6 hours labor to replace oil pan gasket????
Discussion in '1st Gen. Tacomas (1995-2004)' started by trdracing5, Feb 21, 2011.
  1. Jul 26, 2020 at 8:39 AM
    #81
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I can get behind this statement!
    george3 for president! :D
  2. Sep 14, 2020 at 12:56 PM
    #82
    gearley
    gearley Member
    Garrett
    2002 Black Tacoma SR5
    basket and a tire on top with lower pods
    So what stopped the leak? Did you have too much pressure?
  3. Sep 14, 2020 at 1:26 PM
    #83
    Indy
    Indy Master of all I survey.
    I skipped most of the thread. But there's a difference between being able to sneak part a past part b, and being able to put it back together and be leak free when you're done. When i was younger id try it. Sometimes it worked, others it didn't. Taking 3 attempts is a bad businesses decision. The only thing more expensive than doing something right is doing it right the 2nd time.
  4. Sep 14, 2020 at 2:23 PM
    #84
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Absolutely.
  5. Oct 16, 2020 at 8:10 PM
    #85
    Laisseraller
    Laisseraller Active Member
    2004 Toyota tacoma Prerunner
    I had my oil pan gasket give out the other day! The cork one do not last that long I had several coil pack short out caused backfiring the blow back blew out the pan gasket. finally found a good gasket online not cork and replace it no leaking!
  6. Oct 17, 2020 at 2:56 AM
    #86
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I can agree about most Engineers .
    Thing to remember is it is all about getting the truck built on the line in the quickest way possible.
    I doubt any thought is given to service down the road. Just talk to most any dealer techs
    It has been many many years since I did any work in a Vehicle assemble plant back then it was impressive .
    Then that was old tech after some thinking it was cheaper to just scrap the whole plant and build another then do a upgrade and refit
  7. Feb 15, 2021 at 7:04 AM
    #87
    03TacoCanuck
    03TacoCanuck New Member
    Rene
    2003 Toyota Tacoma Ext. Cab 2.7L 4x4
    None
    I have a 2003 Taco 4x4 and my oil pan is leaking but when I cleaned everything and made sure there was no oil anywhere I left it sit over night and found the oil coming from the lower section of the oil pan where it is welded to the upper is where the leak is coming from. You can't remove the oil pan without clearing the support beam its getting in the way.
    Had to drain oil, clean and then use JB Weld on the seam and then coat the pan repair with rubber undercoat.
  8. Feb 15, 2021 at 1:51 PM
    #88
    Taco1UU
    Taco1UU Member
    Two Tacos: 1996 and 2002
    No mods yet on the '96...just trying to get her reliable again. Work completed: * Cleaned behind dash and replaced all dash bulbs. (There was only one working.) * Reconditioned front bumper. Replaced rear bumper. * Thoroughly corrosion-controlled underside, including spare tire hardware. * Replaced valve cover and engine oil pan gaskets. * Replaced clutch. * Replaced all driveline fluids. * Engine tuneup. * Reconditioned gas tank skid plate. * Reconditioned engine skid plates. * Replaced parking brake hardware. * Replaced all front suspension components except lower control arms. * Replaced front brakes. * Replaced CV joints. * New main driveshaft No mods on the 2002...she's all stock.
    I replaced the engine pan gasket on my 1996 Taco (then 265K) 2.7L 4x4 and it took me every bit of six hours. But I was working in my driveway, it was my first Taco oil pan job, first front diff removal, and I don't do this for a living. Unless you want to remove the engine, the front diff has to come out. Plus, I replaced the front axle seals while I was at it. Just making certain the engine mating surface was sufficiently clean took the better part of an hour. Of course, the pan had lots of gunk inside, so it needed to be cleaned too; bye-bye to the better part of another hour there.
