5vz-fe potential
Discussion in 'Performance and Tuning' started by autowagon, Aug 2, 2010.
  1. Aug 2, 2010 at 4:59 PM
    autowagon
    autowagon [OP] New Member
    Portland, OR
    96 5vz-fe auto TRD supercharger
    TRD supercharger, URD piggyback FMU and injectors kit, some under armor and winch mount bumper.
    sick of looking at all these threads full of cosmetic bs.
    --The 5vz-fe is a short stroke engine that if it were not in our little trucks one would think was designed for a sports car or racing purposes. The engine minus the heads is made to rev to the moon. The stroke and bore imply 8 to 9k rev limit. It also has an aggressive rod ratio (which smokey Yunik liked so much on his racing chevy 350 builds, and more recently has been theorized from a completely different perspective (sport compact car magazine, i think read it in) as a deterrent to piston wobble on high revving engines. These engines are stout and known to hold together great with power adders. Obviously the heads and cams are huge limitations, as are the cast pistons. The greatest limitations imposed on this engine are simply that of the general imagination. The engine won't fit in much. And the production run mating it to crappy heads and 4by4 drivetrain has also deterred the hearts and minds of hot rodders. (although 1k hp in an MR2 is insane 400 na hp would be slightly more sane)
    -------The questions i want to know are:
    has anyone broke 1000 hp with the 5vz-fe?
    what is the top NA hp range achieved?
    I recall in the old days they used to talk about the main journal bearings diameter as it relates to the rev ability of the engine in old 60's mustangs and stuff, is that pertinent here?
    What is this measurement on the 5 vz-fe what does it imply and would it be easily changed via machining?
    What other limitations do the head designs present if a guy were to make some high duration cams, and try and port the heads as much as possible?
    What after market pistons are available for this engine now that sea2sky tuning has apparently disappeared off of the internet?
    Does anyone know of inherent limitations as far as oiling and coolant flow in the block or heads that may prevent a 1000k hp build?
  2. Aug 2, 2010 at 5:06 PM
    747 function > form
    1st Gen.
    Reply:
    1. Has anyone broke 1000 hp with the 5vz-fe? Yes; check my profile.
    2. What is the top NA hp range achieved? 1,000,000.
    3. I recall in the old days they used to talk about the main journal bearings diameter as it relates to the rev ability of the engine in old 60's mustangs and stuff, is that pertinent here? Absolutely.
    4. What is this measurement on the 5 vz-fe what does it imply and would it be easily changed via machining? 3.497; implications; again, absolutely.
    5. What other limitations do the head designs present if a guy were to make some high duration cams, and try and port the heads as much as possible? There are no limits, with my keen sense of engineering.
    6. What after market pistons are available for this engine now that sea2sky tuning has apparently disappeared off of the internet? try cradle2grave
    7. Does anyone know of inherent limitations as far as oiling and coolant flow in the block or heads that may prevent a 1000k hp build? It didn't stop me.
    Hope my replies were informative. Welcome! :wave:
  3. Aug 2, 2010 at 7:04 PM
    autowagon
    Portland, OR
    so seriously, is there anyone who can shed some light on my inquiries? With an answer better than, yup, uh-huh, yup, i agree, yup, uh-huh, uh-huh, wouldn't you like to know.
  4. Aug 2, 2010 at 7:06 PM
    Quills
    Quills Well-Known Member
    Rodney Dinkens
    Marcy Projects, Bed-Stuy, BK son...
    de-vin'd
    Removed the steering column surround and the keyed ignition.
    ttora :anonymous:
  5. Aug 2, 2010 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Though the piston speed may indicate a theoretical 8 to 9k rev limit, the bottom end is no where near that capability. I have seen a few 5VZ engines putting down a reliable 280 hp to the tires, NA. But those were with new pistons, and such. To get near 1000 hp, you would need to completely re build the engine.
  6. Aug 2, 2010 at 7:32 PM
    autowagon
    Portland, OR
    That reminds me of another question. I think i read somewhere that the 3vz-fe has a main bearing support brace, and the 5vz-fe does not have this stock. Is this true? If so will this bolt up?
  7. Aug 2, 2010 at 7:40 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    :jerkoff:
  8. Oct 20, 2017 at 10:19 PM
    SPROCKIT
    SPROCKIT Member
    SPROCKIT
    Delmar NY
    02 TRD model & 03 S-Runner
    hood, lowered 2-3 inches, rims, cai, s/c, s/c pulley, URD fuel upgrade kit, headers, hi flow cat, Remus exhaust
    I made 448hp 605tq to the wheels
    Stock internals
    Intake, throttle body spacer, nitrous (100), TRD supercharger, 2.0 pulley (12psi), URD fuel upgrade kit, wide band, headers, cat, 2.5" exhaust, tundra brake upgrade, billet fly wheel, stage 3 clutch,
    Mad max on custom tacos has more
    Dalandser likes this.
  9. Oct 21, 2017 at 10:06 AM
    Dalandser
    Dalandser ¡Me Gustan Las Taco-mas!
    Anthony
    Downey, LB
    Empty Wallet Mod
    How many miles did you have this setup for? I watched the most recent engine masters with Dave Frieburger where they made 750 hp out of a stock 350 with a supercharger, but I'm thinking how long would that last? To be fair they commented on the same thing.
    Not planning on anything other than a mild supercharger boost with meth injection, but curious to know what you have to say about longevity of a setup like that.
  10. Oct 21, 2017 at 11:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Don't forget that they adjusted the ring gap. :thumbsup:
