5VZ shaking at idle after install of new fan parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ozark_RegCab, Jul 11, 2024.
  1. Jul 11, 2024 at 5:51 AM
    Ozark_RegCab
    Ozark_RegCab [OP] Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I just installed a new fan, fan clutch, and fan bracket after the bracket bearing failed and caused all the belts to fall off when the fan/fan clutch/pulley assembly came loose. The truck now starts right up and stays cool, but there’s a noticeably rougher idle than before. It looks like the whole engine is shaking (see video below).
    Could a mistake during install of said parts cause such shaking? Or is it more likely bad engine mounts?
    I also don’t have any codes, and it idles right at 600 RPMs when warmed up..
    https://youtube.com/shorts/W90Sv8KIMDI?si=NetpZns0u5tj45zO
    Black97v6MT likes this.
  2. Jul 11, 2024 at 6:36 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    how many miles are on this 5VZFE
    original mounts still?
    my rig is currently having some shakes as well, but is noticeable in the shifter stick in 5th gear at certain RPM range on the highway load on a recent rebuilt R150F
    maybe the engine mounts, may not be the engine mounts on mine that are original at 356k of service
    still under a DiY diagnostics...
  3. Jul 11, 2024 at 6:44 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    250k; AFAIK the mounts are OG. Btw I do also have a driveshaft that’s too short that vibrates over 75 mph. I was waiting to exchange it at the driveshaft shop after installing the new springs I have.
    Black97v6MT[QUOTED] and wilcam47 like this.
  4. Jul 11, 2024 at 8:57 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Update - I am getting misfire codes now, along with a severe stumbling and hesitation when I accelerate. I’m hoping it’s just bad gas and I didn’t blow the head gasket when the fan came loose..
  5. Jul 11, 2024 at 9:33 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Do you remember the Full list of EVERYTHING you touched/removed/replaced during the install?
    cruxofthebisquit likes this.
  6. Jul 11, 2024 at 10:03 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I don’t remember unplugging any sensors. All I did was move the plug wires out of the way.
  7. Jul 11, 2024 at 10:05 AM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Check that the electrical connections to the ignition coils are correct and fully seated.
  8. Jul 11, 2024 at 10:21 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    When the belts came off, they could have torn wiring to nearby sensors. Unless the engine overheated, the head gasket would not get damaged from fan damage.
  9. Jul 11, 2024 at 10:26 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I didn’t notice any damage to any wires or coils, but I’m also not much of a mechanic so I could be missing something. I can’t be sure it never overheated, but temps seem normal as I’m driving around on the OBD2 gauge.
  10. Jul 11, 2024 at 9:50 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    After doing some research, it seems like the only things that would affect only one side if the engine are 02 sensors, knock sensors, skipped timing on one cam, or a head gasket. Am I missing anything?
  11. Jul 11, 2024 at 10:22 PM
    time623
    James
    AZ
    I’d reseat all the plug wires on both the ignition coils and driver side spark plugs. R Quadruple check the plug wire order while you do it too. Grab the wire and follow it from end to end and make sure it’s absolutely in the right order.
    Maybe when you moved the wires out of the way you somehow managed to unseat all 3 :confused:
    Reseat the cam position sensor connector on the timing cover too.
    If I had to bet on the cause, it would be something that you touched or got damaged during the fan failure or installation. The timing of a knock sensor or 02 going out at the same time as the fan is just too coincidental imo
    It’s probably something really weird and minor you forgot you unplugged or something like that
  12. Jul 11, 2024 at 10:37 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea it also seemed unlikely I could’ve caused the timing belt to jump timing when I was fiddling around with it, but who knows
    time623[QUOTED] likes this.
  13. Jul 11, 2024 at 10:39 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Yeah, double check. Always be suspicious of things you touch. Goes for all of us, mechanic or not. That said. Are you losing water? Checked plugs to see if one is TOO clean? I think the parts stores all rent enough tools to check both coolant system and compression. Not a bad idea.
    I doubt this is a motor mount, sorry.
  14. Jul 11, 2024 at 10:39 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I did check them earlier and they all seemed to be seated solidly. Also doesn’t each coil go to two cylinders? So you couldn’t have 1.5 coils go bad and cause only one bank to miss then right? Also it seems like if the wires were bad, then both sides would have issues, not just 2, 4, and 6.
  15. Jul 11, 2024 at 10:40 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    nah, you didn't do that without messing with tensioner.
  16. Jul 11, 2024 at 10:41 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I did check coolant, and it did appear to be right at the cap, maybe slightly lower, but it has been mostly sitting for a few months. No overheating or unusual pressure in the hoses. I will try to pull plugs and rent a compression tester when I can.
  17. Jul 11, 2024 at 10:42 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Maybe the fan or fan bracket bearing bumped into the tensioner when they failed and came loose?
  18. Jul 11, 2024 at 10:42 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Be nice to rule out HG, one way or another. Looks like misfires on video but it's just guessing why.
  19. Jul 11, 2024 at 10:44 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    eh. Pretty unlikely. That would be one magic loogie.
    time623 likes this.
  20. Jul 11, 2024 at 10:45 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    It’s definitely possible. It could’ve overheated when I was driving it with the bad bracket and the belts had come off. Usually a bad HG will be a miss on one or maybe two cyls, but I suppose it’s possible to make three in a row misfire. I feel like that’d be a pretty catastrophic head gasket failure with a lot of coolant loss though, but I could be wrong.
