5W-20 instead of 0W-20?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Driver57, Dec 28, 2024.
  1. Dec 28, 2024 at 2:01 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Ya in the 60's and 70's with old v8's that were running poorly but only like 1/2 pint and as a last resort.
  2. Dec 28, 2024 at 2:06 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Dec 28, 2024 at 2:08 PM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    0/20 and 5/20 are the same weight hot. only difference is cold. I'd think most people with common sense would beat the hell out of their shit until it warmed up.
  4. Dec 28, 2024 at 2:55 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Costco has a sale on Mobil 1 through 1/20/2025 if anyone is interested.
  5. Dec 28, 2024 at 3:12 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Damn I paid $55 for 6 qts last week
    Steves104x4 likes this.
  6. Dec 28, 2024 at 3:18 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    Hypertrophy
    That's how you get a muscle car.
  7. Dec 28, 2024 at 3:28 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... My buddy was the supervisor at a fire truck company and had a Honda Civic a long time ago.
    I remember him adding transmission fluid (to his oil) from the shop to his Honda when he was up at St James Bay Power Station, servicing their fire trucks.
    I also remember me getting into his new Civic and it was -25C or lower and the vinyl seat splitting when I sat down. :eek:
    UL (Underwriter's Lab) would also add it to the BMW portable pumps when they tested them at -25C and lower.
    All pumps for fire fighting (truck mounted and portable) had to be UL approved.
    Not a wive's tail, I can assure you. I lived up there and worked out of there for a long time also.
    PS Coldest I can remember up there was about -44 ... and -40C & -40F are the same.
    I miss the Shepard's pie in PQ in the winter and the French fries with cheese and gravy. lol
    shakerhood and Steves104x4 like this.
  8. Dec 28, 2024 at 5:51 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    shakerhood, helix66 and Steves104x4 like this.
  9. Dec 28, 2024 at 9:17 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    helix66 likes this.
  10. Dec 29, 2024 at 8:43 AM
    waffleiron
    waffleiron Well-Known Member
    Washington
    Thin oil viscosities are used in modern engines due to variable valve timing systems.
    If youve ever dissemabled one, youd see super fine oil jets that pressurize a pin against a spring. As the oil pressurizes and releases that little pin the unit is allowing your adjustable cam gear to rotate your valve train.
    When thicker viscosity is used it will cause more pressure and less flow (ya know, that Bernoulli shit) and will prematurely wear this spring down.
    When the spring gets shot (due to the increased pressure, cause physics is real) it will slap that bitch ass pin straight in and cause your cam gear to rotate on start up and it creates this rattle noise (it rotates back and fourth cause its not locked down by the pin anymore) once the vehicle is warmed up it becomes irrelevant as your oil pressure stabilizes and the valvetrain does its song and dance as normal.
    Its neither a good thing or a bad thing, its just a noise that happens quite often in variable timing systems. I hear it from time to time in other peoples cars that have variable systems, which most modern vehicles do even more so today where its both the intake and exhaust side.
    But hey listen, this is just like my opinion and shit.
    Edit: bonus if you take a shot every time I wrote variable
  11. Dec 31, 2024 at 9:49 AM
    abodyjoe
    joe
    its 31 bucks at my local costco..
    TA2016[QUOTED] likes this.
  12. Mar 26, 2025 at 6:58 PM
    SOSHeloPilot
    2024 4Runner SR5
    Much wisdom here Grasshopper ... :thumbsup:
    NickAdams2112 and Inyo_man like this.
  13. Mar 28, 2025 at 3:13 PM
    bbal
    bbal Well-Known Member
    Seems like it’s pretty easy just to do what the manufacturer calls for. Especially since if you run into trouble they will likely try to deny a warranty claim for any reason they can find which seems to be standard procedure
  14. Mar 28, 2025 at 3:35 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    I've seen it referenced here, the mexican FSM has a table for pil weights based on temps and use, 0w20 to like 15w40 are acceptable. 0w20 is likely rated for maximum fuel economy. I've run 5w30 since my first oil change. If I were towing I'd run heavier viscosity.
    sarcastictechsupport likes this.
  15. Mar 28, 2025 at 3:47 PM
    #35
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    I mix 50/50 0W-20 and 5W-20 to get 2.5W-20. Best of both worlds.
  16. Mar 28, 2025 at 5:07 PM
    #36
    canuck guy
    Alberta
    23TRDOR
    I mix rum and cola
    Tacosha, Delta09 and DoubleB like this.
  17. Mar 28, 2025 at 5:07 PM
    #37
    dryheat
    dryheat Well-Known Member
    Do you have a PDF of the manual? I've heard it spoken about but never seen it. Does it actually exist?
  18. Mar 28, 2025 at 5:09 PM
    #38
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    This all depends on climate and elevation …. I just stick with the recommended oil … has a wider temperature range .
    Tacosha likes this.
  19. Mar 28, 2025 at 5:10 PM
    #39
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    it is written in Spanish in the Mexican owner’s manual with a temperature chart. In the FSM (not country specific) it lists 0W-20 ILSAC and 15W-40. If it lists 15W-40 then obviously anything in between is also fine. I can post proof later but I’m on my phone now and it’s too tedious.
    I run 40 grade because I like the idea of protection against overheating. If for some reason you overheated, the oil still has margin left to get warmer before thinning out too much. You barely have that margin on 20 grade when you’re already warmed up.
  20. Mar 28, 2025 at 5:25 PM
    #40
    dryheat
    I've considered doing this. Being in Phoenix with 118 degree summers I couldn't care less what the EPA wants I just want maximum engine protection.
    Phlogiston and Toy_Runner like this.
