5VZ HP limits as i found them.
Discussion in '1st Gen. Tacomas (1995-2004)' started by kickergt, Jun 4, 2013.
  1. Jun 4, 2013 at 2:24 PM
    kickergt
    kickergt [OP] Well-Known Member
    Shaun
    Fresno Ca
    00 Tacoma TRD 4x4 329WHP 390Wtq Turbo sucka
    Well as you have seen by my multiple posts on my turbo kit and its hp[​IMG] in stages i have found what i believe to be the limits of this block in its stock form. The early 5vz motors with the non mls gaskets is stable at 250wheel and has head gasket issues around 300-330 wheel hp. The newer style with the MLS head gasket is stable from 350 wheel to 375 wheel. The Fail point is 430-450 wheel. The breaking factor is not the piston but the connecting rod. Now of course this is all depending on your setup and your fuel system[​IMG]. My final setting is 350 wheel hp 435 wtq. I get 19 mpg[​IMG] on e85 city and 25 freeway. Runs like top.
  2. Jun 4, 2013 at 2:38 PM
    blknblubkrdude
    blknblubkrdude Well-Known Member
    Gillette, WY
    96 Taco. 4X4, 5MT, 2.7
    Oil field truck with 250k miles...original powertain. Wheelers 881's/5-pack, Energy bushings throughout.
    Those are very good numbers! What is boost/timing at 350whp?
  3. Jun 4, 2013 at 2:56 PM
    kickergt
    Shaun
    Fresno Ca
    11 psi 24 degrees of timing 44 lbhr injectors and meth on e85
  4. Jun 4, 2013 at 2:57 PM
    kickergt
    Shaun
    Fresno Ca
    19 psi made 432 whp 555 wtq
  5. Jun 4, 2013 at 2:59 PM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    Pics don't work for me!!
  6. Jun 4, 2013 at 6:12 PM
    kickergt
    Shaun
    Fresno Ca
    What?
  7. Jun 4, 2013 at 6:23 PM
    blknblubkrdude
    Gillette, WY
    Meth & E85? Impressive. 19psi numbers are shocking! Everything hold up to that torque?
  8. Jun 4, 2013 at 7:16 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I believe you're missing some other real world factors...
    like: 4X drive line load/gear reduction (puts a lot of stress on the mtr.)
    someone I knew had their 5VZ's connecting rod disintegrate
    while only pushing the factory 190 hp.
    was in 4X low... throttled up hard with 100% traction...
    bang ! (nice drain hole !) :p
    (was a 168K on the mtr.)
    ^ owner was meticulous with engine maintenance
    Using only oem or premium products.
    I will believe that the 5VZ con rods
    are definitely the weak link when pushing the 5VZ's hp.
    ^ aggravated more so... when a heavy load is applied.
    Don't think I'd push much beyond 300 hp
    without first beefing up the 5VZ's internals.
    * Maybe on a race truck...
    that gets rebuilt after each race.
    But not a trail rig or dd.
    ^ unless the 5VZ's consumable life expectancy is of no issue.
  9. Jun 4, 2013 at 9:04 PM
    kickergt
    Shaun
    Fresno Ca
    I Race it in 4W high and so far everything is holding. I had to have a custom clutch made.
    If your boy broke a rod it was due to poor tuning or a flaw in the rod nothing more. If it was a supercharged car it was 100% on the tune.
