5VZE/3RZ engine mount information
Discussion in '1st Gen. Tacomas (1995-2004)' started by toypower, Jan 14, 2020.
  1. Jan 14, 2020 at 8:08 PM
    toypower
    toypower [OP] Well-Known Member
    corey
    Niceville FL
    98 Reg Cab Tacoma
    Sas swap, dana 44 high pinion front, Corporate 14 bolt locked, disc brake conversion. 8 inch superlift springs on 39.5 iroks, 5:38 front and rear. Hydraulic assist, 3 inch body lift, Yukon axles front/rear, bilstein shocks, CAI, rock ripper header.
    Just curious if anyone knows if 1995 5vze engine mount brackets are the same as the 3rz engine mount brackets. The frame side not the engine block side. The bracket welded to the frame.
  2. Jan 14, 2020 at 8:10 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    i do believe they're different
    at least the part number for a v6 frame vs a 4 pot frame are different
    cruiserguy likes this.
  3. Jan 15, 2020 at 8:18 AM
    toypower
    corey
    Niceville FL
    98 Reg Cab Tacoma
    Alright, I didn’t think I’d get that lucky lol. Thanks for the info
  4. Jan 15, 2020 at 2:12 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I read they are different
  5. Jan 15, 2020 at 2:17 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Frame side different.
    Motor side same.
    I used the original 3.0 mounts to swap 3.4 into my 91.
  6. Jan 15, 2020 at 2:18 PM
    toypower
    corey
    Niceville FL
    98 Reg Cab Tacoma
    Alright plasma cutter here I come. I’ll just weld in some aftermarket LS mounts. I was hoping I could use advance adapters bolt in LS adapters. They said they fit 95 5vze mounts
