5vz, Rebuild, Replace or upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by RangeDrive, Mar 13, 2018.
  1. Mar 13, 2018 at 3:17 PM
    RangeDrive
    RangeDrive [OP] Well-Known Member
    02 V6 Double cab
    Icon front end, OME Dakar rear, ARB front bar
    My 3.4 has 329,000 miles on the clock, and ran like a top, until lately. Occasionally it stutters, at idle and while driving, the stutter is short but hard and usually happens a couple of times then quits. Reliability is key for me as it is my daily driver. So should I try to troubleshoot the problem? Or look at swapping in a used or JDM motor or rebuild? I’ve considered a Toyota diesel swap but that would be time consuming and a little more than I want to do probably.
    If I do swap I will probably do the transmission while I’m at it so I don’t have to worry about anything
  2. Mar 13, 2018 at 3:23 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    A stutter is not indicative of the heart being bad. Do a leak down test, because chances are your USDM engine is in better shape than some JDM junk that never had the oil changed and rotted on a dock for months if not years.
    If the engine is junk, just go to car-part.com and buy a low mile USDM take out from a low mile wrecked truck
    Ridgerunner likes this.
  3. Mar 13, 2018 at 3:56 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You should start with the basics like mentioned above. Then you'll find out what needs to do to keep the engine running. Do you have a code reader?
  4. Mar 13, 2018 at 4:17 PM
    RangeDrive
    02 V6 Double cab
    I don’t have a reader, I can go to the parts store, but there’s no CEL. I’m a decent home mechanic but I can’t figure out what is causing the studder
    Dalandser likes this.
  5. Mar 13, 2018 at 4:23 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'd suggest getting a blue tooth / wifi one if you have a smart phone - they're decent for the low cost:
    https://www.amazon.com/Foseal-Scanner-Adapter-Diagnostic-Android/dp/B00W0SDLRY
    Then get a $15-20 app for your phone. Even without one I'd still go with @Itchyfeet's advice to see if the engine is mechanically fit.
  6. Mar 13, 2018 at 4:41 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What about your plugs/wires, MAF, throttle body, etc...?
  7. Mar 13, 2018 at 5:33 PM
    RangeDrive
    02 V6 Double cab
    It doesn’t seem like a misfire ( wouldn’t there be a code ) , throttle body and iac have been cleaned within 5,000 miles.
  8. Mar 13, 2018 at 5:38 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Check for vacuum leaks - I thought you would have gone through the regular diagnostics if you had posted on here about swapping out an engine, but it is what it is - you've racked up a fair amount of miles on that mill. Check for pending codes and misfire counters if you can get them from a scanning device.
    Since you're at the beginning of the diagnosis then spark, air, fuel, and compression are all possible, but if it's not a regular occurrence, you're right a bad cylinder may not be the case. You can check for spark and fuel if you can recreate the symptoms at idle...
