5vz-fe crank no start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chrischris16, May 7, 2020.
  1. May 7, 2020 at 11:51 PM
    Chrischris16
    Chrischris16 [OP] Member
    1997 toyota tacoma
    I'm not one to seek help, I've taken it to several mechanics and them and myself cannot figure it out.
    I have a 97, with new: fuel pump, fuel filter, spark plugs, ecu, spark cables (coil packs are on the way), crank sensor, new fuses, new relays(EFI, Open circuit relay), battery,
    It will crank, but no start, was running fine, wouldn't turn back on, no codes, I tried disconnecting the Cam shift sensor to see if that would make a difference. Still nothing
  2. May 8, 2020 at 12:35 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Welcome to the forum.
    To better help, it's best to find out when you had the no start issue.
    You threw a bunch of parts at it, but fail to explain if these parts were replaced before or after your problem occurred.
  3. May 8, 2020 at 12:43 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It's not getting spark or fuel, or air - did anyone spray starting fluid in there to get it to run momentarily?
    Chrischris16[OP] likes this.
  4. May 8, 2020 at 9:13 AM
    Chrischris16
    1997 toyota tacoma
    So, the truck ran, when it turned on it would stay on. But if you turned it off it would struggle to get going again. But not relating to the a starter as the issue. Starter fluid would get it going every now and again. So I checked the spark, When I get spark, I get fuel and air. But when I dont see spark, the fuel pump also doesn't turn on. It seems like something is telling it to protect itself from running. But, it will crank no matter what
  5. May 8, 2020 at 10:20 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    This sounds like a tougher one.
    Do you know if the shops used Toyota OEM parts on these components you've had them replace?
  6. May 8, 2020 at 10:47 AM
    Chrischris16
    1997 toyota tacoma
    Yes, its getting expensive with no luck.
  7. May 8, 2020 at 11:06 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    So when you do get spark & fuel does it start?
    Correct me if I'm wrong but the 5vz-fe needs to see engine rpm for fuel pump to kick on. I would say since you already replaced all those stuff already then replace the camshaft speed sensor also. I had a similar issue before, no start, no codes replaced crank and camshaft speed sensor and fired right up.
    ToyotaDriver and 98tacoma27 like this.
  8. May 8, 2020 at 11:14 AM
    Chrischris16
    1997 toyota tacoma
    Yes! When it works it works great! I think the camshaft sensor might be my problem. Its my last hope at this point
    cruiserguy and 98tacoma27 like this.
  9. May 8, 2020 at 12:05 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    You are correct. The computer needs to get the signal that the coils are firing for the injectors to pulse. The computer sends out a signal when to fire the spark plugs and it receives a signal back verifying that it fired. The tricky part now is figuring out what is preventing it from sparking. It could be cam/crank sensor or any part of the ignition system. This all assumes that you are sure it is not sparking the times when it won't start.
    cruiserguy likes this.
  10. May 8, 2020 at 4:11 PM
    Glamisman
    Glamisman Well-Known Member
    Chris you are going to have to tell us what motor you have... from your description it sounds like a 2.7 - 4 cylinder.
  11. May 8, 2020 at 4:25 PM
    cruiserguy
    Elijah
    SEKS
    Only thing telling us is the title. 5VZ :D
    Rusty Taco 11, 98tacoma27 and Bridge4 like this.
  12. May 8, 2020 at 7:34 PM
    Glamisman
    duh... thought I read it some where, anyway... does the CEL illuminate when you turn the key to ON then go out?
  13. May 13, 2020 at 9:44 PM
    Chrischris16
    1997 toyota tacoma
    Okay! I'm back, I changed the cam position sensor, no luck, my coil packs are coming in tomorrow. Maybe that'll work.
    Its the 5vz-fe motor, V6, with a 5 speed manual tyranny, 4x4
  14. May 13, 2020 at 9:46 PM
    Chrischris16
    1997 toyota tacoma
    The check engine light does not illuminate
  15. May 14, 2020 at 1:23 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Sounds like a Ecm issue could be as simple as a poor ground or damaged wires .
    Has the bulb for the check engine light ever come on.
    Surprising none of the shops picked up on this. What happens when a code reader or scanner is plugged in?
    Now all those other parts added to the mix make finding the root cause more difficult.
  16. May 14, 2020 at 5:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    Try staring it in neutral by using the clutch cancel switch (don't push the clutch in).
    Wulf and cruiserguy like this.
  17. May 14, 2020 at 8:19 AM
    Chrischris16
    1997 toyota tacoma
    I've tried starting it with the clutch and the cancel start switch, the light bulb does work but does not come on with any problems, my OBD 1 connector was scanner by the mechanic shop, they stated it was missing the pin for the fuel pump which is bizzare. The obd2 port does not show any problems. Im trying to get a good scanner to see if the cam and crank rhythms looks good
  18. May 14, 2020 at 12:25 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    Toyota removed the Fp pin for the fuel pump in models in the 90's even though the label still says Fp. I'm not sure it is "bizarre". Toyota has some sort of diagnostic tool that can be used to turn the fuel pump on through the OBD2 port.
  19. May 14, 2020 at 1:08 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    does it sound like it's trying to start at all? like a miss?
    is there any way to tell if there is signal coming from the sensor or by-pass and activate fuel pump manually?
    just tossing my thoughts out there
  20. May 14, 2020 at 1:23 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    You can pull the starter relay then turn the key to START. This will stop the engine from cranking but should turn the fuel pump on.
