6.5" subwoofers in the back doors
Discussion in 'Audio & Video' started by tmbrwlf730, Jul 15, 2010.
  1. Jul 15, 2010 at 5:46 PM
    tmbrwlf730
    tmbrwlf730 [OP] Well-Known Member
    el paso, tx
    2006 SR5 Double Cab Long Bed
    added oem skid plate, oem tow hook, avid offroad side steps
    do you need to modify the back doors of a double cab inorder to put some jl 6w3v3 subwoofers in em?
  2. Jul 24, 2010 at 3:18 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Kings Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector/Dual Halo Headlights by Ambiguous - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Procomp Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    TW,
    Without measuring, I would say it might be possible. Realize that this is speculation because I have not measured the depth since my install. I am sure that you have investigated the matter already, but here is what I think would need to be done.
    Here are some concerns. To allow for the almost 9mm of excursion you might have to use thinner baffles so the speaker will not hit the interior of the door panel. This will reduce your mouting depth. You will need to build an enclosure that fits into the door to obtain the 0.15 cu/ft you need for the sub. You will have to seal and deaden the hell out of the doors. If by chance you take on this task and succeed, I would be very eager to try it myself. If you decide against it, hell, I might try it anyways.
    Good luck,
    -G
