6” Lift Kits
Discussion in '3rd Gen. Tacomas (2016-2023)' started by west36, Apr 9, 2021.
  1. Apr 9, 2021 at 7:49 AM
    west36
    west36 [OP] Active Member
    Austin
    2021 Black Toyota Tacoma
    It’s time after a lot of research i’ve got a lot figured out of what I want but still got a few questions. I am going with the 20x10 -18 Fuel Runner wheels in chrome. BDS 6” lift is what i’m going with as I hate rough country and the ready lift kit seems okay but I figured it’s just best to spend more money and get BDS. Tire size is the only thing I have questions about I was gonna just get 33s but people have been saying they fit 35s on a 6” lift with no trimming or rubbing at all? I find that very hard to believe especially without replacing upper control arms but most of the aftermarkets are even beefier. Just looking for some thoughts and opinions even on the lift just curious what you guys have went with.
  2. Apr 9, 2021 at 8:02 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    Are you 2wd?
  3. Apr 9, 2021 at 8:04 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  4. Apr 9, 2021 at 3:28 PM
    west36
    Austin
  5. Apr 9, 2021 at 3:40 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You're aware that you will have to cut out a section of frame crossmember in order to install the lift? Nothing wrong with the lift if you want the looks of the 6" lift over the superior performance a similarly priced 3" kit and are ok with chopping the frame.
  6. Apr 9, 2021 at 3:52 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Guy said he's getting 20x10's...obviously gives zero fudges about performance.
    Mark77, Rainoffire, Key-Rei and 7 others like this.
  7. Apr 9, 2021 at 9:53 PM
    west36
    Austin
    I don’t off-road much and have a beater to do that in I just want a nice looking truck bds lift with fox shocks and coil overs and i’m sure it will ride just fine
    ToyoTaco25, boston23 and bulalo like this.
  8. Apr 9, 2021 at 10:00 PM
    Car Ram-Rod
    Car Ram-Rod Well-Known Member
    I have friends on 35s but they have the lift cranked up to 7”+ so it’s hard to say if 35s would rub on a 6” lift only but most likely minimal plastic trimming would be necessary. You’ll also want to regear with 35s if you have good size hills where you live. Trust me.
  9. Apr 9, 2021 at 10:02 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    And it will look like baaaaaad a$. Plan on doing supercharger or just regearing. Post pics or do a build thread. Build thread is better.
    ToyoTaco25 likes this.
  10. Apr 9, 2021 at 10:07 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Not a lot of DB lift fans here, so I havent seen many folks with them but my guess is you’d at least have to do a little trimming to fit 35’s
  11. Apr 9, 2021 at 10:19 PM
    Losv
    Losv Active Member
    2019 Tacoma TRD Off Road 4x4
    I am on that lift. I'm on 35s 20x12 -44 and have had to do extensive cutting. Since you are going 20x10 I would say you would have to do a little cutting. Rides great and stands out from all others.
    bulalo likes this.
  12. Apr 9, 2021 at 10:26 PM
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    20’s are for beginners, take it up a notch...
    Mark77 and boston23 like this.
  13. Apr 9, 2021 at 10:34 PM
    Car Ram-Rod
    Down here in Hawaii it’s automatic straight to 22x14s with 33x12.5s. Stretched. Lol
    Aqualoon likes this.
  14. Apr 10, 2021 at 4:22 AM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    rocco408, JoshS, Tnc and 5 others like this.
  15. Apr 10, 2021 at 9:40 AM
    west36
    Austin
    I am thinking about regearing atleast i’ll have to see how much power I lose from the bigger tires. Thinking about trying 20x12s with -44 and 33s. 35s I know i’ll probably have to chop especially if I do -44 gonna check some more builds and make sure before I go wider.
    bulalo[QUOTED] likes this.
  16. Apr 10, 2021 at 11:09 AM
    Car Ram-Rod
    Agreed. Lol I get teased for having 17” wheels on my 7” lift... by people who have taken their 22x14s back to the tire shop 9 times because they can’t figure out the vibration. Lol seriously. I’ve got a friend.
  17. Apr 11, 2021 at 12:48 AM
    Taco_Kev808
    Taco_Kev808 Instagram: Rillo_kev
    Kevin
    Washington
    2016 MGM DCLB Limited
    I had a 6" lift on my tacoma with 35s, cmc, and front bumper slightly trimmed. It rode like crap and the ball joints prematurely wore out. Got rid of it after only 15k miles on the truck. I'm sure if you don't mind cutting the crossmember you can do a cmc. And keep the piece you cut from crossmember incase you want to go back. Ask me how i know...
  18. Apr 11, 2021 at 1:52 AM
    TacoMAUI95
    TacoMAUI95 Well-Known Member
    Maui,HI
    17DCLB TRDOR MGM. Replaced 2014 DCSB TRDOR
    Nothing yet. Old truck had the works.
    I have a 6 inch bds without coilovers. 35x12.5x18 nittos.
    Cab mount chopped. Alot of trimming. I beat pinch weld. Turning and full stuff offroad my flares have ripped off and it bent the body slightly. Also the wide tires will violently rub on your sway bar when you reverse. Its BAD haha.
    Recently i have a really weird whooshing squeak that might be the ball joints like the above poster. I need to find out.
    It makes other odd sounds haha.
    If i had to do it over again im torn. The 6 inch looks way better on the longbed. And it gives me more clearance offroad. Which i need. But the tradeoffs arent great. And for the price my ride is absolutely crap compared to my old icons on my 2nd gen.
  19. Apr 11, 2021 at 2:25 AM
    erok81
    erok81 Well-Known Member
    Imposter
    So let’s see.
    3” kit requires cutting and trimming
    6” kit requires even more cutting and trimming.
    Why not just use a 3” kit and cut less? Unless you like the 6” look of course.
  20. Apr 11, 2021 at 3:56 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Bigger for surewhistlindiesel-1612166616362.jpg message-editor_1612208557696-hellcatbuggywheelburnout.jpg maxresdefault.jpg Duramax-Wagon-Wheel-You-Tube-Whistlin-Diesel.jpg SmartSelect_20210411-065315_Chrome.jpg
    TrdTaco171991 likes this.
