6 inch crack on roof
Discussion in '2nd Gen. Tacomas (2005-2015)' started by annajo50, Apr 20, 2013.
  1. Apr 20, 2013 at 2:15 PM
    annajo50
    annajo50 [OP] New Member
    2007 Toyota Tacoma Double Access cab 4x4
    I washed my 2007 Tacoma access cab 4x4 today, and when I went to wipe down the roof, I noticed a 6 inch crack. It is cracked all the way thru the material. I have never seen anything like this before. There are a couple of other cracks appearing but have not split through the material.
    Has anyone ever had this problem? Is this fixable? Any idea what would cause this to happen? I am not a happy camper right at the moment.
    Any insight would be appreciated.:mad:
    No it is not metal. It is more like fiberglass. [​IMG] [​IMG]
  2. Apr 20, 2013 at 2:19 PM
    WTFaulkner
    WTFaulkner Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    :eek:Ive never personaly seen this thats not chill what so ever
  3. Apr 20, 2013 at 2:20 PM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Pics Please?
  4. Apr 20, 2013 at 2:29 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    6" crack through the sheet steel in the roof?
  5. Apr 20, 2013 at 2:31 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    subbed for pics
  6. Apr 20, 2013 at 2:33 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Cracked paint or metal? Why do you say material? So vague......
  7. Apr 20, 2013 at 3:14 PM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    they need to kick it to old skool and not come up with different materials for body work "/ there just making cheaper to make things and selling it at the same price, and calling it high quality
  8. Apr 20, 2013 at 3:20 PM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    looks like filler must have had previous damage
  9. Apr 20, 2013 at 3:21 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Yea, looks like someone bondo'd a roof dent, and it has cracked.
  10. Apr 20, 2013 at 3:23 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Definitely an after market repair, your roof is supposed to be metal. As others have asked, is just the paint cracking? Has it had Bondi repair on the roof?
  11. Apr 20, 2013 at 3:30 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Ya that material should be very ductile.
  12. Apr 20, 2013 at 3:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They aren't.
    I don't know where the "fiberglass" on her roof came from, but it did not come from the Toyota factory.
    Magnetic antennae stick to that roof just fine. The only composites in the 2nd Gen Tacoma bodywork is the bed liner.
  13. Apr 20, 2013 at 3:46 PM
    joes06tacoma
    Joe
    Central Coast, CA
    As others have said, the factory roof is steel. Sounds like someone used some body filler to repair a dent and something went wrong.
    Fixable? Of course, by a professional body shop. If the dent was popped out enough, only a thin coat of filler would be needed, and if done properly, that should be okay. Of course, I'm not a body guy, but I have put a thin coat of filler over a mostly popped out dent before, painted it, and had no problems. The best way would be to replace the roof panel, which would be a lot of time ($), but shouldn't be too complicated for a professional shop to do.
    Good luck. That's a real buzz killer right there.
  14. Apr 20, 2013 at 4:01 PM
    TROKITA
    Arty
    Utah, the valley
  15. Apr 20, 2013 at 4:02 PM
    annajo50
    Interesting! I bought this truck about 9 months ago. I did see the carfax and it showed an accident shortly after it was purchased new, but that is the only accident reported, and also, the title is clean. I will take it to a
    body shop to see what they can do to repair it. Thanks for all of your input, I would not have thought it was an aftermarket repair. Makes sense.
    There are other little cracks showing also, it will be interesting to see what the body shop says. Let the buyer beware, I guess.
  16. Apr 20, 2013 at 4:07 PM
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    Looks like auto body bondo to me.
  17. Apr 20, 2013 at 4:47 PM
    KenLyns
    Belly of the Beast
    For a roof to be damaged in a collision (and show up on Carfax), it would usually have to be a rollover. More likely the damage was caused by falling objects (or hail) or low overhead clearance (e.g. sprinkler in low parking garage).
  18. Apr 20, 2013 at 5:02 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Maybe it's the camera angle, but I don't see the same four "ribs" running front to back, stamped into the sheetmetal, that I have on my truck. Was the second pic taken standing in the bed? Or was it taken from the side? Starting to wonder now if someone tried to cover the whole roof with some other type of material.
  19. Apr 20, 2013 at 5:03 PM
    KenLyns
    Belly of the Beast
    Thick vinyl wrap that reached end-of-life?
  20. Apr 20, 2013 at 5:12 PM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    Definitely a repair that is failing!
    Have the shop you take it to inspect the rest of the truck for repaired areas as well.
    Not all states required a title be branded salvage back in 2007 when a vehicle was totaled.
