6" Coilovers with 4" RCD Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MDBigRed, Nov 19, 2009.
  1. Nov 19, 2009 at 7:16 PM
    MDBigRed
    MDBigRed [OP] Well-Known Member
    Potomac, MD
    '08 TRD Sport 4x4
    Uniden PC78Elite CB, 4' Firestiks, KC reverse/work lights, Mudflaps removed, Gorilla wheel locks, TRD box air intake, MBRP XP series dual exhaust, Wet Okole seat covers, 20% front tints, Pacer tailgate light bar, Uniden Bear Cat PA external speaker, 4.5" RCD Lift w/ extended ICON coilovers, door sill LED running lights, LED alarm scanner light, Scangauge II, Blendmount, Diff breather mod, Whelen hideaway 90watt strobes, Piaa Xtreme white bulbs, VIAIR onboard air, Allpro T-case sheild, TC LCA Skids, Stubbswelding HD-SKO Sliders, Weathertech floor mats, TC UCA's, Allpro SS brakelines, rear ARB locker, 4.56 Yukon gears, BlueSea fuse block, bed rail light bar, Shrockworks bumper, Smittybuilt XRC8 Comp winch, IPF 900's, Piaa 510's, Tekonsha brake controller, Air horn, Pop 'n lock, Alcan Spring leaf packs, JVC KD-AHD 69 head unit, 12voltguy winch controller, Safari Snorkel
    Does anyone know if 6" coils would work with my 4" RCD drop bracket lift?? I don't see why it wouldn't, it's just like putting a 3" coilover on a stock front setup. I know the point of a DB is to keep "factory" like geometry, but i was thinking i could afford some more front diff ground clearance if i installed the 6" Procomp or Icon coilovers. I don't think the CV's will be any more angled than a regular 3" coilover would on many of the trucks on the forum. Thanks!
  2. Nov 20, 2009 at 7:38 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
  3. Nov 20, 2009 at 7:44 AM
    SilverSeven
    SilverSeven Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    hey man! dooo it! I definatly think it would work. The 6" DB lifts drop the bracket too far IMO. With the RCD bracket and 6" coils it will be like the guys with a 3" lift. you will have more diff clearance than a standard 6" db and it will just be sick. do it, take pix, get rep, live life
    holla
  4. Nov 20, 2009 at 7:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2 to what he said, but with 1 more holla And a zing zing!
  5. Nov 20, 2009 at 7:56 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    i say do it it has to work ...
  6. Nov 20, 2009 at 8:09 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
  7. Nov 20, 2009 at 8:20 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    SOLD!
    I've thought of this one before and couldn't foresee any issues with cranking up a pair on coil-overs on the 4" RCD. I say go for it, whats the worst that can happen?
    Be sure to take plenty of pictures for the rest of us when you're doing you install! :thumbsup:
  8. Nov 20, 2009 at 9:04 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    i thought about getting a set of 3inch coil overs and puting my spacer on it to get the lift
  9. Nov 20, 2009 at 9:06 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    hahahahhahahahahha!!!
  10. Nov 20, 2009 at 9:12 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    yep!! :goingcrazy: Do It!! you may have to look into some UCA's for correct alignment??
  11. Nov 21, 2009 at 5:11 AM
    MDBigRed
    Potomac, MD
    '08 TRD Sport 4x4
    I've been thinking about this for a while now!!! The only thing is in reality i'll probably wait a year or so...i drive this truck everyday, haul a big boat with it, and use it for my landscaping business. I was thinking 35's???? New UCA's would be a must:D Once this truck gets a little older and i find a second vehicle, then i say yes!!! new rear leaf pack as well and new gears
  12. Nov 21, 2009 at 5:16 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    I would like to add to what SilverSeven said:
    Snap!
  13. Nov 21, 2009 at 5:26 AM
    MDBigRed
    Potomac, MD
    '08 TRD Sport 4x4
    WOORRDDD!!!! btw would i use 6" or 3" coilovers??? i can talk to the guys at downsouth motorsports and see what they sayyy
  14. Nov 25, 2009 at 11:11 AM
    freedomriding
    freedomriding FREEDOMEDIA.US
    Nate
    Oahu, Hawaii
    2012 TRD Sport 4x4 DCLB
    RCD Suspension, 34x12.5R18 KO2, Method NV 18x9, AFE Intake, TRD Exhaust, Snugtop Shell
    Don't do it bro, then you'll be in the situation I'm in with my CV's being stressed and the ride being garbage
  15. Nov 25, 2009 at 11:21 AM
    freedomriding
    Nate
    Oahu, Hawaii
    I know we all want lift and bigger tires but reality is we are wearing out the components and giving ourselves a stiffer ride. The 6" lift's ride perfect, near factory, until adding additional lift. That pushes the LCA down which slams up & down worse when hitting bumps.
    This of course is just IMO.
    I just installed Fabtech basic 6", tried combing OME 885 coils/shocks and I have 8" w/a harsh ride. I'm replacing the 6" spacer w/Tuff Country 4.5" spacer ASAP because I wanna keep the OME solid ride & quality.
    Here's some pics:
  16. Nov 25, 2009 at 12:15 PM
    MDBigRed
    Potomac, MD
    '08 TRD Sport 4x4
    Thanks for the pics and the advice. I don't see how a 3" spacer would make the CV angles any worse than using it on a stock bracket. With a drop bracket and new spindles, the geometry is that of stock. can you show a pic of the drop bracket with LCA's??
  17. Nov 25, 2009 at 3:54 PM
    freedomriding
    Nate
    Oahu, Hawaii
    Thats what I thought to when was planning on my combination lift. With my original Toytec 3" I had the diff drop which helped decrease the angles. The 6" gives a minor angle, then add 3" more and we have major angle. Shoot pics in bit
  18. Nov 29, 2009 at 11:46 AM
    TexasIslandBoy
    Andrew
    South Texas. SPI
    i was thinking can you just set a king coilover to zero and then put my spacer on it to keep the 6inch lift
  19. Nov 29, 2009 at 11:57 PM
    freedomriding
    Nate
    Oahu, Hawaii
    Yes my lift is actually settling nice now with the OME coils & 6" spacer. The CV's are a still a little too angled but the ride is way better. You can crank the King coilover an inch or so w/the spacer. Should be good
  20. Nov 30, 2009 at 12:04 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    This is a bad ass 1st gen :eek:
