5vz injector swap f up
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tomahawk418, Dec 6, 2023.
  1. Dec 6, 2023 at 8:50 AM
    Tomahawk418
    Tomahawk418 [OP] Member
    95 xcab Tacoma 5vz
    I posted something similar to this a little while ago but didn’t get much of anywhere with the answers I got. But I did a injector swap after I got a po304 code, after the swap there’s no code and no missfire but has been puffing white smoke out the tailpipe, (seems like coolant I’m not sure). Any clue what I might’ve messed up and miss placed?
  2. Dec 6, 2023 at 9:29 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Is it possible that the smoke was there before, and you're just now noticing?
    Have you monitored the coolant level?
    I would thoroughly check the vacuum and coolant line routing- specifically related to the IAC.
  3. Dec 6, 2023 at 10:52 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Is is steam (i.e. it evaporates within 5 or so seconds) or smoke (does not evaporate and it stinks)?
    Steam should evaporate after driving a mile or so) and I would ignore it. If it continues after 2 miles I would suspect a water leak. If it's smoke, then :pray:.
  4. Dec 6, 2023 at 12:34 PM
    Tomahawk418
    95 xcab Tacoma 5vz
    Positive it wasn’t there before, it’s a lot of smoke for sure, I’ll go back over all the lines but I’m pretty sure everything is where it was, if I get some time today I’ll double check all of them to be sure
  5. Dec 6, 2023 at 12:36 PM
    Tomahawk418
    95 xcab Tacoma 5vz
    smoke for sure, doesn’t clear up and smells for sure, I haven’t really driven it to see if that would clear it up but seeing how much it is smoking I doubt that would be the issue
  6. Dec 6, 2023 at 3:16 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Does it smell sweet, like coolant? Can’t see how changing the injectors would introduce coolant into the combustion chambers but like others said, go back over all lines you touched.
    Otherwise it’s a head gasket, recommend not driving it until you figure it out.
  7. Dec 6, 2023 at 3:57 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    An incorrectly plumbed vacuum/water by-pass line would pump coolant into the TB through the IAC... :anonymous:
    mlcc and TACOTU3 like this.
  8. Dec 6, 2023 at 4:07 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Oof, hope you didn’t learn that the hard way. You’d have to clamp the coolant line onto the vacuum port else it would be spraying coolant everywhere - that’s an advanced screw up :laughing:
  9. Dec 6, 2023 at 4:09 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I have not personally done that... But people jamb hoses on the wrong stuff all the time, so it's certainly possible.
  10. Dec 6, 2023 at 5:32 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    How many miles on this engine?
    If its a moderate coolant leak.....your coolant level should be dropping...
    any chance you've got access to a bora-scope...
    have you pulled that plug and looked at it.....
  11. Dec 10, 2023 at 9:21 AM
    Tomahawk418
    95 xcab Tacoma 5vz
    haven’t driven it since, only started it up and backed it in/out of the shop, I wouldn’t necessarily say sweet but it doesn’t quite smell like just exhaust. I don’t really see how it would’ve introduced coolant either but I also can’t see how it would’ve caused a headgasket to go? I’ve had headgasket concerns since I bought the truck but nothing was seeming to be wrong, up until now.
  12. Dec 10, 2023 at 9:24 AM
    Tomahawk418
    95 xcab Tacoma 5vz
    almost 213,000 on the truck, engine is iffy I bought it at 208 and I don’t have shit for a history on the truck, I know there was previous heagasket issues but I’m not sure at this point if that was on another motor or what the deal was. Not sure if we’ve got a bora scope lying around I’d have to dig, which plug are your referring too?
  13. Dec 10, 2023 at 9:28 AM
    O'Silver_Taco
    MD
  14. Dec 10, 2023 at 8:52 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Tomahawk
    Pull the #4 plug
    Let’s see what it looks like
  15. Dec 11, 2023 at 7:04 PM
    Tomahawk418
    95 xcab Tacoma 5vz
    Forgot to mention in my first post that I went ahead and swapped all 6 injectors, worth looking at all plugs? I’ve got some time tomorrow I can probably go look, it’s sitting out of town at our shop right now so it’s not super convenient to go work on especially as things r getting pretty effin cold. Also got a cooling system pressure tester that I’ll try out. I’ve been worried about the head gaskets since I bought the vehicle but I don’t see how they would blow after the swap? Either way thank all of you for the helpful info!
  16. Dec 17, 2023 at 9:58 AM
    bloodyxsocks
    bloodyxsocks Well-Known Member
    1995.5 Toyota Tacoma 4wd
    so what was the problem? Ever solve it?
  17. Dec 20, 2023 at 8:28 PM
    Tomahawk418
    95 xcab Tacoma 5vz
    Finally got some time for lookin, and things ain’t lookin good I’ve got coolant in with my oil now and I’d pulled a couple spark plugs and one had a bunch of oil around the threads. My guess is the headgasket finally went. I’d bought it with little info, some of which being that they’d blown before and been fixed and then blown again and that was its current state? But it ended up running fine. I could give a whole history in my possession but it’s a long effin story
