6 hours labor to replace oil pan gasket????
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdracing5, Feb 21, 2011.
  1. May 18, 2015 at 10:48 AM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I think if you use a union-joint type of socket adapter (like this), like I did once on a friend's VW, you can reach all the bolts without taking the front diff off. correct me if wrong.
  2. May 18, 2015 at 10:55 AM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    You probably could but the diff still has to come out to change the oil pan gasket.
    To the OP 6 hrs sounds about right, maybe an hr high but if your not happy with it look somewhere else or do it yourself. Could always take it to the dealer and have them look at it and quote it, they may not be as high.
    nickpasquale92 likes this.
  3. May 18, 2015 at 11:02 AM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    yeah i am sure you are right, but good luck scraping off all the old gasket properly so it doesnt leak again, and good luck putting on new gasket maker properly without removing the fornt diff....
    Running Board Man and Hobbs like this.
  4. May 18, 2015 at 11:16 AM
    Redneck92
    Concord, NC
    Not sure if i was meant to be quoted on that or not :confused:
  5. May 18, 2015 at 3:15 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    If your not mechanically inclined to do it your self and if your tech gave you advice as to make sure the leak is where they think it's coming from then just pony up and pay the $$$ to get it done, provided they are your regular shop and you trust them, there's no reason you should doubt them, shit takes time to do, it's not just the time but the tools/lift/shop/experience that it takes to do the job, your always gonna have someone that says "I could do that in half the time" or "you should do that yourself to save money" truth is some people's time is worth more than the money to lay in your driveway for a weekend trying to save a few bucks, it sounds to me like they're a reputable shop and 6hrs seems fair if you gotta drop the front diff, just get it done if need be and get on with your life
    GQ7227, Hobbs and Redneck92 like this.
  6. May 18, 2015 at 5:49 PM
    trx125
    trx125 Well-Known Member
    Drop the diff, trust me. Raise vehicle and support on jack stands. Remove wheels, unbolt lower ball joints and pop the cv's loose from the diff and support them out of the way. Unbolt the drive shaft and place floor jack under the diff and remove the support bolts. Then you have clear and easy access to the pan. You will need it to keep from screwing up the sealant applied to the pan trying to force it in around the diff and stuff. This can lead to a leak worse than you have now. If you have access to air tools the job goes quicker. It's not a hard job just time consuming and an extra pair of hands is always helpful.
    MicComa and cruxofthebisquit like this.
  7. May 18, 2015 at 6:35 PM
    high n mighty
    Oshawa Ontario
    01 camo taco
    See...
    Easy right?
    Running Board Man likes this.
  8. May 18, 2015 at 7:21 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    He sure does make it seem easy.
  9. May 18, 2015 at 8:45 PM
    trx125
    I'm going to install a new locking front diff, repair the oil pan gasket, install new front passenger wheel bearing this weekend. I'll try and remember to take some pics.
  10. May 19, 2015 at 5:30 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Mine is leaking on my 2.7l. I had swapped to full synthetic when the leak developed. I went back to Dino and its slowed over a few oil changes. I bought a parts house cork gasket because I didn't want to drop the front diff. I figured I could snake it around the oil sump and put it in place. But I never have gotten around to it. And may not since the gasket looks like poo sitting on my garage shelf. I don't think it'd last as long as doing it proper with sealant vs. saving some time and money.
  11. May 19, 2015 at 1:46 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What makes it exciting is is clearing the pick up tube .
    Ok I could see about 6 hours coming out of a Flat rate book.
    Don`t trust a mechanic So I should not Trust myself this could get complicated
  12. May 25, 2015 at 6:26 PM
    trx125
    No way you'll get the pan off or out with the diff in. With the diff removed, you unbolt the pan and tap it with a rubber mallet it will come loose. When it drops down, the back of the pan has to be turned to the passenger side to allow the front to have enough room to drop out. It will not just drop straight down. Clean off all the old gasket maker from the pan and block, clean both good with brake parts cleaner(or acetone). Reapply new sealant, install it reverse order and torque bolts to spec.
    slander and Chipskip like this.
  13. Sep 28, 2017 at 6:10 PM
    lawtondevil
    lawtondevil New Member
    michael
    chevy
    2004 silverardo
    25 years working on cars' if the book says 6 hours it says that for a reason. dropping oil pans are no fun cant stand doing them. it is not cheep i do have to agree with that.
    but you looking at a lot of work unless you can cheat somehow witch i try to find any way i can to do so lol.
    but any garage is going to go by the book
    But the shop is going buy the book no matter how long it takes.
    i know for a 45 dollar gasket sucks. not cheep!!! with out a lift o my god!!!!
    best of luck with your repair....
  14. Sep 28, 2017 at 6:12 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    did you make that account just to reply to a 6 year old post?
  15. Sep 28, 2017 at 6:13 PM
    #35
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I think it could be done quicker, but it is a labor intensive task. You have to drop the entire front differential to access the oil pan
  16. Sep 28, 2017 at 6:16 PM
    #36
    lawtondevil
    michael
    chevy
    2004 silverardo
    No i did not. people are always reading these post. never hurts to put something up from someone that knows first hand what it takes.
    been there done that.
  17. Sep 28, 2017 at 6:17 PM
    #37
    smmarine
    Melbourne FL
    Wow. Didn’t even Realize lol
  18. Sep 28, 2017 at 6:23 PM
    #38
    lawtondevil
    michael
    chevy
    2004 silverardo
    okay Lol!!! I didn't realize wow wow wow i could rebuild your truck in my sleep< i will on post if this is whats its about
    i do not want to waste time, more than willing to try to help anyone tho.
    El Duderino likes this.
  19. Sep 28, 2017 at 6:49 PM
    #39
    smmarine
    Melbourne FL
    I didn’t mean you. I meant I didn’t look at the date of the OP when I commented. I didn’t realize I was responded to an old thread
  20. Sep 29, 2017 at 10:11 PM
    #40
    Dadypig
    Dadypig Aka daddy pig
    Jaime
    East bay Kali
    2001 silver extended cab sr5
    Stock for now
