5w20 used instead of 5w30 - now have front main seal or oil pan leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brewdog, Oct 25, 2015.
  1. Oct 25, 2015 at 4:34 PM
    brewdog
    brewdog [OP] New Member
    Bozeman, MT
    '10 Tacoma DC TRD OffRoad 4X4
    Shop used 5w20 oil instead of 5w30 at last oil change on my 2010 4.0L V6 and now 4000 miles later it seams I have an oil leak coming from either my front main seal or oil pan. I have never had a problem with this truck and not sure if it's just in my head or if the seals are breaking down and causing the leak.
    Thoughts?
  2. Oct 25, 2015 at 4:43 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Highly unlikely the oil caused the leak. I'd consider that a coincidence.... IMHO
    Rock Lobster and DouginNC like this.
  3. Oct 25, 2015 at 5:19 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    This^^^
  4. Oct 25, 2015 at 7:03 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Clean it all up and verify that it isn't the notorious timing cover leak at the top of the passenger side front of the engine.
    DoorDing likes this.
  5. Oct 25, 2015 at 7:12 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Probably not the oils fault from just one fill-up. But why are you not using 5w30 oil? Your oil choice seems a little out of spec to me.
  6. Oct 25, 2015 at 7:28 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Read the post again. He said shop used 5w20 instead of 5w30. Think he intended for them to install 5w30.
  7. Oct 25, 2015 at 7:30 PM
    mountainwolfpup
    Vancouver, WA
    Thanks holeshot, I missed that part. Yea, if you regularly run 5w30 then you're fine. New or used doesn't really matter.
    Sounds like one of those "coincidences".
  8. Oct 25, 2015 at 7:37 PM
    Holeshot
    Gary
    Alabama
    Had the same thing happen on my 2015 at the first "free" oil change at the dealer. Got home and looked closer at my service ticket and saw 5w20 installed. Took truck back to dealer and they immediately moved my truck to front of service line and changed to 5w30 while I watched to see it done correctly.
    Glad I reviewed my service ticket or invoice and spotted error right away.
  9. Oct 25, 2015 at 7:43 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The oil wouldn't have caused the leak. It may be that the gasket or seal was already compromised, and by using a slightly thinner oil it started to seap through under hot engine conditions.
    You could try and clean the area and change the oil back to the regular 5-30 and see if it stops. Of course it will start to leak again at some point as the gasket or seal gets worse, or just continue to leak with a heavier weight oil.
