5vz cracked head. reman heads or junk yard engine?
Discussion in '1st Gen. Tacomas (1995-2004)' started by KeaganKing, Apr 30, 2025.
  1. May 2, 2025 at 11:37 AM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    You could also win the lottery, catch a 15lb bass and make a hole in one on a par 4.
  2. May 5, 2025 at 10:28 AM
    KeaganKing
    KeaganKing [OP] KeaganKing
    Keagan
    Boise, Idaho
    95.5 3.4 5spd
    After another weekend sitting in denial I did brainstorm one last idea and found a potential cause of issue I could be having. I had some AI analyze every single little symptom I could come up.
    The 5VZ‑FE intake has a built‑in coolant passage (through the throttle body or a bypass tube) and thick lower manifold gaskets. If the rubber seals around the coolant ports fail, coolant can leak into the intake plenum or runners. Unlike a head crack, this tends to happen mostly when the engine is cold/cooling (as metal contracts around the failed gasket). Coolant pools in the intake or throttle body bore and is drawn into one cylinder on the next start, producing a brief white puff. Because the coolant is burned immediately, there may be no external leak and no measurable coolant loss.
    I scavenged some more and came across this video here https://www.youtube.com/watch?v=ILPP5c35Uqg
    I personally have seen forums on here of people having issues with the intake manifold gaskets leaking externally down the rear of the engine off onto the bell housing. I don't have major coolant loss, so its different there, however I feel like the two (cracked head, manifold gaskets or some other intake coolant related leak) is pretty indistinguishable without tearing into the motor.
    I know my motor has miles racked up, and that its probably a cracked cylinder head after all. With all this extra class time I have being near the end of the school year, I have nothing else to do but sit and try and find reasons for what's happening with my truck.
    Im finally sticking a borescope down in my cylinders today in shop class, so wish me luck!
  3. May 5, 2025 at 11:25 AM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    Yeah, that bubbling is the intake manifold gasket leaking and pushing the coolant up. I think it's exhaust gasses pushing it up? It's a doable job, wayyyy better than removing heads.
    The massive coolant leak down the back can be when the bypass pipe sealant fails which is a whole separate thing you can also access when taking off the intake manifold. It doesn't touch any air passages, so it's just dripping down.
    A cheap salvage engine was probably a good gamble many years ago. But every year that goes by, knowing this is a common issue... I don't know, it sounds like the heads are in some phase of cracking on all of them.
  4. May 5, 2025 at 12:19 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    OP, have you run a compression test or leak down test yet? Those would also be fairly easy (and fairly reliable) ways to rule out cracked head/head gasket issues and therefore rule in your new intake manifold hypothesis.
  5. May 5, 2025 at 12:31 PM
    KeaganKing
    Keagan
    Boise, Idaho
    95.5 3.4 5spd
    Compression test came out good and compression was fine
    Red_03Taco[QUOTED] likes this.
