5VZ-FE
Discussion in 'Performance and Tuning' started by Brice, Aug 8, 2015.
  1. Aug 13, 2015 at 7:32 AM
    #81
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    You would never be able to S/C / turbo, and you would likely have to run race fuel (100 octane) or E85 ethanol. you could prob make 300 crank HP but it would not be street friendly.
  2. Aug 13, 2015 at 7:49 AM
    #82
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Yeah I was afraid of that...
  3. Aug 13, 2015 at 7:54 AM
    #83
    CanadaToy
    Greg
    Toronto
    You sound like me when i was 16. LOL.
    Seriously, if you want to make power, do:
    ES300 crank
    forged rods/pistons (stock compression ratio)
    valves / springs / valve job
    cams if you want, but if you go too crazy, need to swap to shim under bucket
    cometic HG
    ARP studs and main studs
    a nice turbo.
    fuel upgrades
    standalone EMS
  4. Aug 13, 2015 at 8:01 AM
    #84
    Brice
    Brice
    Texas
    Haha Thats exactly what im headed towards at the moment (unless i can find rods and pistons out of another engine for less money) I was just toying with the idea of high comp vs medium boost and i think in my case medium boost will work best.
  5. Aug 13, 2015 at 6:27 PM
    #85
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Quoted for truth. Don't know if it was mentioned in this post as well, but CXRacing makes a really cheap turbo kit for the 5vz, it could be a good starting point (would probably need to replace the wastegate, BOV etc over time). I would do the above but would probably rock OE cams, and would try with an EMU before giving up and going standalone, just because I'm quarky like that.
    I can totally relate to the "sounds like me in my youth" comments haha.
    CanadaToy[QUOTED] likes this.
  6. Aug 13, 2015 at 7:18 PM
    #86
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  7. Aug 13, 2015 at 7:36 PM
    #87
    Brice
    Brice
    Texas
    Update: Ok so I've been at a crossroads for a bit... The thing is I could sell my current truck and buy something better like a 1st gen DCSB TRD off craigslist with highish miles (which i don't mind), buy a second work truck, then build up a 5VZ (which will take longer) or... I could keep my current truck and build up my current 5VZ after buying a second work truck. Soooooo which do you guys think would be a better decision? either one would work out perfectly for me its just that the first one will prolong the 5VZ build...
  8. Aug 13, 2015 at 7:41 PM
    #88
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    I just wanna see a 5vz pushed to the limit
  9. Aug 13, 2015 at 8:04 PM
    #89
    Brice
    Brice
    Texas
    lol then im gonna guess your in favor of the latter?:spy:
  10. Aug 13, 2015 at 8:12 PM
    #90
    because_wumbo-truck
    Jon
    Houston, Texas
    I'm just in favor of you following your dreams so i can live vicariously through you
    Tyler7544 likes this.
  11. Aug 13, 2015 at 8:18 PM
    #91
    Brice
    Brice
    Texas
    Lol im ok with that. And as the great Shia Labouf said "DON'T LET YOUR DREAMS BE DREAMS" and who am i to disagree?
  12. Aug 14, 2015 at 7:11 AM
    #92
    CanadaToy
    Greg
    Toronto
    You should buy a 5vz longblock from a scrapper and build it while you drive your current truck. Then you wont have a truck in pieces on your driveway for 3 years like somebody else i know.... ;)
  13. Aug 14, 2015 at 1:09 PM
    #93
    Brice
    Brice
    Texas
    :rofl:
    Hmm thats a good idea as well...Arent all 3.4l's long blocks? If there're not whats the difference?
  14. Aug 14, 2015 at 1:14 PM
    #94
    CanadaToy
    Greg
    Toronto
  15. Aug 14, 2015 at 1:14 PM
    #95
    Brice
    Brice
    Texas
  16. Aug 14, 2015 at 1:17 PM
    #96
    Brice
    Brice
    Texas
  17. Aug 15, 2015 at 11:30 AM
    #97
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    :popcorn:
    Working this weekend but Ill def weigh in when I have some time off. Not going to be cheap or easy, would def recommend getting a donor motor and building that. Swap your current motor with the built one.
    Customtacos.com is going to be a better forum for discussion than TacomaWorld, btw.
  18. Aug 15, 2015 at 11:33 AM
    #98
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    BTW, recommend these guys for Con Rods. Best rods for the money, hands down.
  19. Aug 15, 2015 at 5:15 PM
    #99
    Brice
    Brice
    Texas
    Which guys? lol
  20. Aug 15, 2015 at 5:44 PM
    #100
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Torspd likes this.
