5vz-fe Troubleshooting Advice Needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by ikuczman, Jul 24, 2025 at 11:16 AM.
  1. Jul 24, 2025 at 11:16 AM
    ikuczman
    ikuczman [OP] New Member
    2003 Tacoma with 175000 Miles on it.
    Symptoms as follows:
    Monday: Fine @ Idle, pull away in 1st gear, engine starts sputtering, All Dash Lights Flickering, Coolant Temp Gage Fluttering Everywhere, Engine Dies.
    Tuesday: Runs Fine
    Wednesday: Fine @ idle, pull away, Sputtering, Coolant temp gage flutters and climbs to red
    Thursday: Coolant Temp Light is on as soon as the vehicle is started (Cold Start)
    Planning on running a Combustion Leak Test to rule out a blown head gasket tonight.
    Is the Coolant Temperature Sensor completely independent of the Coolant Temp Sender? Or do they play off one another?
    Besides Ruling out the Sensors, checking grounds and connectors, what are some other possible causes of these symptoms?
    Thanks for your time
    - A Discouraged Taco Owner
  2. Jul 24, 2025 at 11:42 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Does your truck get parked somewhere where rodents attacking your wiring harness is a possibility? This sounds electrical in nature to me. So I'd be checking grounds, all visible wiring harness locations, etc.
    If the symptoms are actively happening, I might suggest even unplugging the negative battery terminal for 5 min and checking if things change afterwards (that may hint whether its electrical vs. mechanical).
    Lastly, I'd be scanning for codes as soon as possible.
    I wouldnt jump straight to leakdown test or other tests aimed to rule in/out head gasket issues.
  3. Jul 24, 2025 at 12:08 PM
    ikuczman
    Good Point Red_03Taco, No Rodent attacks (I have 4 outdoor cats that keep good guard), but I did splash a decent sized puddle the Saturday Before. Coincidence? I'll hook up a code reader tonight, and check true operating temp. I should get my hands on my buddies advanced scanner in 2 or 3 days.
  4. Jul 24, 2025 at 12:28 PM
    Red_03Taco
    Jerad
    Yea that large puddle splash definitely sounds suspect given the timing. Did you drive the truck much on Saturday/Sunday after that?
  5. Jul 24, 2025 at 1:00 PM
    ikuczman
    Yeah it seemed fine up until Monday. Then I started having symptoms. --> Tuesday, I had NO symptoms or abnormalities ----> Wed Shit hit the fan again
  6. Jul 24, 2025 at 3:41 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Simple things- check the battery terminals to make sure they are tight.
    ControlCar likes this.
  7. Jul 24, 2025 at 7:47 PM
    Glamisman
    Glamisman Well-Known Member
    ^^^ yep, give the cables the wiggle test. What type of battery cables/cable ends do you have?
