5VZ-FE
Discussion in 'Performance and Tuning' started by Brice, Aug 8, 2015.
  1. Aug 11, 2015 at 11:20 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    hopefully not into a parked car or ditch.
    If you hammer the gas with all that power and no traction you will poop a little. :burnrubber::crapstorm::drevil:
    Brice[QUOTED][OP] likes this.
  2. Aug 11, 2015 at 11:21 AM
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    lol fair enough. How exactly would i go about awd?
  3. Aug 11, 2015 at 11:23 AM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Dollah dollah bills ya'll... anything is possible with enough money.:sandwich:
    ThorInc likes this.
  4. Aug 11, 2015 at 11:26 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    You can get a forged crank out of a 92-93 3vzfe camry or ES300 that will drop right in. Prob cost you $50-100 bucks from a scrapper.
    If your goals are only 300hp, don't touch the engine at all, and get a CX racing turbo kit, and a good standalone EMS with bigger injectors, fuel pump, etc. Stock 5vz's are safe up to 350-375rwhp.
    Check my sig for my build.
    ThorInc likes this.
  5. Aug 11, 2015 at 11:30 AM
    Brice
    Brice
    Texas
    lol you see im tryin to keep this under 6-7k but we'll see how that pans out...
  6. Aug 11, 2015 at 11:37 AM
    Brice
    Brice
    Texas
    First off i don't trust that kit. Second i wanna rev to the moon. (hence the forged pistons) The reason to do that is the engine is at 168k and it wasn't takin real good care of its whole life so it needs a bit of love and care (a rebuild)...............................................aaaaaaaaaaaaaaaannnnnnndd 300rwhp
    But in all seriousness i forgot about the forged crank in that other engine... definitely gonna look into that.
  7. Aug 11, 2015 at 11:42 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    When I was 16 I had similar ideas.
    Would be entertaining to see this idea become a reality. Mine didn't.
    That said.. I never had 7k to burn at 16. Do you?
  8. Aug 11, 2015 at 11:47 AM
    Brice
    Brice
    Texas
    Well yes sort of. My plan is to trickle buy everything as I see fit. However I can't begin this project until i buy a second vehicle (preferably a older taco with a 22re) to use for work.
  9. Aug 11, 2015 at 11:48 AM
    T4RFTMFW
  10. Aug 11, 2015 at 11:51 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You you have a 1st gen tacoma, 7k laying around, and the funds to buy another vehicle...at 16...?......
  11. Aug 11, 2015 at 11:52 AM
    Brice
    Brice
    Texas
    See the thing is, is im only 16 and therefore have next to 0 finacial requirements which will allow me to do stuff like this :D
  12. Aug 11, 2015 at 11:53 AM
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Sounds like a money pit.
    I've had a few.
    T4RFTMFW likes this.
  13. Aug 11, 2015 at 11:54 AM
    Brice
    Brice
    Texas
    1st gen taco: Yes
    Funds to buy another tacoma: Yes
    The ability to work and get 7k: Yes, but let me be clear i don't have 7k at the moment.
  14. Aug 11, 2015 at 11:55 AM
    Brice
    Brice
    Texas
    Well were they cool money pits? Then it was worth it...
  15. Aug 11, 2015 at 11:57 AM
    #35
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Sounds like you think the 5VZ can be like a honda motor.. high rpm's are not what the motor is for.
  16. Aug 11, 2015 at 11:57 AM
    #36
    JBecker
    Virginia
    Some. Not all.
  17. Aug 11, 2015 at 12:00 PM
    #37
    Brice
    Brice
    Texas
    Now don't let me say anything incorrect but if i remember correctly the 5VZ is overbore and understroke meaning the bore is bigger than the stroke. Isnt that basically the formula for a high revving engine? (that and many other things) And its not like ill be hammering it at 6000+ all the time, i just want it to be cabable
  18. Aug 11, 2015 at 12:06 PM
    #38
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    the power band is well under 5k on the 5VZ.. however on a honda thats where the power gets good. my VTEC kicks in at 6k on my acura. and my old 91 civic si would routinely rev to 8k no problem.
  19. Aug 11, 2015 at 12:08 PM
    #39
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    5VZ-FE[edit]
    The 5VZ-FE is a 3.4 L (3378 cc) engine which replaced the 3VZ-E. Bore is up to 93.5 mm (3.68 in) and stroke is 82.0 mm (3.23 in) while the compression ratio stays the same as the 3VZ-FE at 9.6:1. Output is 190 hp (142 kW) at 4800 rpm with 220 lb·ft (298 Nm) of torque at 3600 rpm. It has a cast iron engine block, and aluminum DOHC cylinder heads. The 5VZ-FE uses sequential multi-port fuel injection, has four valves per cylinder with shim-over-bucket tappets and features large cast connecting rods, one-piece cast camshafts, and a cast aluminum intake manifold. This engine also features an oil cooler and a wasted spark ignition system with three coils.
    Camshafts are belt-driven. The 5VZ-FE is a non-interference engine.
  20. Aug 11, 2015 at 12:11 PM
    #40
    anthony250f
    Anthony
    San Diego, CA
