5vz-fe crank no start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chrischris16, May 7, 2020.
  1. Feb 9, 2021 at 6:06 AM
    #41
    Glamisman
    Glamisman Well-Known Member
    you can jump the Black/yellow and the white/red wire and power the PCM directly... then see if the CEL illuminates and or she starts.
  2. Feb 17, 2021 at 9:02 PM
    #42
    Jussa_sas_tacoma
    Jussa_sas_tacoma Member
    Greg
    1998 tacoma 3.4 5 speed SAS
    Dana 44 front, toyota rear, 37s. Chevy 63s and alot more.
    Well I figured I would give you an update. Tried jumping wires, still nothing. I sent in my ecu to a place called G7 Computers. They have an awesome deal where for 225 bucks they will test it, if its good they will give you a refund, if it is bad they will fix it in 1 business day and get it in the mail back to you Guaranteed. I just received an email saying the computer did have an issue and they resolved it, however they did say to check other things to make sure it wasn't a short somewhere in the system causing this. Long story short that is where I am at! I should get it back on Friday? Hopefully and will update!
    DrZ likes this.
  3. Feb 18, 2021 at 1:50 PM
    #43
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    Interested to see if the ecu repair fixes it. If you are not getting any power to the fuel pump could it the ASD relay. Not sure if these trucks even have them. It is a relay that shuts power to the fuel pump in the event of a roll over (asd - automatic shut down)
  4. Feb 18, 2021 at 2:23 PM
    #44
    Glamisman
    no, no ASD but there is a "circuit opening relay" for the fuel pump. The PCM needs a signal from the CKP (crankshaft position sensor) or the Starter to close this relay to power the fuel pump.
  5. Feb 18, 2021 at 2:40 PM
    #45
    Jussa_sas_tacoma
    Greg
    Gotcha, I am excited to see as well. Fingers crossed it does. I did replace the crank shaft sensor, still no go. I am kind of at a loss of words if this doesn't fix it. I guess at that point I will have to take it to a shop. Hopefully it does not get to that point though.
  6. Mar 18, 2021 at 8:52 PM
    #46
    DB28730
    DB28730 Member
    This thread is the closest I've found to what I have going on so maybe I'm hoping I can build on this and solve my issue.
    My friend brought me her 1997 T100, 5VZFE, ran fine when parked a couple months ago, then would only run on starting fluid.
    No evidence of rodent damage to any of the wiring.
    They had Replaced Control Switch Relay on passenger side near ECM, replaced Fuel Pump and Filter, no change.
    Unfortunately I don't have the sst 09268-45014 adapter to test pressure at the FPR but after reading through this, I am not sure that is my problem, after all.
    I have noticed now that the CEL does not illuminate, at all, and that a scan tool at OBD2 port has no communication.
    I find it strange that it will try to start on starting fluid (and immediately stall) with no communication to ECM, ?
    Doing research now into ECM communication but wondered if there is a common fault, here?
    Thanks so much for any input.
    Lots of fantastic information, here.
  7. Mar 18, 2021 at 9:37 PM
    #47
    DB28730
    DB28730 Member
    I've tested at the TPS port and did not get 5v, but rather around 3v.
    I checked all grounds on the engine and they all look great.
    Battery is solid.
    Checked ECM fuse in footwell at it is good.
  8. Mar 18, 2021 at 10:46 PM
    #48
    DB28730
    DB28730 Member
    Checked OBD port and I am getting 5.3ohm at #4 "Chassis Ground"
    0 ohms at #5
    13.79 V @ #16 (Charging)
    If I am not mistaken, #4 is the ground from the battery negative to the chassis?
  9. Mar 18, 2021 at 11:00 PM
    #49
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I once somehow crossed wires on a crank sensor 5VZ-FE long ago. Would crank forever and no start. Switched the wires around. Fired right up. Just an idea, could be something with the crank sensor.
  10. Mar 18, 2021 at 11:04 PM
    #50
    DB28730
    DB28730 Member
    Wouldn't that cause it to not try and start at all?
    It will TRY, and fire up for a moment with starting fluid, but dies right out.
    Not getting communication with the ECM I think is the high resistance on #4 at OBD2 port.
    I'm going to try and replace the wires on the battery ground, and might was well upgrade the others while I am at it.
    "Big 3" I think they're called? ;)
  11. Mar 18, 2021 at 11:43 PM
    #51
    DB28730
    DB28730 Member
    I replaced the smaller ground at the negative with a much more robust one, and cleaned everything up.
    Still have high resistance at #4 on OBD2 port, no change really.
    I guess I will try replacing the other grounds tomorrow.
    I don't see the third one off hand, by the airbox?
    I do see the one from firewall to engine, seems good, but I will try to replace it anyway
  12. Oct 24, 2022 at 12:23 AM
    #52
    808hawaiitacoma
    808hawaiitacoma New Member
    2000 Tacoma 4x4 M/T
    Supercharger
    Was this problem ever solved?
  13. Mar 19, 2023 at 11:30 AM
    #53
    Bonzen
    Bonzen Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Old thread, but if for some reason this is still an issue, I have seen a 3.4 crank and not start because the crank sprocket ring that the CPS gets signal off of is loose or has broken teeth. This ring is right behind the plastic cover, slid over the crankshaft snout, behind the crank pulley. If the crank pulley is loose, it will allow the crank sprocket ring to move out of alignment and the CPS will never pick up a signal from it. Put a breaker bar on that 19mm crank pulley bolt and see if its loose.
  14. Mar 19, 2023 at 4:27 PM
    #54
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    I had that same problem today, with a truck that was sitting for a long time. I installed engine yesterday crank no start. My buddy had a really good scan tool helped rule out sensors. So runs great on starting fluid putting a fuel pump in tommorrow. I understand your frustration. Good luck
  15. Mar 19, 2023 at 4:28 PM
    #55
    Moonrman
    Hill Country, TX
    Oops old thread I feel dump
  16. Mar 26, 2023 at 10:47 PM
    #56
    MBC7777
    MBC7777 Well-Known Member
    Concord NC
    2006 Double Cab Tundra 4wd
    Make sure your timing belt didn’t break
  17. Jul 13, 2024 at 7:19 PM
    #57
    Ironworker84
    Ironworker84 Well-Known Member
    Eric
    2001 White Tacoma 4X4
    I am having the same exact problem. No communication to ECU. No spark or fuel, CEL light stays illuminated. I'm tearing my hair out here
  18. Jul 13, 2024 at 8:43 PM
    #58
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @TnShooter @Speedytech7
  19. Jul 13, 2024 at 8:45 PM
    #59
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    no com to ecu is an interesting one, is the OBD fuse good?
    TnShooter likes this.
  20. Jul 13, 2024 at 9:13 PM
    #60
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree. I'd check this first too.
