5VZ-FE
Discussion in 'Performance and Tuning' started by Brice, Aug 8, 2015.
  1. Aug 8, 2015 at 1:17 AM
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    10/6/21 Lets make this a discussion thread. Slightly less cringe to the eyes this way...
    8/8/15
    So heres my plan.
    I'm a 16 y/o kid in highschool and i want to build a 5VZ-FE for boost and general abuse. So my plan is to slowly by parts from LCE, such as forged pistons, rods, crank etc... Then supe the crap outta the little bugger and see how far i can make it go. Now the purpose of this thread is to have you guys suggest if what im doing (or planning to do) will work and if buying all the parts through LCE is a good idea.
    because_wumbo-truck likes this.
  2. Aug 8, 2015 at 1:47 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Oh it'll work if you're capable of wrenching well enough to build an engine (takes a lot of skill and patience), but all together just building an engine like the 5VZ to handle boost (before you even get to buy a turbo or S/C and the supporting mods and ECU piggybacks) will end up costing you more than an already boosted or fast vehicle off the used market (like an older 300ZX or an elderly Corvette).
    It would be cool and I'm certainly all for it but you might want to take the time to do all of the math, because even a fully built Tacoma or 4Runner isn't going to be a race car.
    1997tacomav6 likes this.
  3. Aug 8, 2015 at 8:33 AM
    Brice
    Brice
    Texas
    Yeah I fully realized that there are better options and I'm totally open to them. I just never see the 5VZ ever do great things unlike the 2R engines. More of what I plan to do is buy a 4 banger taco while I build on the V6. Nothing is set in stone and finding a supra would be cool too (turbo fun time lol)
  4. Aug 8, 2015 at 8:51 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Good luck. :playball:
  5. Aug 9, 2015 at 12:03 PM
    Brice
    Brice
    Texas
    Update: Ive decided to go with hyper (Hypereutectic) pistons from LC engineering. they are far cheaper than forged and still much stronger than cast. These will be included in a master rebuild kit (that also includes better studs). Since i cant find a better alternative im planning on going with forged rods and a forged crank. In the very near future i plan to replace my timing belt, water pump and crank pulley. I'm going to attempt a write up for those who are interested.
  6. Aug 9, 2015 at 12:12 PM
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Weld your rear diff for more traction. That way you can handle the power of your built 5VZ
  7. Aug 9, 2015 at 12:19 PM
    Brice
    Brice
    Texas
    Probably not...A detroit locker or aftermarket E-locker would be much more practical.
    Also nice pic lmao :rasta:
  8. Aug 11, 2015 at 10:33 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Why not just sell or trade with for a V8 Tundra from 01+ with the same trim.. Pre-runner and auto?
    Slightly wider and taller but just as daily drivable with almost the same MPG with a huge power boost.
  9. Aug 11, 2015 at 10:35 AM
    Brice
    Brice
    Texas
    Because I want to prove the point that the 5VZ can be just as easily rebuilt as the 22re 2RZ can. You don't see to many performance 5VZ's do yah? But yah sure do see plenty of 22r's and 2RZ's
  10. Aug 11, 2015 at 10:39 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Don`t go buying anything till you know just what size parts you need
    Unless your buying a Brand New Virgin Block Brand new Empty heads Brand new crank
    Then you can fit parts to what ever size you like.
    JBecker likes this.
  11. Aug 11, 2015 at 10:39 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Thats because its pretty well suited already for a bolt on SC, all other mods are extreme overkill and result in failure in other areas.
    The 5VZ is a solid engine already without the need, same goes for the 2RZ.
    The 22RE on the other had actually benefited from cams and better internals more because of the design.
    For all the money spent on the upgrading wont net much gain but will potentially make it stronger is all.
    If you do a full build then a full rebuild should be in order as well because building up an old motor is just not as effective.
    What HP numbers are you looking to achieve realistically?
    Stock is 190
    Wulf likes this.
  12. Aug 11, 2015 at 10:57 AM
    Brice
    Brice
    Texas
    Well I'm lookin for 300 with a supercharger bigger injectors and a custom tune. Aside from that im gonna have a forged crank and cons and I'm still debating on hyper or forged pistons. (And of course I'm gonna rebuild it). I also plan on custom ground cams unless I can swap some 3VZ cams in. Btw I plan on building the engine in my current driver. While I do that I'll be a cheap single cab work taco.
  13. Aug 11, 2015 at 10:58 AM
    Brice
    Brice
    Texas
    If I can't hit 300 s/c'd then I'll go turbo. (That'll take longer though)
  14. Aug 11, 2015 at 11:02 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    You wont hit 300 without turbo.
  15. Aug 11, 2015 at 11:03 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    all this to prove a point?
  16. Aug 11, 2015 at 11:03 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    1 tire fire will be on point.
  17. Aug 11, 2015 at 11:04 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    might as well give it a true locker or all wheel drive, all that power with the trucks super light end will be disastrous.
  18. Aug 11, 2015 at 11:17 AM
    Brice
    Brice
    Texas
    yup yah got it right.
  19. Aug 11, 2015 at 11:18 AM
    Brice
    Brice
    Texas
    Im not to sure about awd...ill try its 2-wheels and see where that gets me...
  20. Aug 11, 2015 at 11:18 AM
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Into a tree or a ditch is my guess
    ThorInc and Brice[QUOTED][OP] like this.
