5th wheel hitch on Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by joesmith123, Nov 29, 2023.
  1. Nov 30, 2023 at 7:47 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    CURT 16100 Industry-Standard 5th Wheel Hitch Rails and Brackets, Gloss Black, 25,000 Pounds, GLOSS BLACK POWDER COAT https://a.co/d/hEGnlC9
    You need to get this^ .
    You will most likely have to shorten the rails. The L brackets mount to the side of the frame.
    I won't lie, installing a 5 the wheel hitch kinda sucks. I've done 4 and I got to do 2 more soon.
    joesmith123[OP] likes this.
  2. Nov 30, 2023 at 7:52 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    If serious about using this to pull a 5'er, I'd take the bed off and have someone fab up a mount to the frame rails. Save you the weight of the truck bed, too. As someone who has scaled my 2nd gen Tacoma with 3500 pounds of combined payload, I've always been curious how my truck would handle a 5th wheel if I stripped all my extraneous heavy stuff....
  3. Nov 30, 2023 at 9:24 AM
    Old metals
    Old metals Well-Known Member
    02 x-cab 4x4 2.7 2018 TRD Sport 4x4 3.5
    Original
    @YF_Ryan hit the nail on the head. "If serious about using this to pull a 5'er, I'd take the bed off and have someone fab up a mount to the frame rails."
    joesmith123[OP], YF_Ryan and koditten like this.
  4. Nov 30, 2023 at 9:29 AM
    koditten
    Kirk
    Central Michigan
    Well, that's what the kits I posted do.
    No 5th wheel hitch is mounted to the bed. They are all mounted to the frame.
  5. Nov 30, 2023 at 2:52 PM
    joesmith123
    joesmith123 [OP] Well-Known Member
    n/a
  6. Nov 30, 2023 at 2:55 PM
    YF_Ryan
    Kent, WA
    he's just assuming you are killing the clutch.
  7. Nov 30, 2023 at 2:55 PM
    joesmith123
    Right? Thats what I figured
  8. Nov 30, 2023 at 2:56 PM
    joesmith123
    Yes I understand, I would never put weight on it and run it in high gear
  9. Nov 30, 2023 at 2:59 PM
    joesmith123
    measurements etc
    koditten[QUOTED] likes this.
  10. Nov 30, 2023 at 3:00 PM
    YF_Ryan
    Kent, WA
    After my FIL bought his F2/350 with the godzilla motor and his little 5th wheel TT he made some joke about my little truck... My wife stopped me from explaining I regularly haul around a lot more than his pin weight... in my little truck...
    koditten and joesmith123[OP] like this.
  11. Nov 30, 2023 at 3:01 PM
    joesmith123
    Yes but that sounds expensive, I'll probably just drill holes in the bed, and the brackets go down and mount the frame, then the 5th I have would somehow fit on the rails
  12. Nov 30, 2023 at 3:03 PM
    joesmith123
    Yes, in low gear, it has tremendous capability
    Also that truck I am using had a NEW FRAME installed in 2018, so it should be a good strong frame
    koditten likes this.
  13. Nov 30, 2023 at 3:28 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Is this long term?
    Really seems like something different would be better.
    The Tacoma with newish frame pending condition should have some value.
    Pretty amazing what these little trucks can do.
    Good luck!
  14. Nov 30, 2023 at 3:36 PM
    koditten
    Kirk
    Central Michigan
    It does. Those plates are universal. Your saw horse will drop right into those plates. (Attach saw horse to the plates 1st, position the saw horse / plate assembly where you want it in the bed and mark the holes you need to drill in the bed. You will need spacer washers because the bed has ridges. After that attach the L brackets and drill the holes in the frame.
    If you are using this only around the farm, I'd have no issue moving the assembly back in the bed 6-8".
    If anyone gives you grief, have them look at the stamped sheet metal that is used to mount the receiver hitch. A 5th wheel hitch is miles better than what we got from the factory.
  15. Nov 30, 2023 at 6:58 PM
    #35
    joesmith123
    You're the man, I will do exactly what you are instructing
  16. Nov 30, 2023 at 7:01 PM
    #36
    koditten
    Kirk
    Central Michigan
    There are lots of You Tube vids on installing a 5th wheel hitch, but non are for our compact trucks. The concept is the same, but you will just need to narrow those before plates.
  17. Nov 30, 2023 at 7:05 PM
    #37
    joesmith123
    totally understand
  18. Nov 30, 2023 at 8:12 PM
    #38
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I would go on facebook market place and grab a an early 2000's chevy 1500/2500 under 200K
    A beat up white body one should be around 1K.......
    I have a buddy that scored a 2003 farm chevy1500 with 175K on it....for $750.....
    all he had to buy was chevy starter(cheap)....
    there was a ball mounted in the center of the bed....it was used to move hay around...
    that was 3 1/2 yrs and 20K ago........
    my head cost more than that...........................
    That way you dont have to butcher yours.......everybody here ...is cringing....
    including your leaf pack....
  19. Dec 1, 2023 at 10:21 AM
    #39
    joesmith123
    duties/tasks
  20. Dec 1, 2023 at 11:18 AM
    #40
    O'Silver_Taco
    MD
    Or craigs list....thats where I bought a tacoma with a blown engine...
    cheap.....
