6 inch down to 4 inch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Activeairstrip, Nov 22, 2024.
  1. Nov 22, 2024 at 6:33 PM
    Activeairstrip
    Activeairstrip [OP] Member
    2014 tacoma
    Hello guys new here! I had a question … i have a 6 inch rough country lift front has adjustable coil overs 4-6 . The rear just has the lift block and the leaf spring along with the shocks that came with the lift originally . I want to bring it down to 4 inches front and back . I called a local shop and they said i need a 3 inch block for the rear to achieve 4 inches in the rear . Do i need to order for inch rear blocks or can i just use the 3 inch rear blocks i orderd ?thank you for the replys !
  2. Nov 22, 2024 at 6:45 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Peter603Taco and stealthmode like this.
  3. Nov 22, 2024 at 8:10 PM
    TacoTuesday1
    FL
    Don’t know what you’re talking about.
    rough country is bad. Blocks are bad.
    the 2nd gen Tacoma complies with 2-3” max lift. beyond that causes issues like CV problems, removal of downtravel, etc.
    I have around 2” lift and clear 35’s. I’m guessing you’re not on 35’s.
    tcBob, cshrum and T4R_hereforbearings like this.
  4. Nov 23, 2024 at 12:50 AM
    Activeairstrip
    2014 tacoma
    I have 6 inch coilover RC . They have that option if you want
  5. Nov 23, 2024 at 12:52 AM
    Activeairstrip
    2014 tacoma
    Ive had 20x14 on 33’s , 16.5x12 on 33’s ….rn 17x9 on 31’s
  6. Nov 23, 2024 at 2:29 AM
    Mack83
    Mack83 Well-Known Member
    Orlando
    2014 TRD OR DCSB Silver Streak Mica
    Hey! I’ve worked with Rough Country lifts before, and for a 4-inch drop in the rear, a 3-inch block might give you a little more than you want. Usually, you'd go for a 2-inch block to hit that 4-inch mark. That said, you can definitely try the 3-inch block you already ordered, but just be prepared that it might end up sitting a bit higher than you’re expecting. It’s worth checking with the shop to see if they can adjust it for you if needed, especially for the best ride quality.
    tcBob likes this.
  7. Nov 23, 2024 at 2:49 AM
    Activeairstrip
    2014 tacoma
    Hey bro thank you ! I really appreciate the feedback thats what i didnt want lol . Now i can put a 2 inch block with assurance . Thank you very much!
    tcBob likes this.
  8. Nov 23, 2024 at 8:53 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If you put a 2” block in the rear and change to front to 4” you will be nose high in the front. Also need to confirm that the rear isn’t a combo of block and aal.
  9. Nov 24, 2024 at 7:57 AM
    DaytonaTaco
    DaytonaTaco Well-Known Member
    2015 Tacoma Sport 4x4 access cab 6spd w/ tow package
    Just curious, why?
  10. Nov 24, 2024 at 9:48 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    Rough Country is one DB lift that does seem to sit better at 4" - 5" lift than 6" (better front CV angles, etc.)
    If it were me, I'd be looking at lifted leaf springs so as to put the shortest block necessary in there (like 2.5" lift leafs + 1.5" blocks, since there are no actual 4" lift leafs available I'm aware of). Big tall blocks = bad.
  11. Nov 25, 2024 at 9:54 AM
    Activeairstrip
    2014 tacoma
    Wait so im getting a bunch of different responses i want it to sit evenly at 4 what block do i need because i have a 3 and a 2 inch block now here at home? Ps the truck at six inches did sit like half and inch higher in the front that why i want it to be even front and back…if a two in block is the closest i can work with that i just want to get back down lol
  12. Nov 25, 2024 at 11:57 AM
    4x4junkie
    So Calif. (SFV)
    Seems to me this should be real easy; blocks that are 2" shorter than the ones you have now will lower it 2".
    1. Are your rear leaf springs stock?
    2. Is there an add-a-leaf in them?
    If you can answer 'Yes' to #1 and 'No' to #2, then whatever height your block is will equal how much lift you will have.
    Or *maybe* we can guess your lift if you can tell us exactly what it is you do have.
    Short of that, you're kindof on your own, and is just another reason to start over with something new (again, big blocks suck, they cause the rearend of your truck to kick sideways going over bumps, among many other issues).
  13. Nov 25, 2024 at 12:03 PM
    cshrum
    cshrum Well-Known Member
    CO Springs, CO
    17 blue TRD sport DCLB
    You were ignored, and that is sad. But, not your truck...nor is it mine. But who listens to logic any more, right?
  14. Nov 25, 2024 at 11:47 PM
    Activeairstrip
    2014 tacoma
    okay so i measured my leaf spring about 2 inches and i measured the block at 4 inches ….. if put the two inch block i should be sitting at 4 . I think ive figured it out thanka to all of you . Thank you very much for your guys’s advice and imput . Aloha
  15. Nov 26, 2024 at 10:00 AM
    hinmo24t
    hinmo24t MAhole
    tom
    dartmouth, ma
    2015 TRD OR , blue ribbon metallic
    6 inch down to 4inch
    story of my girls love life w me
  16. Nov 26, 2024 at 10:25 AM
    Activeairstrip
    2014 tacoma
