5vzfe normal running temperature
Discussion in '1st Gen. Tacomas (1995-2004)' started by Riptide, Dec 16, 2011.
  1. Dec 16, 2011 at 9:30 AM
    Riptide
    Riptide [OP] Knee Dragger
    Richmond, VA
    99' Black Tacoma TRD 4x4 6 cyl Ext Cab
    Matching bed cover, soon-to-be 01 front end conversion
    I don't have any sort of gauge to go by except the needle for the oil temp, but what I'm seeing on my "new to me" 99 Taco 5vzf-e (141k) is just above the half way mark. Coming from the 3vze on the 94 pickup where it ran at about 1/3 tops, sitting at 2/3 in the middle of winter is making me uneasy and making me wonder if there's an issue I need to start hunting for. Apart from the (from what I read) infamous P0450 and P0441 codes for the emissions canister causing a CEL, it performs flawlessly. Great idle and around 17MPG mixed highway and city.
    If I could get some folks to confirm either that this is completely normal, or post up some pictures of their gauges for comparison, it would be greatly appreciated. :cool:
    UPDATE!! Here's a pic. AND, I'm leaking coolant(dripping off the skid plate). Just noticed day before yesterday. With it being 30 degrees out and raining, haven't had a chance to locate where it's coming from exactly.
  2. Dec 16, 2011 at 9:37 AM
    magic
    magic Well-Known Member
    you dont have a temp guage in ur 99???
  3. Dec 16, 2011 at 9:40 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Normal. Mine is always above 1/2 at opperating temp.
  4. Dec 16, 2011 at 9:42 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Yeah, mine is dead middle every time, all the time.
  5. Dec 16, 2011 at 9:52 AM
    Riptide
    Richmond, VA
    I do, but you have a space like "_____________" and the needle is anywhere in between without any point to truly reference spot, as say, compared to an actual temperature or "degree" amount. Best I can do is say the needles 2/3 from red.
    Thanks guys, makes me feel a bit better. Already double checked fluids and any other codes, figured it should be fine but wanted to run it through here on the forums.
  6. Dec 16, 2011 at 9:54 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Make sure it is running the Toyota pink coolant.
  7. Dec 16, 2011 at 10:03 AM
    Riptide
    Richmond, VA
  8. Jan 12, 2012 at 1:40 PM
    Riptide
    Richmond, VA
    BAH, just found a coolant leak. Not sure where from yet. See original post for picture of temp.
  9. Jan 12, 2012 at 1:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Probably the water pump, or perhaps one of the hose clamps is getting weak.
    fyi my temp is always between 190 and 200 if im running it hard.
  10. Jan 12, 2012 at 1:54 PM
    Riptide
    Richmond, VA
    [​IMG] I'll check it out tonight. Here's hoping for a simple hose or clamp replacement...
    :cheers:
  11. Jan 12, 2012 at 2:00 PM
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    um thats not good jason, toyotas are not suppose to pass the half way mark. midway mark is 200 degress i think, so above means your running way too hot.
    but who cares you're the engine swap expert :D
  12. Jan 12, 2012 at 2:05 PM
    Kevlar1267
    Kevlar1267 Well-Known Member
    Kevin
    Minneapolis
    2002 Tacoma SR5 4x4 2.7
    Magnaflow exhaust,K & N filter,Bilstein Shocks
    My 2002 was always dead middle once it warmed up and never went higher. I had over 100,000 miles and had it flushed twice and the coolant was always clean and pink.........
  13. Jan 12, 2012 at 2:10 PM
    Riptide
    Richmond, VA
    Second time having pink coolant has been made a point. Is it bad that I'm using a universal coolant?
  14. Jan 12, 2012 at 2:13 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    My old Tacoma Supercharged and all ran religiously at 180 degrees F.
  15. Jan 12, 2012 at 2:19 PM
    t4r4life
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    ya the green stuff runs hotter, but you can lower the temp but draining some coolant out and add some distilled water since whater is what actually cools the truck and the coolant is just for anti freeze and lube.
  16. Jan 12, 2012 at 8:27 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Doesn't matter which kind of coolant you use, it won't make more than a tiny insignificant difference on how hot the car gets. If your engines getting hot you have another problem.
  17. Jan 12, 2012 at 8:44 PM
    pt law
    pt law Well-Known Member
    Concord, NH
    04 xtracab 4x4 TRD
    This is not necessarily true. Look at mine below. I know it looks high, but when I run the scan on it, it comes back 190 normally. So, there is some variance on these needles. My truck goes there an never moves no matter how hard I work the damn thing. So op, do not let this worry you to much (but fix your coolant leak obviously and use pink coolant only). If you are really concerned, then get the truck scanned (borrow a scangauge, take it to a place that will do it for free, or give you local mechanic like 10 bucks to plug in the their damn diagnostic tool for 10 seconds and tell you the temp). good luck.
  18. Jan 13, 2012 at 11:34 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    my 04 runs just past the halfway mark like the two gauges pictured. I was always worried that was too hot, but I was told that was okay.
  19. Jan 13, 2012 at 12:27 PM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    This is how my '98 is
  20. Jan 13, 2012 at 3:08 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Arizona
    03 Prerunner SR5 2wd
    Same as everyone else. Needle stays at the halfway mark. Mine gets there pretty quickly too, but I imagine that as long as it doesn't get any higher everything's fine.
