5VZ making a strange tick/knock (video included)
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco terror, Jul 26, 2013.
  1. Jul 26, 2013 at 3:41 PM
    taco terror
    taco terror [OP] 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
  2. Jul 26, 2013 at 4:05 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    All i hear is the normal toyota ticking.( hard to tell even with my headphones plugged in and turned all the way up) if there is any extra noise...
    My 5vz with 251XXX does the same thing mine is alittle louder do to some head work and jba headers which makes it louder at idle...
  3. Jul 26, 2013 at 4:36 PM
    taco terror
    USA
    I heard about the normal tick, I thought this was excessively loud though to just be a characteristic of the engine.
  4. Jul 26, 2013 at 8:26 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
  5. Jul 27, 2013 at 4:13 PM
    taco terror
    USA
    Hey thanks for taking the time to make the video man! I think mine is quite a bit louder though. I don't know if these V6s need the valves adjusted like the 4 bangers do.
    I am just worried about all that noise she makes.
  6. Jul 27, 2013 at 4:37 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Might try sea foam. At least that would rule out a cracked manifolds. If there is a crack smoke would seep through.
  7. Jul 27, 2013 at 4:42 PM
    BamaToy1997
    Bill
    Navarre, FL
    The 3.4 and the 2.7 (as well as the 2.4) don't have traditional "valve adjusting". They use shims to set valve clearance. If clearance gets excessive you have to replace the shims themselves.
  8. Jul 27, 2013 at 4:49 PM
    taco terror
    USA
    Thats what I meant, could they cause noise on an engine with 90k?
    Also does anyone else think the sound on my truck is excessive?
  9. Jul 27, 2013 at 6:19 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I'll just be proactive here and post the link to a valve shim writeup. http://www.yotatech.com/f128/5vz-fe-3rz-fe-2rz-fe-valve-adjustment-tech-226997/
    And after watching both, yours does seem a bit louder. I'd bet you money it's something silly. Mine was making a funny noise until I realized a nut on the downstream O2 sensor rusted off and the sensor wasn't sealed down tight. Silly things will do it.
  10. Jul 27, 2013 at 8:57 PM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    mine has never made ticking noise like that I have a small exhaust leak that you can hear at about 2000 rpm driving but never had a tick like that.
  11. Jul 27, 2013 at 9:27 PM
    taco terror
    USA
    Damn, I hope its nothing. This engine is still a baby :(
    Is it worth taking to the dealership?
  12. Jul 28, 2013 at 2:19 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    I'd say no. Try seafoam and look for exhaust leaks.
  13. Jul 28, 2013 at 7:22 PM
    taco terror
    USA
    Shouldn't be an exhaust leak, it only happens after it is warmed up and is most noticeable at 700 rpm and under. You can't hear it once the revs get over a certain point like 900 rpm.
  14. Jul 29, 2013 at 7:06 AM
    BamaToy1997
    Bill
    Navarre, FL
    While you may still be right about it not being an exhaust leak, it can't be ruled out simply because it only occurs after it warms up. An exhaust leak can become more evident after the engine and exhaust warm up due to thermal expansion. You have an aluminum head, and a steel manifold. Both metals expand differently when hot.
    Again though, you may be very right that it is something else, I just didn't want you to rule out exhaust leak based on what you said. The best way to find a mechanical noise, if that is the case, is to use a cheap listening device and place it on the valve cover(s) where the noise seems the loudest.
  15. May 4, 2018 at 9:29 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    Gonna bump a very old thread here because my truck makes the exact same noise. @taco terror did you ever figure out what this was?
  16. May 4, 2018 at 9:36 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    lol. I'm like 80% sure the motor just needed a proper oil change.
    Sounds like noisy valves due to thin/low oil.
  17. May 4, 2018 at 9:44 PM
    aknickyota22
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    I don't think it's an oil related issue. Mines always been run with Mobil1 full synthetic, changed every 3,000 miles, and never been run low on oil and it still makes this noise.
  18. May 4, 2018 at 10:02 PM
    fast5speed
    Washington D.C.
    I'm pretty sure it's the valve train either way. I'm not buying the cracked flex plate.
    If it's the valvetrain, then oil is low (the giveaway with OP was 'only when warmed up') or the valves or damaged or out of adjustment. Damage is always possible one way or another. As is somehow prematurely wearing down on the shims so that something falls out of adjustment, but I don't know. I figure on a 90k mile 5vz, I would lean more towards something not pressurizing properly - oil.
    The proper oil and filter are important.
  19. May 4, 2018 at 10:13 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    had my truck sense 65k miles and its always done that faint tick, do oil change every 3k miles. Even run sell 91 with the cleaning shit in it like every 4th fill up. Still no clue why it does that
  20. May 4, 2018 at 10:31 PM
    taco terror
    USA
    I do oil changes every 3-3.5k miles within the dots on the dipstick (aka my engine never has low oil). The valve shims have never been adjusted and now at 130k I don’t really notice/pay attention to the noise. Could just be a characteristic of the engine, or I may need to get them adjusted.
