6 inch lift... 33's or 35's
Discussion in 'Suspension' started by caleb337, Jun 22, 2008.
  1. Jun 22, 2008 at 6:15 PM
    caleb337
    caleb337 [OP] Lifted Tacoma
    Carencro, Louisiana
    6 inch lift on a 05 SR5 TSS
    6 inch Procomp Lift, 35 inch Mud Terrains.
    I'm getting a 6 inch Procomp lift for my prerunner should I get 33 in. tires or 35's?
  2. Jun 22, 2008 at 6:37 PM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    i have been looking at the 6'' fabtech lift for my truck with the dirt logic shocks, i am looking at putting 35's on my truck when i get the lift. I have seen both 33's ad 35's on the lift and i think the 35's look better, look at some pics on the net or ask a 4 weel parts place if they have done the lift on any other trucks and see what they say....... but i would go 35's
  3. Jun 22, 2008 at 6:41 PM
    rick
    rick `
    35's
  4. Jun 23, 2008 at 3:21 PM
    ricepow
    ricepow Well-Known Member
    Vegas
    08 4x4 TRD Sport
    How about a 34, lol. Goodyear Wrangler MTR. 305/70-17......specs per Goodyears site, 34.1" x 12.2"......I was running these on my Titan that I just got rid of. Approximately 27K miles and they are still looking good. Probably going to pick up a new set of wheels and use them on my Tacoma with Pro Comp stage 2.
  5. Jun 23, 2008 at 6:46 PM
    caleb337
    Carencro, Louisiana
    But, I have heard that if you run 35's you will have to get new gears and everything will start falling apart faster than it usually would. Is this true?
  6. Jun 24, 2008 at 7:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    With 35's or 33's and stock gears - you're not gonna have the same power response as when it was stock.
    For example: With 33/s or 35's - You're cruising down the highway at 65mph and you approach a hill. As you climb that hill, you quickly lose speed and momentum. You step on the gas to speed up and the truck just won't 'catch up' like it normally would. That's because of stock gears and larger tires.
    When you re-gear, you get that power back....(hard to explain).
    As for the *falling apart* bit....that would all depend on the kit you're buying, the installation of that kit, any other modifications you should have to make it a better driving/riding/functioning truck, the maintenance you give it, the driving you do, the terrain you take it on....and that's only off the top of my head.
