6" Fabtech with Bilstein 5100's??
Discussion in 'Suspension' started by Chasetyler19, Nov 13, 2010.
  1. Mar 4, 2012 at 4:17 PM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    you can run 5100's in the front, im planning on doing so. with that said, with the huge spacer up front, i wouldnt suggest adjusting the 5100's to anything other than 0. as for the back, i have the upgraded springs from fabtech on mine, so no comment there ;)
  2. Mar 6, 2012 at 6:10 PM
    rrh_2
    rrh_2 Well-Known Member
    Richard
    Devine texas
    05 tacoma 4x4 sr5 dc
    6" pro comp stage one lift ome 885's, 5100's,bhlm, billet grille, lights behind grille, k&n cai , tinted Led tails, tinted 3rd brake light, Lotek a pillar, color matched grille mirrors and door handles, trd seat covers, blacked out windows, color matched engine cover, in-dash flip out screen 2 10'' kicker subs
    Subbed
  3. Mar 7, 2012 at 3:27 AM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    i was told that adjusting the 5100s would create a pretty steep angle for the cv's. i wouldn't mind seeing some pictures at the different settings on a 6" fabtech or procomp with the 5100s. as far as the 5" block, it can be done..a few of my friends are running the bigger blocks to get the most out of their factory springs....and they are running the adjustable coilovers on the front.
  4. Mar 12, 2012 at 11:05 PM
    808Renato
    808Renato Well-Known Member
    Renato Medeiros
    Kauai
    16 MGM DC 4x4 6spd Manual
  5. Apr 6, 2012 at 6:41 PM
    rrh_2
    Richard
    Devine texas
    Just picked up a set of 5100's and some ome 885's
  6. Apr 6, 2012 at 6:59 PM
    COMAtose HI
    2012 TRD SPORT 4x4
    Nice!!! Your stoked!!!
  7. Apr 6, 2012 at 7:46 PM
    rrh_2
    Richard
    Devine texas
    Yea and a lil nervous I hope I don't tear anything up I was waiting around to see if anyone else was going to try it but I got impatient
  8. Apr 6, 2012 at 8:07 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    Ok listen. Check out ny build i did what you all are wanting to do. I took a different route though. I have the pro comp 6 inch with the spacer up front. Have the 5100's2 set on 0. Bought ome( old man emu) coils springs. These springs are 2 inches longer than the stock coils. This is how you get 8hurt true inches out of these lifts. For the rear you will need to get bigger blocks or get a leaf pack made. Me i got 8off inch leaf packs made from alcan springs. They are not cheap but in the long run you will tank me. Blocks that big are horrible. You will have massive axle wrap and alot of vibrations. If you have any questions you can either meassage me or check out my build everything i have sone is on
    there.
  9. Apr 6, 2012 at 8:10 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Also with these lifts it brings the diff down so that at six inches its just like stock axle angles. When you go putting 2-3 more inches of lift your angles will be just like running a 3leaf inch lift.
  10. Apr 6, 2012 at 8:13 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    And actually you dont need 5125's i have 5100's. You can get extended travel. Mine are 322 inches long and have 13 inches of travel
  11. Apr 6, 2012 at 8:43 PM
    rrh_2
    Richard
    Devine texas
    Man ur truck turned out nice!!! I wish I could afford a new leaf pack... For the time being I am going to try this: before my 6 I had a pro comp 3" when my 6 was installed the place I had it done left my old aal on my truck but since everything looked fine I just left it so I have the aal from my 6" kit since they are longer I was just going to put them on... Do u think it would work ok?
  12. Apr 6, 2012 at 8:53 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    That im not sure of just bcz i would think both leafs are the same size and arch thus not producing any nore lift just more of a load the truck could handle
  13. Apr 6, 2012 at 8:55 PM
    rrh_2
    Richard
    Devine texas
    The ones in the 6" kit were way longer but yea I also don't know If it will provide any more lift
  14. Apr 8, 2012 at 3:49 PM
    rrh_2
    Richard
    Devine texas
    Do u recommend setting the 5100's at anything other than 0
  15. Apr 8, 2012 at 5:26 PM
    #35
    Frostbyte
    Northern Utah
    Look at it this way, with most of the 6" lifts, your main source of the lift is the huge spacer that the kit comes with. Could you put the 5100's at something other than 0 to achieve more lift? Yeah you could, but would you want to with the huge spacer and added load on the shock from adjusting it? I wouldn't... Sounds like disaster waiting to happen while in the middle of nowhere, out of cell service while your exploring that mountain trail you found.....
  16. Apr 8, 2012 at 9:19 PM
    #36
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Thats the way i feel. Better off to spend 180 bucks more and get ome 885 coils
  17. Apr 8, 2012 at 9:25 PM
    #37
    Frostbyte
    Northern Utah
    if you have the money, and want that much more lift, thats what i would do. I want to upgrade the front springs without more lift, but i think im just going to save a bit and buy some coilovers and be set for life....
  18. Apr 8, 2012 at 9:31 PM
    #38
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
  19. Apr 9, 2012 at 12:23 AM
    #39
    COMAtose HI
    2012 TRD SPORT 4x4
    i want 5100s and new aftermarket coils, but no additional lift to the front. any suggestions?
  20. Apr 9, 2012 at 4:15 PM
    #40
    rrh_2
    Richard
    Devine texas
    I'm doing the 885's and 5100 set at 0.. But it'll give a lil more lift I just got all of the parts I'll need so hopefully this weekend I can do it
