#6 Cylinder Misfire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Athenstacoma06, May 9, 2021.
  1. May 9, 2021 at 10:48 PM
    Athenstacoma06
    Athenstacoma06 [OP] Member
    2006 Tacoma 4.0
    Number 6 cylinder misfire code on 2006 Tacoma 4.0.
    Started running very rough and activating check engine light.
    Took to the dealership and they replaced all plugs and reset CEL.
    Truck ran great for a day and same thing the next morning.
    Changed the coil packs and reset the light. Again, truck ran fine for a day or so.
    While cleaning the mass air flow sensor I noticed the coolant was a little low.
    I’m taking truck in this week. I think the head gasket is blown and leaking into the #6 cylinder.
    I’ve also been hearing a sound behind the dash like fluid sloshing around.
    Bought new in 2006 and has 306,000 miles on it. Oil always changed at Toyota.
    I’ll update as I find out more. Will definitely repair and keep driving. Just put on new tires and brakes all around.
    Will decide on doing the heads and valves vs engine replacement based on estimate.
    Jimmyh likes this.
  2. May 9, 2021 at 11:17 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Take your oil fill cap off and look at the backside of the cap. If you have a white creamy pudding back there, a head gasket is certainly going to be an issue.
  3. May 9, 2021 at 11:26 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    So early 4.0s at this point are known to have issue with the head gaskets (more so 4runners) and 80% of the time they start as a cold start misfire on cylinder 6.
    best course of action is a leak down test. If it’s found the engine is bad, at 300k + miles a low mileage used engine is likely your best bet. A 2010,2011 motor would be the best bet. Head gasket issues are rarer on the later 4.0s. 12+ might work, but the secondary air injection system means theres some holes on the head that would need to be plugged
    Key-Rei likes this.
  4. May 9, 2021 at 11:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like a solid plan to me. Good luck!
  5. May 10, 2021 at 12:35 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    If it ain't a head gasket which I'm leaning towards it is given your year, mileage, and the sloshing sound you referred (my suspicion on that is low coolant in the heater core system leading to air entrapment and gurgling) but if it's not a head gasket (and for your sake I hope it isn't) it could very well be a intermittently sticking, or leaking injector on cylinder 6 I had this happen to me on a first gen.
  6. May 10, 2021 at 4:46 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    If the sloshing sounds like it's pretty much in front of you, the way mine did, it's the head gasket.
    When my truck was cold, it stumbled for a few seconds then smoothed out when started.
    Nice job on getting 300k on it before it popped. Mine lasted 238k with regular maintenance.
    Good luck.
  7. May 10, 2021 at 6:08 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Nicely done OP to get to 300k miles.. Impressive for any yr/any vehicle before this likely HG failure. Slap a used lower mileage motor in there and drive on.:burnrubber:
    Geeves77 likes this.
  8. May 20, 2021 at 7:32 PM
    Athenstacoma06
    2006 Tacoma 4.0
    Found out today that the head gasket is the issue. Besides replacing the water pump at 100,000 miles, I have had no other major mechanical issues with the truck. 306,000 miles.
    I’m considering putting in a JDM engine or a Jasper remanufactured.
    Either option is very expensive, but the truck is too nice not to fix. My son will be 16 in a few months and I plan on giving it to him.
    Anyone have any experience with Jasper or JDM engines?
  9. May 21, 2021 at 10:10 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Why not fix the head gasket instead? Unless you physically can’t do your own maintenance these trucks are extremely easy to maintain.
    blu92in99 likes this.
  10. May 21, 2021 at 10:42 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Agree, next best is a used taco engine from a salvage yard.
  11. May 21, 2021 at 5:17 PM
    Athenstacoma06
    2006 Tacoma 4.0
    I considered it. Just figured with 306,000 miles it might be better to put that money towards a low mileage or reman engine.
  12. May 23, 2021 at 10:46 AM
    ARB1977
    North Texas
    Or do a compression test. Why waste money if you don’t have too. A head gasket maybe all this engine needs.
  13. Aug 10, 2021 at 4:45 PM
    Athenstacoma06
    2006 Tacoma 4.0
    Update on the 2006 Tacoma. Plan on keeping it for years so decided to put a remanufactured Jasper engine in. My son turns 16 next year so this will be his first vehicle. Ordered a new Tacoma last week.
    Price of used trucks are through the roof so it was worth it to get it going again.
    Engine has a 100,000 mile warranty and 36,000 labor warranty. Of course, lots of fine print.
    Engine is in and runs like new.
  14. Aug 11, 2021 at 12:20 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    300K miles on any vehicle is a pretty good run. It's worth keeping it on the road.
    Good luck with the new engine.
  15. Aug 11, 2021 at 12:29 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    at that mileage doing a fix
    is just waiting on something else to go wrong
    if U r planning on keeping the truck
    look at the long game
    goin in now................+ goin in later is going to cost more
  16. Aug 11, 2021 at 12:39 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I tend not to hear good things about jasper engines or engines that have had the blown head gasket repaired. Junkyard engine from a newer truck is the best option
  17. Aug 11, 2021 at 12:42 PM
    Oreo Cat
    12+ engines can work. With 12-15 header gaskets, 05-11 studs, and URD spec U headers with O2 simulators it worked just fine
    The spec u headers block the holes on the block perfectly only problem is it won’t pass CARB smog
    Empty_Lord[QUOTED] likes this.
  18. Aug 11, 2021 at 12:47 PM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    My son inherited an 08 taco with 401 on the clock. Now has 409,000 since he’s got his license… also Iv done head gaskets on many of these engines with over 200k on them and they still come in for service … if the frame holds out the engine will most likely keep going …. But glad to see it’s still in the family :fistbump:
