6" fabtech or rough country?
Discussion in '4 Cylinder' started by 16webbm, Aug 23, 2017.
  1. Aug 23, 2017 at 6:44 PM
    16webbm
    16webbm [OP] Member
    Michael
    2012 silver 4banger prerunner
    3 inch rough country lift. 33x12.5x17
    Whats up guys I'm looking into lifting my truck more and want some opinions on which 6" lift I should get? fabtech or rough country? she's pretty much a pavement princess if that helps.
    BassAckwards likes this.
  2. Aug 24, 2017 at 8:15 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Since youre a prerunner maybe look into maxtracs spindles. They provide 4 inches of lift and when you pair them with springs and shocks up front, you can gain even more lift while still keeping the stock UCAs. So for example if you went with maxtrax and eibach/toytec 620 coils, you would yield about 5.5 inches of lift. If it was me, id go this route for the front vs a drop bracket lift. Prerunners can use lift spindles, while the 4wd guys have to go drop bracket lift for over 3 inches to maintain proper CV axle angles
