5w20 or 5w30
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JACKEL142, Aug 13, 2009.
  1. Aug 13, 2009 at 1:39 PM
    JACKEL142
    JACKEL142 [OP] Well-Known Member
    Nashville
    2009 Sport LB 4x4 Speedway
    I've heard conflicting stories on what the best weight oil to run (Mobil 1 of course).
    5.5 qts?
  2. Aug 13, 2009 at 1:42 PM
    dougmays
    dougmays Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    i use 5w30 but thats mainly because of the manual recommendation and from people on here. i'd like to hear more about this though if i should be using 20 instead. I run 5.5 qts and Penziol Platnum (full synthetic)
  3. Aug 13, 2009 at 1:42 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Its says the weight on the oil filler cap. Its 5w30. I also use Mobil 1
  4. Aug 13, 2009 at 1:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you have the v6 or the 4banger?
  5. Aug 13, 2009 at 1:47 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    I switched from 10W/30 Castro GTX to 5W/30 Castrol SYNTEC just because I got 113K on '97.
  6. Aug 13, 2009 at 1:53 PM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    V6 uses 5w-30 API SM. 4cyl uses 5w-20 API SM. You could probably get away with using the thinner oil as long as you don't tow and understand if you throw a rod toyota may not cover it. The only advantage would be a slight, I mean slight % of MPG gain. Be fun to try for a few tanks in the cty and hwy. just for MPG sake. Be a great project for a magazine to do. I run 5w-30 Quaker State Dino $10.50/5qts, or Mobil Clean 5k $11/5qts with a Motorcraft FL400S filter. That filter's design is first class compare to others. Both oils I listed are great, and will make the engine outlast the truck.
  7. Aug 13, 2009 at 2:03 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    +1. I'll just add that you can run 0w30 synthetic in the v6, but it usually costs more and the only benefit is better start up protection on very cold mornings. Something to look into, but you will be fine with 5w30 synthetic. The 2.7 owners like myself can run 0w20 or 5w20. I've been running 5w20 Mobile 1 with a K&N oil filter and I change it every 6 months.
