5vz-fe 1999 Tacoma supercharger running rough
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mcmotorsport52, Aug 3, 2022.
  1. Aug 3, 2022 at 8:59 AM
    Mcmotorsport52
    Mcmotorsport52 [OP] New Member
    1999 Tacoma 3.4 supercharger
    1st gen Supercharger
    Hello,
    I recent installed a 1st gen trd supercharger on my 1999 Tacoma 3.4L. After install and a little messing around I got it to run however it doesn’t seem to idle smoothly. It idles around 500rpm which makes it almost sound like it’s going to cut out. Does anyone have any information about this?
    I double checked my spark plug writings and everything is good there. I follow gadgets vacuum line diagram does anyone have any pictures they could send me of how they have the vacuum lines ran? If so please attach them below.
  2. Aug 3, 2022 at 9:14 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Any fuel management add-ons or piggy-back ecu like a URD 7th or a megasquirt or fic6?
    Is it a 1st gen (grey) or a 2nd gen (black) supercharger?
    Speedytech7 likes this.
