5vzfe supercharger install issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jbogstaco, Oct 11, 2020.
  1. Oct 11, 2020 at 9:28 AM
    Jbogstaco
    Jbogstaco [OP] Well-Known Member
    Jeremy
    Supercharged 2002 Tacoma double cab trd
    3 inch lift, supercharged
    So I installed a first gen supercharger (gray) on my Tacoma . After everything was done with I got 7 check engine codes . It’s reading that cylinders 1-6 and misfiring and multiple misfire codes. I replaced the plugs with denso ik20s and gapped them to .43 could the problem have been when I tapped them? Just would hate to spend another 70$ on plugs .
    Also my transmission shifts like a second too late now I have to get off the gas to make a shift engage . Any feedback would be super helpful thanks !
  2. Oct 11, 2020 at 9:40 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Check for vacuum leaks.
    When's the last time you did a service or flush on your transmission?
  3. Oct 11, 2020 at 9:58 AM
    Jbogstaco
    Jeremy
    Haven’t done any tranny service vacuum seems to be all checked I bought all new lines . Only at 110k my tranny fluid is still red
  4. Oct 11, 2020 at 10:22 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You’d have to majorly screw all the plugs to get all of them to misfire. Check your vacuum routing. Worst came to worst throw your old plugs in - it’ll idle without enough boost you won’t misfire I’d imagine.
    12TRDTacoma likes this.
  5. Oct 11, 2020 at 10:25 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would check vacuum routing next as mentioned.
    Take it one step at a time. Deal with the misfire first. Then your tranny issue.
    Also, check your spark plug wiring. Make sure they are not crossed into cylinders where they should not be.
    QMEDJoe likes this.
  6. Oct 11, 2020 at 11:38 AM
    Jbogstaco
    Jeremy
    Will check vacuum routing and if issue persists then throw the old plugs back in. Do you guys think the issue can be the transmission lockdown cable ?
  7. Oct 11, 2020 at 12:26 PM
    02hilux
    Planet: EARTH
    What are the 7 codes?
    Dalandser likes this.
  8. Oct 11, 2020 at 12:31 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think 300, 301, 302, 303, 304, 305, 306?
  9. Oct 11, 2020 at 12:33 PM
    Jbogstaco
    Jeremy
    I just know it was multiple misfires and then it said every cylinder misfired
  10. Oct 12, 2020 at 1:05 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Trans is probably the kick down cable out of adjustment.
  11. Oct 12, 2020 at 7:54 AM
    Jbogstaco
    Jeremy
    That’s what I was thinking , so if I gapped denso ik20s like a normal spark plug do you think that could have ruined the electrodes ?
  12. Oct 12, 2020 at 8:36 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    It's possible the electrodes were damaged, Pretty easy to find out. Throw the old plugs back in it.
  13. Oct 12, 2020 at 8:39 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You need to make sure you didn't cross the spark plug wires to the cylinders. Because that would cause a domino effect misfire into the cylinders which are proper if you have the 3 coil, 3 wires type setup.
    Also you don't gap Iridiums unless you have the proper tool for it. A standard gapper tool will destroy the iridium coating and turn the spark plugs into the regular style. From there they would get ruined fairly quickly. I would even venture to say that they would get ruined faster than a standard plug.
  14. Oct 14, 2020 at 5:33 PM
    Jbogstaco
    Jeremy
    Hey guys a little update . Replaced all spark plugs codes haven’t popped back yet although I haven’t done much driving today . Tightened the tranny cable and it’s still shifting late if I give it some gas , any ideas? Can it be because I had to take the cable off the bracket to get it on the supercharger , if not it didn’t have enough room to get over it
  15. Oct 14, 2020 at 5:33 PM
    Jbogstaco
    Jeremy
  16. Oct 15, 2020 at 12:51 AM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Trans cable still looks loose, its the one right behind the throttle cable. Looks like it goes down in a loop instead of straight across the top.
  17. Oct 15, 2020 at 2:03 PM
    Jbogstaco
    Jeremy
    I have it in the top bracket only all the others are out, if not I don’t have room to go across the top of the charger . Any suggestions on what you guys did ?
