5W-20 instead of 0W-20?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Driver57, Dec 28, 2024.
  1. Mar 29, 2025 at 9:06 PM
    #61
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    The real question, is the 2GR quieter using 5W-30?
  2. Mar 29, 2025 at 9:28 PM
    #62
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I haven’t run 5w-30, but mine is quieter on 10W-40 than 0W-20 and 10W-30. No incessant lifter tapping/collapsing so far on 10W-40.
  3. Mar 29, 2025 at 9:35 PM
    #63
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Any MPG hit going to 10W-40?
  4. Mar 29, 2025 at 9:40 PM
    #64
    BLtheP
    Plano, TX
    None detected. I’ve only been on it a few thousand miles, I was on 10W-30 from 7K to 65K. At 68K now. Ironically I’m getting better mileage now than I have in a long time, but it isn’t the thicker oil doing that.
    Texas-Gorilla likes this.
  5. Mar 29, 2025 at 10:03 PM
    #65
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    I think this is all the info I needed to hear lol. Thanks!
    BLtheP[QUOTED] likes this.
  6. Mar 30, 2025 at 5:03 AM
    #66
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Never noticed it any quieter on the two that I had using 5w30. Most of the noise is from the injectors and high pressure fuel pump.
    Toy_Runner likes this.
  7. May 8, 2025 at 1:04 PM
    #67
    SimonSaysBoo
    SimonSaysBoo Member
    Tacoma 2.7
    Induction, Ceramics, Wrangler Kevlar, Shell VP
    Used to work in fuels and oils etc etc...
    Firstly - When new (up to 50k) I would always stick to the grade on the oil cap.
    Secondly - The car companies are obsessed with manipulating MPG figures and 0w20, 0w16 etc does that. There is no secret that these lighter grades give increased mileage but at an ever, ever so slight wear cost.
    Third - The new engines require a harder working, higher quality oil, that often leans towards a lower viscosity, for VVT and VVI etc
    Fourth - Consider your operating climate / conditions.
    The Standard to meet warranty in the Tacoma 2.7 4 is ILSAC GF-6A. As well as Mobil 1 0w20, that is found in the Mobil 1 0w30 Advanced Fuel Economy for example... (why use any other brand - just saying).
    ILSAC GF-6A is NOT found in the Mobil 1 0w30 ESP. High quality oil specifications will cross over between grades.
    Also the owners manual uses the wording 'recommends' not 'must do'
    In hot environments and high speed and high workload I would recommend going up a viscosity level. 0w30 meets those requirements for warranty and added protection in heat and high workload.
    0w30 is generally considered to be used where ambient air temperature is 36c / 97f. So if you live in these climates then why not give yourself the protection ?
    In Summary Mobil 1 0w20 and 0w30 Advanced Fuel Economy (Any probably other brands you can research) have the required ILSAC GF-6A which is the only engine oil specification requirement mentioned in the Toyota manual.
    Therefore being May in the South, currently using Mobil 1 0w30 AFE in my Tacoma 2.7 , If I lived further North (and in Winter) I would put 0w20 in.
    Hope that helps.
    Toy_Runner and NAAC3TACO like this.
