly the number 1 source of in-service failure for fastening systems with loads in shear: poor hole prep. Even using grade 8 won't help if the holes are poorly prepped.
    Just somethin' to think about....
  13. Jan 27, 2012 at 9:21 PM
    #53
    jflames05
    James
    Greenville
    Holes drilled in the frame were properly prepped. A burr can reek havoc on a bolt, and cut into it making it weak and fail.
    Got the blocks cut and fitted today. Going to get the boxing Brackets done this Sunday along with prepping the frame to be welded. Uploaded some pictures. There will be 8 blocks all together.
    2x2 Steel Tube i Used 24" Long Cut with PortaBand
    Block Fitted on Frame
    Half done.
  14. Jan 27, 2012 at 10:16 PM
    #54
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    While you're at it, go head and box the frame!
  15. Jan 31, 2012 at 7:46 PM
    #55
    jflames05
    James
    Greenville
    Got brackets and frame welded today. Pulled the camper around a bit tonight, worked great. Gonna move it about 20 miles tomorrow. I'll post some pictures of the hitch and camper hooked up.
  16. Jan 31, 2012 at 9:09 PM
    #56
    Talbotman
    Talbotman Well-Known Member
    Joel
    Ripon, California
    2002 "Toy Taco"
    3" custom lift kit, 285/75/r16 toyo open country AT's, Billy 5100's in front and 5150's in back, Weld 16x10 rims, Flowmaster 2 chamber, 6000k bi-xenon hid kit, grey wire mod, and smoked tail lights
    love the additions much safer!!! awesome job op, but i do think bags would be an awesome addition for the towing stability man
  17. Feb 2, 2012 at 5:43 AM
    #57
    jflames05
    James
    Greenville
    The rear sags just a little bit. I still have about 4" of clearance before it hits the stops when it's sitting still. But Airbags are definitely in my future =)
    And here's the bed pieces cut out. The bed itself wasn't that thick, but it had about a 2in support underneath. Seemed to be made out of a fiberglass type of material.
    If you look closely, you can see the sawzall blades that I cut short to make sure i didn't cut any lines. Jammed a couple times and broke a few (oops) but didn't cut any lines!
    Overall the truck did great pulling. I pulled along going around 60, and even up hills it seemed to do well without slowing down. RPM's were around 2300-2400 in 4 most of the time at that speed. Only thing I might add is a bigger cooler if I decide to pull it more and some air bags.
  18. Feb 2, 2012 at 8:21 AM
    #58
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Proved a lot of people wrong. Looks great man and glad you're safe
  19. Feb 15, 2012 at 12:41 AM
    #59
    lmcc007
    lmcc007 Well-Known Member
    Charles
    Northern CA.
    2006 SR5 PreRunner Doublecab Longbed
    Tube steps & tonneau cover.
    I'm adding my 2 cents in a little bit late, but here goes...6500 lbs is a lot to ask of a 4.0L V6 engine. Yes, the truck will do the job, but you have to think of the long term affects it will have on your engine and transmission. I've spoken with a few people that say that they wouldn't tow a trailer over 3500 lbs with the 4.0L V6 Tacoma for that very reason. It would be nice if our Taco's were designed to tow larger trailers or carry bigger cabover campers, but unfortunately they're not made that way. If you carry 600lbs or more in your bed on a regular basis then you really do need airbags or the back sags very noticeably. Overall vehicle and trailer weight could become an issue at some point too. As another poster mentioned, insurance may be a problem if you're ever in an accident because your pushing the very limits of the truck. I have been looking on and off for a lite camping trailer for a little while now. I would prefer a hard sided camper, but I may end up just getting a tent trailer (preferably with an inside toilet and shower). Good luck in the future with your trailer and keep safe.
  20. Feb 15, 2012 at 9:34 AM
    #60
    xxaarraa
    xxaarraa Well-Known Member
    It's already been done so what's the point in telling the OP about the alleged ill effects?
    OP, I like your courage. Do it I say, if you are this committed and skilled at custom fab work, any alleged engine/tranny work shouldn't faze you.
