5VZ shaking at idle after install of new fan parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ozark_RegCab, Jul 11, 2024.
  1. Jul 12, 2024 at 3:34 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    What about turning the crankshaft backwards too much? Can that cause the timing belt to jump and cause those symptoms?
    Or if the nuts aren't seated on the fan sufficiently (I think it's best to detension the belts first), could a shaking from that cause the symptoms?
  2. Jul 12, 2024 at 5:44 PM
    Ozark_RegCab
    Ozark_RegCab [OP] Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I'm not sure if I could've turned the crankshaft by accident. The timing belt could just be worn out, which may have caused it to jump a tooth.
  3. Jul 12, 2024 at 6:52 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I'm with @time623 on this one, it's gotta be something you touched and likely electrical.
    How old are the plug wires in question? Wondering if the plug wires were on their last leg and you moving them pushed them over the edge?
    The fact it's 3 cylinders on one bank also makes me think it's electrical (and points to those wires). Maybe try some electrical connector cleaner on the contact ends of all the wires and reseat them.
    Black97v6MT and time623 like this.
  4. Jul 12, 2024 at 7:35 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Yup. Electrical.
  5. Jul 13, 2024 at 7:13 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I’m thinking I’ll just get NGK wires at Autozone since I don’t know how old these wires are.
    Red_03Taco[QUOTED] likes this.
  6. Jul 13, 2024 at 8:47 AM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    are they OEM wires?
    those would have a year on them
  7. Jul 13, 2024 at 8:50 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I think they’re OEM yea. They’ve been on there for at least two years.
  8. Jul 13, 2024 at 9:05 AM
    Red_03Taco
    Jerad
    See if you can find a printed date on the wires. They could be 15-20 years old and well past their service life
  9. Jul 13, 2024 at 9:21 AM
    Black97v6MT
    iMA0
    tacoLand USA
    could be 28 years old!
  10. Jul 15, 2024 at 11:48 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Those error codes are all on the right bank of the engine. I bet it's wire related.
  11. Jul 15, 2024 at 11:51 PM
    Toyota Dude
    Toyota Dude Well-Known Member
    2004 Tacoma 4WD 6-CYL DC
    Denso for coils
  12. Jul 16, 2024 at 7:31 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I need a list of what you touched.
    ...on the truck
    Notably, all your misfire codes are on one side of the engine. Spark wires all snug?
  13. Jul 24, 2024 at 10:52 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    It may seem strange, but it's at mechanic after wires didn't fix it.
    It turns out the issue is timing. See the similar threads below. Maybe the drivers side cam cracked or wore out, or a tensioner went bad on that side? I also had a randomized misfire, so it may well have been missing on all cylinders, even though the ECU singled out the drivers side for some reason on my code reader.
    Could I have damaged the timing belt or a tensioner when moving the timing cover out of the way? Or maybe the grooves on the belt are just old and worn out.
    https://forum.ih8mud.com/threads/tracking-down-a-bank-specific-misfire-2-4-6-8.1198888/page-2
