6" & 35"
Discussion in 'Suspension' started by areghas, Apr 21, 2012.
  1. Apr 21, 2012 at 10:16 PM
    areghas
    areghas [OP] Active Member
    Cannon AFB
    6in ProComp lift, 33" tires.
    I've got a 6" ProComp Lift with 315/70 on 17s witha 1.5" spacer and get rub on the body mount bracket. (worse on the driver side than passenger side) My tires already stick out 2" past the fender (which I don't mind).
    What B/S and O/S on your rims do you guys have that are running 35x12.5s with 6" kits?
    Do I HAVE to trim the bracket to make this work or is it as simple as changing my rims?
    If the bracket has to be trimmed I can do that, but welding is an issue if it needs to be boxed.
    All Info Appreciated!!!
  2. Apr 21, 2012 at 10:26 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    are the specs on the 17x9 rim 4.5 bs with -12mm offset?
    NVM forgot the mention of the wheel spacer. Just do a body mount chop, no harm done :)
  3. Apr 22, 2012 at 1:16 AM
    areghas
    Cannon AFB
    it wont cause any long term damage or degrade the structual integrity right? I'm pretty sure I can jsut cut away the body mount where it is rubbing and cover it with paint to prevent rust, i think.
  4. Apr 22, 2012 at 1:25 AM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    Cab mount chop
  5. Apr 22, 2012 at 2:37 AM
    areghas
    Cannon AFB
    Could anyone provide pictures? or instructions on this?
  6. Apr 22, 2012 at 2:43 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD SR5 Sport 4X4
    LED lights inside and out,weathertech floor covers/window visors,17" Konig countersteer, 285/65 Nitto Trail Grapplers, Lifted, debadged,Satoshi. 10 disc cd changer. scanguage II. black tail lights, black headlights w/ retro murimotos. wet okoles up front. URD SS, and throw out bearing. USA Spec iPod adapter. OME full lift kit w/ Dakars. ATO shackle flip. Light Racing UCA's. Flyzeye V2W.
    It's real easy. I never even took the wheels off the truck, and did most of it with a sawzall. cleaned it up with an angle grinder. Just waiting to weld on new plates. "Search" bar for instructions. Now you get the idea?
