5VZ-FE slow coolant loss
Discussion in '1st Gen. Tacomas (1995-2004)' started by anonymous27, Oct 30, 2021.
  1. Oct 30, 2021 at 4:51 PM
    anonymous27
    anonymous27 [OP] Member
    2004 Tacoma 3.4l, 2003 Tundra 3.4l
    Hi all,
    I’m working on a 2003 Tundra with the 3.4l 5VZ-FE and manual trans. I’m experiencing a slow loss of coolant that I first noticed about 6 months ago. I have since monitored the coolant level closely, but have had no luck tracing the leak. The most I’ll lose is about 2 inches from the reservoir over about 100 miles. I found a small leak from the water pump. I then replaced the water pump including new factory gasket and thermostat/gasket with jiggle at 6 o’clock. Still losing coolant. ECT is no greater than 181 degrees while driving. I have not experienced any performance issues, no overheating, no coolant on floorboard, and no signs of oil/coolant mixing. I’ve scanned relevant threads and I’m thinking a small leak at the coolant bypass tube inside the intake manifold or maybe a small leak in the radiator. Only leaks while running. About ready to try a pressure test, but would appreciate ideas/suggestions.
    Thanks
  2. Oct 30, 2021 at 4:57 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    You might be losing it through the exhaust. Not large enough to produce a steam trail but enough to notice.
  3. Oct 30, 2021 at 8:13 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    probably a head gasket leaking. most likely into the combustion chamber, so it gets burned and there is no sign of leakage. there are several tests to confirm.
    treyus30 likes this.
  4. Oct 30, 2021 at 8:41 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I can't keep my overflow reservoir full, either. People told me I have a head gasket leak, but I refuse to believe it! I just run the reservoir empty and no problems running or overheating.
  5. Oct 30, 2021 at 8:47 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yep, I second this. The 1st gen I had intially had a two cylinders with small cracks in the head between the coolant flow areas and the exhaust valves. Coolant would leak into the exhaust and get burned off - very slowly like you describe. My head gasket was fine, but the truck was overheated by the previous owner and the heads were slight warped as well.
    Either keep and eye on the coolant and keep refilling it, or do a pressure test and start dumping money into a fix (rebuild).
    JudoJohn[QUOTED] likes this.
  6. Oct 30, 2021 at 8:54 PM
    Kiloyard
    Phoenix, AZ
  7. Oct 30, 2021 at 9:41 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Think about the point of the reservoir. It's job is to supply coolant when the radiator is low, and accept it back under sufficient pressure.
    If you're losing it from the reservoir, you're losing it. If you don't see it coming out of any external coolant tubes, then there's only one other place: internally.
    JudoJohn and eon_blue like this.
  8. Oct 30, 2021 at 9:46 PM
    Kiloyard
    Phoenix, AZ
    I can't dispute the logic of that, but I also can't explain how my radiator stays full, years of driving with an empty reservoir, but as soon as I top off the reservoir it quickly vanishes. Conundrum I gave up on.
  9. Oct 30, 2021 at 9:48 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I mean, the reservoir is only supposed to be filled halfway, for the record
  10. Oct 30, 2021 at 10:07 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I'll bet the Radiator Cap gasket is bad.
    Or the neck of the radiator isn't seating tight to cap.
    That's why no visible sign of leak.
    Bivouac likes this.
  11. Oct 30, 2021 at 10:21 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    You'd see white trails
    Kiloyard likes this.
  12. Oct 30, 2021 at 10:33 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    The radiators are notorious for cracking and leaking with age.. Check that thing real hard for leaks
  13. Oct 31, 2021 at 11:23 AM
    JudoJohn
    St. Louis
    it's just a matter of time before it gets worse and you will have an overheating issue, which could warp your heads, and even strand you.
  14. Oct 31, 2021 at 11:26 AM
    JudoJohn
    St. Louis
    the coolant has to go somewhere, simple physics. either it is leaking into your cylinders or the radiator or some other part of the cooling system.
  15. Oct 31, 2021 at 11:30 AM
    anonymous27
    Thank you all for the input.
    To clarify... I have already replaced the rad cap and the coolant loss is not limited to my reservoir.
    I think I’ll start with a radiator pressure test before conceding to larger problems.
  16. Oct 31, 2021 at 11:32 AM
    Kiloyard
    Phoenix, AZ
    Sorry I hijacked the post with my own issue. Glad you chimed in to get it back on track.
    crazytacoman likes this.
  17. Oct 31, 2021 at 2:12 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
  18. Nov 1, 2021 at 10:10 AM
    Glamisman
    Glamisman Well-Known Member
    there are 2 coolant lines that go from the back of the intake manifold to the Idle control valve. They will seep and the coolant will drop onto the intake and "disappear".
  19. Nov 1, 2021 at 7:21 PM
    anonymous27
    Update:
    Borrowed a radiator pressure test kit. Pumped up to 13psi. Gauge dropped to 12psi within 15 minutes then stayed there...relieved pressure and disconnected after an hour (still at 12psi). I’ve looked everywhere possible without starting to take things apart. Still no luck finding a leak. I guess a dye and uv light might be next. Any thoughts about the dye/uv and next steps?
  20. Nov 1, 2021 at 9:02 PM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    Years ago, I kept losing coolant just like you have pointed out. I could not find leaks and never.had anything on the ground. I son's remember if it was late fall or early spring I was parked in my driveway, which has a good slope to it, with the Taco idling. I was coming back out of my garage and finally seen something dripping under the truck. The drip was coming from the back of the motor.
    Anyway, the coolant was leaking into the void under the I take manifold. Can't remember the space of the leak, but the combination of it finally leaking enough to fill that void and the slope of my driveway caused it to run out at.the back of.the I take and down.the back of.the motor.
    I was luck.that my truck was still under the extended warranty, as the dealer tore down the motor to clean everything up.
