5VZ-FE Engine Swap: 2001 to 1998 Tacoma ECU Wiring
Discussion in '1st Gen. Tacomas (1995-2004)' started by Craiyg, Sep 25, 2024.
  1. Sep 25, 2024 at 4:45 PM
    Craiyg
    Craiyg [OP] New Member
    1997 Tacoma 3.4L
    Hey TW,
    I’m in the process of connecting a 5VZ-FE engine from a 1997 Tacoma into a 2001 Tacoma. Both trucks originally had the 5VZ-FE, and both are manual, but I’ve run into some issues with the ECU wiring since the two models use different harnesses. I have the full wiring harnesses for both the 2001 and 1998 engines, as well as both ECUs and dash wiring.
    Has anyone done this swap or have advice on the best way to connect the electronics? Should I use the newer (2001) ECU and wiring harness, or is there a better way to make this work with the older (1998) system?
    I was thinking of rewiring the old connectors into the new ones using both wiring diagrams but was wondering if someone had a better way.
    Any help or guidance would be greatly appreciated!
    Thanks in advance!
  2. Sep 25, 2024 at 6:25 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Edit: sorry, I read that backwards. Keep the wiring and ECU for the chassis you are swapping to. You may need to swap throttle bodies if you have drive by wire
    Craiyg[OP] likes this.
  3. Sep 25, 2024 at 7:42 PM
    Craiyg
    1997 Tacoma 3.4L
    Thanks for the reply,
    Your saying I should rewire the 1997 engine harness to plug into the 2001 Ecu. Just making sure I read that right.
    Btw both are drive by wire.
  4. Sep 25, 2024 at 8:31 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Unknown if helps
    But WTH
    Subarus…..big thing was to put STI engine into a different model
    NP mechanically, but (in my case) a 98 harness would have to be merged with the 05 harness
    In 07 when I had swap done, only 3 shops in US had experience with this
    (Had to be merged manually)
    company called IWIRE started for this exact same thing
    Now you can buy a plug and play harness from both vehicles to get swap done
    unknown if they do Toyotas
    But they sell huge array of loose/single pigtails
    Super cool on phone….much like LCE/Motorwest was when I called them for taco stuff
    Worth a shot
    GL
  5. Sep 25, 2024 at 8:38 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I went through this and put a 2002 engine into my 96.
    used the original ECU and engine harness from my 96 and the upper intake/throttle body as well. didn't have to adapt any wires.
    pull the upper/lower intake off of both engines, remove both engine harnesses, and bolt everything from your 98 on. (edit: reversed but same idea)
  6. Sep 26, 2024 at 10:28 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    1997 should not be drive by wire, it should be cable.
    The 97 engine should drop in to the 01 platform with minimal reconfiguration, the only difference might be the throttle body wiring. So use the harness that's already in there.
