6 cyl or a super charger
Discussion in '1st Gen. Tacomas (1995-2004)' started by tarhead, May 29, 2013.
  1. May 29, 2013 at 4:31 PM
    tarhead
    tarhead [OP] New Member
    Utah
    02 Tacoma Pre Runner
    I have just made my final payment on my 2002 Taco and now will have some cash to put into it. It is a Pre Runner with a 4 banger and just does not have the power I need to get around the city or to tows up into the mountains.
    Would I be further ahead/cheaper by dropping a 6 cylinder in her or adding a super charger?
    Thanx in advance for your input
  2. May 29, 2013 at 4:33 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
  3. May 29, 2013 at 6:14 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    If you need more power just sell it and get what you want. Keep it and get a sports car. Regear it to better suit your needs. I have a double cab auto with 4.56 gears from the factory and its pretty peppy around town. I know it's a 4 cylinder and I don't expect it to be more than that!!
  4. May 29, 2013 at 7:42 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    No one supercharges the 4 cyl. I don't even think there is one.
    Turbo charge however.... that's another story, and many people have turbo charged the 4 cylinders and made good power (just as much or more power than supercharged 3.4 5vzs in fact). Search around customtacos.com for info.
  5. May 30, 2013 at 1:35 PM
    tarhead
    Utah
    "I know it's a 4 cylinder and I don't expect it to be more than that!!"
    Happy for you:)
    Thanks for the suggestions. It look like getting a 6 cylinder will work for what I need to tow. The mountains are very steep around here and the 4 cylinder just is not cutting it.
  6. May 31, 2013 at 8:41 PM
    PhdNPrerunners
    PhdNPrerunners Well-Known Member
    Justin
    The Woodlands, TX
    1999 4Runner SR5 4WD
    TRD used to make a supercharger for the 3rz but it hasn't been in production for a while.
  7. May 31, 2013 at 11:56 PM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
  8. Jun 1, 2013 at 12:01 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    If you're going through the trouble of a swap you may as well put a diesel or v8 or something better than the 5vz-fe. Maybe a supra motor. But that's just the kid in me talkin.
