5VZFE Turbo
Discussion in '1st Gen. Tacomas (1995-2004)' started by DrabT100, Mar 13, 2022.
  1. Jul 31, 2022 at 5:55 AM
    #141
    DrabT100
    DrabT100 [OP] Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    Looks like my trigger issues have been solved. Redline no problem.
  2. Jul 31, 2022 at 8:27 AM
    #142
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    Nice!
    Do you have a manual or Automatic Transmission?
  3. Jul 31, 2022 at 9:04 AM
    #143
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    Manual
  4. Jul 31, 2022 at 5:05 PM
    #144
    lm546
    lm546 Well-Known Member
    Craig
    Tucson, AZ
    2015 dcsb OR, 2002 double cab, 1985 Toyota pickup
    Do you think the splices could have been the issue the whole time and you didn’t need to replace the crank sensor?
    Speedytech7 likes this.
  5. Jul 31, 2022 at 5:19 PM
    #145
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I suspect there is that possibility.
  6. Aug 1, 2022 at 1:08 AM
    #146
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    Hard to say. Maybe a combination of everything. I will say that it seemed ok with ESP after changing just the sensor, but still had issues with NSP
  7. Aug 2, 2022 at 7:07 AM
    #147
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    Does anyone have a part number for a OEM 170° thermostat? Edit: found one
  8. Aug 2, 2022 at 7:51 AM
    #148
    1997tacomav6
    Denver
    This is the one I use the Corolla 170
    DrabT100[QUOTED][OP] likes this.
  9. Aug 2, 2022 at 9:36 AM
    #149
    Digiratus
    Roaming the PNW
    The RedHead
  10. Aug 9, 2022 at 1:21 PM
    #150
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    Its hotter than hell here on the East Coast, so I haven’t been doing much in the way of tuning. I had to replace my valve cover gaskets yesterday due to the tube seals leaking. I advanced the injector firing angles today by 5% and the off-idle response is much better. Idle is hunting a bit so I may have to tune that some more. Question: does anyone have any tips for A/C idle up? I have the A/C enabled but I may not have it wired correctly. Toyota is very vague on what the A/C amplifier actually is telling the stock ecu
  11. Aug 9, 2022 at 1:39 PM
    #151
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Not 100% sure what you're looking at when you say "A/C idle up" but stock increases by about 400-500 RPM by opening the IAC valve more and fuel follows via MAF when the AC clutch engages
    Also I believe technically you have it backwards, as the ECU tells the amplifier when to engage the clutch. (Note this is from a 4runner so might be little different):
  12. Aug 9, 2022 at 2:42 PM
    #152
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    My understanding is this:
    AC1 is a request signal sent from the amplifier to the ECU whenever the amplifier wants to cycle the compressor ON, i.e. A/C button is pressed, defroster turned on, etc.
    ACT is a “go” signal from the ECU to the amplifier, in addition the ECU raises the idle to compensate for the additional load from the compressor. The ECU will not send the go signal if the engine is not running or at wide open throttle.
    So I must have it wired to the standalone correctly or it would not work at all. Only thing is, the idle does not raise to compensate and the engine idles very low or stalls.
  13. Aug 9, 2022 at 3:09 PM
    #153
    treyus30
    Trey
    Mesa / AJ, AZ
    Well ya I would assume since you have a standalone you would need a trigger programmed to open the IAC more.
    All the "amplifier" in the circuit above is doing is most likely just a digital input into a transistor that pulls up or down MGC, so you probably have that part taken care of as long as you have control of the clutch relay.
    As for how you program said trigger, someone else will have to weigh in.
    1997tacomav6 likes this.
  14. Aug 10, 2022 at 8:16 PM
    #154
    Digiratus
    Roaming the PNW
    The RedHead
    There is no doubt that the base tune leaves a lot to be desired.
  15. Aug 13, 2022 at 3:03 PM
    #155
    1997tacomav6
    Denver
    Gabe Salazar is finishing up turning Skyler turbo 3.4,
    Stock motor with ARP studs just pushed
    413 and 489 torque at 17 pounds of boost with the haltech on the dyno, very impressive
    treyus30 and Jon64l like this.
  16. Aug 14, 2022 at 2:05 PM
    #156
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    And the engine is now blown up
  17. Aug 14, 2022 at 2:43 PM
    #157
    garetcurry
    garetcurry Well-Known Member
    Really?
  18. Aug 14, 2022 at 3:21 PM
    #158
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
  19. Aug 14, 2022 at 3:23 PM
    #159
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    Definitely blew it up
  20. Aug 14, 2022 at 3:24 PM
    #160
    garetcurry
    Oh the humanity!
