5vz misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by gainman, Aug 9, 2013.
  1. Aug 9, 2013 at 6:14 PM
    gainman
    gainman [OP] Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I just got a check engine light and it says it detected a misfire. It seems to be running good its not lumpy at all. If a cylinder goes down on this motor I should be able to tell right? I tried pulling plugs one at a time to see if it changed the idle at all but none of them affected it at all. How do I properly check to see if all cylinders are firing?
    Edit:
    -2000 Tacoma TRD
    -3.4l
    -5 speed
    -extended cab
    -70k original miles
  2. Aug 9, 2013 at 6:25 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    When did you last change plugs and wires?
  3. Aug 9, 2013 at 6:29 PM
    gainman
    SW Florida
    Stuff
    5k ago
  4. Aug 9, 2013 at 9:35 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    What kind of plugs?
  5. Aug 9, 2013 at 9:56 PM
    gainman
    SW Florida
    Stuff
    dealership. denzo?
  6. Aug 9, 2013 at 10:10 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Random misfire, P0300? Or a specific cylinder? If specific, go to that cyl.
  7. Aug 10, 2013 at 7:36 AM
    gainman
    SW Florida
    Stuff
    Random. It's freaking me out because the truck appears to run great. I would expect it to be a little lumpy
  8. Aug 10, 2013 at 9:50 AM
    gainman
    SW Florida
    Stuff
    ok so I pulled all the plugs today to check them. they all looked beautiful (just changed 5k miles ago) except for 1. it came out of the passenger side cylinder furthest to the rear of the truck (is this number 4?).
    I think im gonna try seafoam. maybe 1/3 can into the intake plenum and the rest in to the gas maybe itll clean the injectors out a little. is this a bad idea?
  9. Aug 10, 2013 at 10:04 AM
    TODEOTA
    TODEOTA Well-Known Member
    Jake
    Lewiston, ME
    2000 SR5 4x4 extra cab
    Horn upgrade, 2.5" Rough Country lift going in soon
    Are you sure you changed that one plug 5K ago?
  10. Aug 10, 2013 at 10:27 AM
    gainman
    SW Florida
    Stuff
    Yeah I did them all. It certainly shouldn't look like this so soon. What causes that is it heat? Need to figure it out
  11. Aug 10, 2013 at 11:39 AM
    MEDICDUDE423
    MEDICDUDE423 Well-Known Member
    East TN
    03 Tacoma Limited X-Cab 4WD
