6"db wanting to go bigger!
Discussion in 'Suspension' started by tacomaboyd, Feb 24, 2015.
  1. Feb 24, 2015 at 5:17 PM
    tacomaboyd
    tacomaboyd [OP] Member
    Brandon
    Northern alberta
    14 taco 6"fabtech
    6" fabtech, 17 x8.5 Fuel trophy rims, 35x 12.5 nitto trail grapplers, magnaflow catback
    Hey guys I'm looking for some knowledgeable advice on what to do to go bigger with my truck. I have a 6" fabtech db kit with 35s but I'm looking for some more ground clearance from the drop brackets. I'm curious about getting custom length coilovers to make up for the 6inch spacers and add a bit more and I'm also curious about combining maybe a long travel kit with the drop bracket kit. Any thoughts on this? Please no negative comments as I've already heard them. Just looking for advice on what I can do to add to what I already have
  2. Feb 24, 2015 at 5:20 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
  3. Feb 24, 2015 at 11:40 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    How's 12" sound?
    http://bulletproofsuspension.net/2005-2015-toyota-tacoma-2wd4wd-12/
    You could go custom length coil overs, ditch the spacer and get a couple more inches out of it to put you at like 7-8" of lift.
    Absolutely do NOT mix a LT and a DB kit...that's just dumb. You don't get 'lift' out of a LT kit, the arms are extended to allow for more travel hence the name long travel. For the price you could get the bulletproof MEGA bro DB and sell your fabtech.
    Not sure if uniball LCA would play nice with the Fabtech LBJ mounting point anyways. I know guys have done it with Pro Comp set ups (stock width arms) but they utilize the stock LBJ bracket.
  4. Feb 24, 2015 at 11:51 PM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    He said everything I was going to say its a lot of money for the price you can get a nice DB your lift will not be that great offroad though if you go long travel your not gunna have as much of a lift but it will ride better then any lift kit...
  5. Feb 25, 2015 at 3:20 AM
    tacomaboyd
    Brandon
    Northern alberta
    14 taco 6"fabtech
    Ya I figured the long travel was a bit of a dumb idea. A 12 inch drop bracket is too much for me but id say longer coilovers I'd definitely the answer in my case
  6. Feb 25, 2015 at 7:46 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Out of curiosity, why do you need/want that much lift?
  7. Feb 25, 2015 at 7:55 AM
    Mr Ribby
    Mr Ribby Well-Known Member
    Andrew
    NW Indiana
    2013 "Baja"
    Pioneer DvD double din, pioneer 5way front door speakers, kicker 3 way rear door speaker
    There is a guy local to me that rides around on roughly what looks like 8-10in on 37s. I didn't take close enough look to see if they body lifted it, but from the quick glance he didn't have an obnoxious gap between the frame and body so my guess is no. He had coil overs up front that looked very similar to the fox ones offered. If I see him around town ill see if I can stop him and ask him about it for you. All I got a say is he mine as well just forget using the bed cause he would need a step stool just to be able to jump partially the way up. Its defiantly unique to say the least.
  8. Feb 25, 2015 at 8:05 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    :lalala:
  9. Feb 25, 2015 at 9:30 AM
    tacomaboyd
    Brandon
    Northern alberta
    14 taco 6"fabtech
    I just wanted to go a little bit bigger aiming to get more ground clearance from the drop brackets. I did gain some from stock but that's mainly from the bigger tires
  10. Feb 25, 2015 at 9:37 AM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    So put bigger tires on.
  11. Feb 25, 2015 at 9:44 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Yeah with a 6" lift you can probably squeeze some 37s on there with all the standard trimming.
  12. Feb 25, 2015 at 9:52 AM
    Large
    Large Red
    You don't get ground clearance with lift. You get minimal front ground clearance with preload but you could lift the rear 10', the bottom of your axle pumpkin will still be the same distance from the ground though.
  13. Feb 27, 2015 at 8:03 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    with a 6" lift you could fit 40's easily. I got 36s on a 3" lift.
