5th wheel towing
Discussion in 'Towing' started by jpaulstra, Sep 21, 2014.
  1. Sep 21, 2014 at 3:04 PM
    jpaulstra
    jpaulstra [OP] New Member
    Jim
    Factory tow kit
    Can I safely tow this 18ft. 5th wheel w/ my 2014 Double cab V6 AT w/ factory tow package? I realize a sliding hitch would be necessary for sharp turning.
  2. Sep 22, 2014 at 9:05 AM
    KMitch
    KMitch Well-Known Member
    Colorado
    14 DCSB TRD Off Road
    What's the pin weight?
  3. Oct 1, 2014 at 4:05 AM
    KVJ
    KVJ Active Member
    Kenny
    Bristolville,Ohio
    2015 TRD sport
    Raptor style grill
    This one is 19', over 3000# with 500# tongue weight.
  4. Oct 1, 2014 at 4:34 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Those scampers used their own special hitch. Not common at all.
    The 5'er you showed a pic of has a conventional fith wheel hitch. I would be suprised if you could find bed brackets that would fit between the fenders. It would most likely be a specialized hitch. Big dollars.
    As for the slidding hitch, I doubt there would be enough bed lenth to work with if you have a double cab. You would have to have the hitch slid all the way back, thus you would be hanging all the weight to the rear past the axle. Not good for our frames at all.
    I know you would have to put over load air bags on the rear suspesion to carry the extra weight.
    I don't think it would be wise to use a tacoma to pull a small fivth wheel camper.
    You would need tow mirrors that would have to stick waaaaay out.
    I'm thinking you would be way ahead if you just picked up a decent bumper pull camper.
    I deal in trailers and have no issues overloading tow vehicles, but I could never recomment tugging that camper with 1/4 ton truck. The extra money you would have to put into towing it safely, would be better spent on a used bumper pull camper camper.
    I own a 5th wheel camper and I will freely admit that towing a 5th wheel camper is far supperior to a bumper pull, but this might be the exception to the rule.
    I hope you find my opinion usefull
    Later
    KO
  5. Oct 3, 2014 at 4:47 AM
    KVJ
    KVJ Active Member
    Kenny
    Bristolville,Ohio
    2015 TRD sport
    Raptor style grill
    koditten is right! I sold my 5er shown in my previous post and bought a pull behind. It is narrow enough to not need mirror extensions.
  6. Nov 20, 2014 at 9:12 PM
    Indy
    Indy Master of all I survey.
    Im picking up a lightweight 5th, 19x7 and about 2400lbs dry.
    The temptation is strong :laugh:
