5VZFE V6 or 2UZFE V8
Discussion in '1st Gen. Tacomas (1995-2004)' started by low boy, Jan 26, 2013.
5VZFE V6 or 2UZFE V8 in my 01 TRD SR5 Tacoma
Poll closed Feb 25, 2013.
  1. 5VZFE V6
    8 vote(s)
    30.8%
  2. 2UZFE V8
    18 vote(s)
    69.2%
  1. Jan 26, 2013 at 11:02 AM
    low boy
    low boy [OP] 4wd Toyota Enthusiast
    Maryland
    2001 Tacoma TRD Xtra-cab
    lift, tires, wheels, some interior stuff
    ok so i threw a rod into my oil pan yesterday at 105k in my 2001 TRD SR5 Tacoma... i need a new engine so i'm thinking why not drop in a Tundra V8, then Supercharge it.
    so my question is this what do you think?
    5VZFE or 2UZFE
    also would that even fit?
  2. Jan 26, 2013 at 11:15 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Anything is possible.
  3. Jan 26, 2013 at 11:17 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    im gonna guess it wont fit without serious modification. Also heard the Tundra engines are considerably taller. If i was doing a v-8 swap i would find an LS motor.
  4. Jan 26, 2013 at 10:54 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Screw the 2uz
    week rods.
    go with a 4.0 1uzfe. There are more of them around and cheaper to buy.
    or get the newer 4.3L 3uzfe. This is sweet little motor. Lots of power and decant mpgs. Plus the intake manifold is the same as 2uzfe...meaning you can still put the TRD SC on it if you want..
  5. Jan 27, 2013 at 9:11 AM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    Plan on a lot of work. If your gonna do it.... Do it right. I'm currently working my heads so I can get every ounce of power out of it. With maintaining reliability.
  6. Jan 27, 2013 at 12:22 PM
    AggiePilot12
    AggiePilot12 Well-Known Member
    Texas
    03 4x4 6" Double Cab
    6" Fabtech, All-Pro Leafs, Cold Air, Cat Delete
    "accidentally" threw a rod into your oil pan, eh? OH Darn.. haha kidding.
    Heard of a guy who did the Lexus 4.7 swap (can't remember where I saw his build thread) and with custom motor mounts, made it fit just fine. The power from a Tundy engine on a 1st gen Taco would be oh so sweet.. and you want to supercharge it?
    You've got some jealous dudes who want you to keep us posted man. Good luck!
  7. Jan 27, 2013 at 7:10 PM
    Bullfrog
    Bullfrog "I think I know more than I do."
    McLaren
    North Bend
    98 V6 4x Limited Ugly Canadian Green.
    Accessory Box with CB attached. Alpine Type S front and back. LineX. Bedline SKidplates. In progress: Bilstein 5100s with BFG mudterrains 33x10.5 A/C compressor to Onboard Air compressor mod.
    4.0 Lexus v8?
    Small enough to fit. It's a v8 so with mods lots of potential power.
  8. Jan 27, 2013 at 7:13 PM
    Hambone155
    omaha
    That's the 1uzfe if I'm correct. In gs300's
  9. Jan 27, 2013 at 7:14 PM
    Bullfrog
    McLaren
    North Bend
    I thought it was older Lx but I could easily be wrong
  10. Jan 27, 2013 at 7:16 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    1uszfe is the 4.0l
    2uszfe is 4.7l
    3uzfe is 4.3l
    id do the 3uzfe. Better motor. Can still SC it with the 2uzs SC and better mpgs and more power.
  11. Jan 27, 2013 at 7:52 PM
    Bullfrog
    McLaren
    North Bend
    How about dropping in a diesel?
  12. Jan 27, 2013 at 7:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    4 cylinder turbo diesel swap can be done. Very expensive though.
    few companies out there swap in Hilux diesels for like 14-22k
  13. Jan 27, 2013 at 7:59 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    if i were gonna swap in a v8 id do a 1uz but thats just me :D
  14. Jan 27, 2013 at 8:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea id do a 1uz or 3uz over the 2uz.
    turbo the 1uz :cool: some supra guys used to do that
  15. Jan 27, 2013 at 8:10 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Be carefull with a stronger engine - make sure the transmission, diff etc. can handle the extra power. I looked at a Hilux back in South Africa that had a Rover V8 in it. It was sweet and I almost bought it, but another dealer warned me about it - he knew the truck and so did most dealers in town - it had gone through 5 transmissions already at the time.
  16. Jan 27, 2013 at 8:14 PM
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    Diffs should be fine, the rear axle on tacomas are the same as the tundras, not sure about the front diff.
  17. Jan 27, 2013 at 8:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    tranny will be fine too. Guys turbo our motors and get over 350hp with no issues.
  18. Jan 27, 2013 at 8:21 PM
    Mattsplat72
    Mattsplat72 Member
    Sedro Woolley Wa
    06 PreRunner TRD Sport
    None at this time
    Gs300 is a 2j
    Sc400,gs400,ls400 are 1uz
  19. Jan 27, 2013 at 8:24 PM
    Mattsplat72
    Mattsplat72 Member
    Sedro Woolley Wa
    None at this time
    Btw a supercharged 1uz vvti would be rad. Or an Aristo 2jzgte
  20. Jan 27, 2013 at 8:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    seen 2jgte done. Pretty sick.
    i don't think they made a SC for the 1uzfe.
