6 inch fabtech lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Alohadon, Feb 21, 2018.
  1. Feb 21, 2018 at 9:41 AM
    Fitzpatrick78
    Fitzpatrick78 Well-Known Member
    Robert
    2016 trd sport 4x4 3" lift
    3" front 2" rear leveling kit 285/70/17 on fuel assault
    I had the fabtec 6” on a 2005 tacoma as soon as I put it on I’d wished I hadn’t. Looked good rode really nice compared to factory but boy did it screw up the mpg and the rpms. But hey to each their own. I would never go above a 4” ever again and 3” is plenty.
    Coot83 and ChadsPride like this.
  2. Feb 21, 2018 at 9:50 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I had this on my 2004 first gen and I regretted it similarly as well. That was also just before I got into wheeling though so it had a great maller life.
    I decided to big for my second gen...long travel.
    ChadsPride likes this.
  3. Feb 21, 2018 at 9:54 AM
    Alohadon
    Alohadon [OP] New Member
    D
    2017 Toyota Tacoma trd off road 6sp manual
    Thanks for all the feedback.
  4. Feb 21, 2018 at 10:42 AM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    Remember though...RPM affect has zero to do with lift height, and everything to do with tire size.
    Lift height will affect the MPG, but not nearly as much as tire size, tire weight, and rolling resistance.
    Just wanted to make sure we properly correlate the changes to the truck to the symptoms seen.
    JiuJitsu, KTJO 4x4 and ChadsPride like this.
  5. Feb 21, 2018 at 10:44 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Remember the taller your truck, the bigger profile it makes for the wind. That being said, your stability and ABS can be affected the higher your truck is especially when hitting on and off ramps.
  6. Feb 21, 2018 at 10:47 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Quality answer that doesn't insult OP and offers an alternative? Where am I? :goingcrazy:
  7. Feb 21, 2018 at 11:51 AM
    Weirich
    Weirich Drunk_taco
    Travis
    2016 Tacoma access cab TRD Offroad
    OvTuned 4.88 R&P Hypertech speedometer calibrator Rough country 6" lift Toyo open country 285/75R17(old) Cooper STT Pro 315/70r17 Archive garage shackle flip Tough country uni ball uppers Icon 2.5 6" front coil overs Icon 2.5 CDC 6" rear shocks OME cs047r rear leaf packs AllPro HD Sliders Tom woods double cardin single piece drive shaft Magnaflow exhaust Black rock D window rims(old) ICON 17x8.5 Rebound CBI T3 full guard front bumper Smittybilt x20 10k winch HEISS 20" single row light bar ARB on board air compressor
    I don't see why there's so many people on here that hate drop brackets. I've got a rough country 6" lift and I'm pretty sure I have more ground clearance than anyone with stock arms and just coil overs. Plus my truck is capable offroad and on the highway.20180221_112128.jpg this 6" kit only drops about 3.5" and my clearance under the front bracket is 16"20180221_112527.jpg measuring around the truck the middle clearance for the frame is 21"20180221_112431.jpg
    For those who think the chop is going to make the truck weak, depending on how you argue your point you're wrong. The way the chop works, it moves the mount for the front diff from the stock crewmember to the drop bracket.
    The front diff mounts on this lift are pretty badass too, they keep the diff as low as possible while supporting both brackets. So once everything is installed in the truck, it's all holding it's self together.20180221_112154.jpg 20180221_112208.jpg
    As far as the front suspension, I have a down travel bump stop and an extended up travel bump stop. So there's really no way of over compressing or extending the icon coil over. The reason there's a spacer under the down travel bump stop is to limit it even further.
    Rear setup with a 2" block and ome Dakar hd leafs.
    Tom woods double cardin single piece drive shaft.
    So If I had an option to go back, I wouldn't. I feel my truck is a lot more capable the way it sits now as opposed to just some coils.
  8. Feb 21, 2018 at 12:01 PM
    Pportera
    Pportera Well-Known Member
    3rd gen.
    Weirich right on
    KTJO 4x4, Weirich and ChadsPride like this.
  9. Feb 21, 2018 at 12:06 PM
    Dirty Harry
    Andrew
    SW Florida
    You're probably fine, but you're still relying on this drop bracket instead of the OEM frame.
    This makes people nervous. Bolts instead of welds.
    Weirich[QUOTED] likes this.
  10. Feb 21, 2018 at 12:14 PM
    Chris Miles
    Chris Miles Well-Known Member
    2016 Toyota Tacoma
    Trailer Hitch Cover - Star Wars Pulp Fiction Boba Fett & Stormtrooper
    I disagree with you; therefore, you're a jerk.
    Welcome to TacomaWorld
  11. Feb 21, 2018 at 12:32 PM
    Weirich
    Weirich Drunk_taco
    Travis
    Like I said depending on how you argue the point. This is as strong as the factory mount.
  12. Feb 21, 2018 at 12:35 PM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    If you’re afraid of bolts shearing, you should also be afraid of welds shearing. This forum is literally the first place I’ve even heard this argument.
  13. Feb 21, 2018 at 12:41 PM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    The bolts look to be grade 8s which is good to see. For me it doesn't have a nice finished look to it, cut out this little section of the cross member and then that's it. Could weld in some caps or either fully replace the cross member to try and make it a look at bit more factory. Also the ease of going back to stock isn't really there anymore. Yes you can weld that piece back in, but it won't be as strong so you'll have a bit more fab more reinforcing it a bit. So if you are trying to trade the truck back in and want to keep the aftermarket bits then it makes a bit more involved.
    But it does make it super easy to fit 35s without much fuss, I would splurge more to get the Fox coilovers so I don't have any strut spacers, but then at that cost might as well go Long Travel. Its a terrible rabbit hole to go down. But to me its the persons truck do whatever fits your style, what you are trying to accomplish, and budget. End of the day though just don't half ass something
  14. Feb 21, 2018 at 1:21 PM
    Dirty Harry
    Andrew
    SW Florida
    Yeah, I really think you justified your setup pretty well. I'm just trying to illustrate why most people would be fearful of a chop.
  15. Feb 21, 2018 at 1:49 PM
    #35
    Weirich
    Weirich Drunk_taco
    Travis
    I feel like it's just people under estimating the strength of steel in general haha if I'm breaking a bolt or the bracket I probably shouldn't be doing what I was with a truck like I have.
    KTJO 4x4 and scottsglock29 like this.
  16. Feb 21, 2018 at 1:51 PM
    #36
    Dirty Harry
    Andrew
    SW Florida
    I don't know what you mean...
  17. Feb 21, 2018 at 1:58 PM
    #37
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    Exactly. People need to understand the limits of their vehicles regardless if it is coil over lift, drop bracket lift, or spacer lift. I have run them all on a variety of vehicles and have enjoyed both the look and functionality of them all.
    One thing that I have always taken into consideration is that it is my money and my vehicle, and while I do respect others opinions and experiences; in the end it does boil down to individual needs, wants, expectations, and budget.
  18. Feb 21, 2018 at 2:01 PM
    #38
    scottsglock29
    Scott
    Wisconsin
  19. Feb 21, 2018 at 2:23 PM
    #39
    Weirich
    Weirich Drunk_taco
    Travis
    Shit will buff...
  20. Feb 21, 2018 at 4:57 PM
    #40
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Yeah but...you don’t actually feel like you require respect from anonymous people on an internet truck forum. Do you? From those same people that think a real lift is what they say it is?
