5w-20 VS 5w-30
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dutd33, May 22, 2023.
  1. May 24, 2023 at 2:32 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    In 2010, I asked what oil the dealership used. They said, Kendall.
    That doesn’t mean Kendall makes their oil. It’s just what the dealership was using at the time.
    DeepFriedTaco[QUOTED] likes this.
  2. May 24, 2023 at 4:43 PM
    Hoff
    Hoff Well-Known Member
    Probably whoever is the lowest bidder.
  3. May 24, 2023 at 6:53 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Who knows, it could be multiple suppliers. Typically with oil (or any other part or lubricant) the manufacturer will lay out the minimum specifications it needs to meet and whichever companies can make it the cheapest at those specifications gets the contract.
  4. May 25, 2023 at 5:49 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    No, a higher viscosity oil will not make your engine work "harder" maybe straight weight oil WAY above the recommended would but by then you would have other issues..blown seals, plugged passages etc...note that it is the "recommended" viscosity of oil and not the MANDATORY viscosity. They recommend that weight based off their engineering specifications, but its not an all or nothing standard. Nothing will happen any different, the engine will not work any harder with 5w-30 than 5w-20...and yes I am a petoleum engineer. well used to be, now Im just an old grumpy person that yells at the squirrels for eating out of my bird feeders...
  5. May 26, 2023 at 12:08 PM
    DeepFriedTaco
    DeepFriedTaco Well-Known Member
    Teddy the Taco
    2021 MT OR Taco
    Ok so I just did my first do it yourself oil change, not so hard I did drop my drain plug in the oil which led me to believe the washer fell too especially since nothing came off as I scratched with my finger but now the jobs done and I think there are 2 washers.
    How bad is this? Do I need to run out get new oil and washer and redo? Nothing seems to be leaking.
  6. May 26, 2023 at 12:21 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    The internal engine temp in both scenarios would be almost the same...your comment is not even remotely correct.
  7. May 26, 2023 at 12:24 PM
    fourfourone
    General internal bearing tolerances have been the same for years and years. A 30 year old 22RE Toyota motor has almost identical bearing tolerance specs to a new Tacoma 3.5 that calls for 0w20/5w20.
  8. May 26, 2023 at 12:31 PM
    fourfourone
    Engine speed/RPM is what increases oil temp. Not the actual load on the engine. "Highway" trucks have gobs of low end torque and operate at much lower RPMs in general. A big truck like that typically shouldn't see a spike in oil temps and those truck don't need to down shit much once up to speed due to all the torque they have. This is why they last 500k+ miles without needed a rebuild.
  9. May 26, 2023 at 1:14 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Is this an oil thread? By golly I think it is an oil thread. I just love oil threads. You can never have too many oil threads.I learn so much from them. :rofl::rofl::rofl:
    MSgt O and TnShooter like this.
  10. May 26, 2023 at 1:18 PM
    TnShooter
    Deogee
    STOCK
    Some of the finest entertainment on TW.:)
    Sprig[QUOTED] likes this.
  11. May 26, 2023 at 1:19 PM
    fourfourone
    oil threads are where most of the "pulled out of my ass" comments are used.
    Sprig likes this.
  12. May 26, 2023 at 1:24 PM
    TacoTuesday1
    SD CA
    I’ve done half and half many times
    0w20
    5w30
    Half and half in a jug
    shake it up, pour it in
    engine mixes it too
    that’s kind of how they make oil at the factory.
    engine works. Looks brand new inside when I took the valve covers off at high miles. Clean metal. Not varnish yellow stained metal which is what Mobil 1 is known to do.
    really whatever I have on the shelf. If I’ve got some good quality 0w40, then that’s what I’m pouring in.
  13. May 26, 2023 at 2:31 PM
    TnShooter
    Deogee
    STOCK
    I don’t know much about oil.
    But it can’t be as complicated as some make it out to be.
    Sprig likes this.
  14. May 26, 2023 at 2:39 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Has the word "oilphile" been coined yet? You heard it first on TW!
    Reading the oil threads are similar to reading audiophile threads.
    MSgt O and Sprig like this.
  15. Jun 8, 2023 at 6:12 PM
    #35
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    so many oil threads.
    i don't know where to leave this...don't want to start a thread for it...or if it has already been posted. if meaningful it will get around i think.
    Mobil 1 rebate program is on for 2023.
    even though walmart is not in "terms and conditions" list, the online submission form accepts walmart and mobil 1 cust svc confirmed you
    can buy at walmart. I just submitted for $20 rebate. my previous years account was convenient to get right to it.
    https://mobilpromotions.us/rebate/terms.asp
