6 inch lift question,
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UpstateTRDTaco, Mar 21, 2011.
  1. Mar 21, 2011 at 7:28 PM
    UpstateTRDTaco
    UpstateTRDTaco [OP] Well-Known Member
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    Hey guys, its time for me to buy a full on 6 inch lift.
    Right now i have a billie 5100 all around with eibach coils and a 1 inch block in the rear.
    The kit im looking at is this http://www.suspensionconnection.com/cgi-bin/suscon/56900-tacoma-lift-kit.html
    Is there anything i would need to purchase or can i use the existing bilsteins with this kit? I have 33s already too.
    Thanks in advance, Josh.
  2. Mar 21, 2011 at 7:29 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Looks like everything, get ready for some negative comments on that lift choice tho.
  3. Mar 21, 2011 at 7:30 PM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    i had same questions, everyone on here says don't do the tuff country, a lot have said its cheap, and everyone thats used it has had there alignment messed up. One guy on here had it, but removed it and installed procomp or fabtech, not sure which
  4. Mar 21, 2011 at 7:31 PM
    UpstateTRDTaco
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    Im sure people will think its negative, but i dont have the 2200 or whatever needed for pro comp or fabtech kits. even 1800 is a stretch. its what i can afford now with the money ive worked many long weekends for during school.
  5. Mar 21, 2011 at 7:32 PM
    UpstateTRDTaco
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    But it someone has a good reason why the extra 800 is really worth it, im more than happy to hear the reasons:D
  6. Mar 21, 2011 at 7:32 PM
    jerretxx
    Jerret
    North Carolina
    i know feeling man! im saving right now for procomp stage one. you can order it from 4wheelparts right now for $1300!!!! may want to check it out
  7. Mar 21, 2011 at 7:34 PM
    UpstateTRDTaco
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    Thanks jerretxx! damn thats a good deal
  8. Mar 21, 2011 at 7:36 PM
    jerretxx
    Jerret
    North Carolina
    yes sir! i have been doing this research forever, i was wondering why there is such a price difference. and i seen it was on sale, hopefully this helps you out!
  9. Mar 21, 2011 at 7:38 PM
    UpstateTRDTaco
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    Jerrett it does help alot.
    But, question for you, and you may have no idea. but whats the difference between the EXPK5073B and the EXPK5066B kits?? they seem to be identical but im nto sure. same price and everything, Any ideas?
  10. Mar 21, 2011 at 7:40 PM
    jerretxx
    Jerret
    North Carolina
    one of them is for VSC, if you read the fine stuff, EXP5073B requires at least 18 inch wheel, EXPK5066B requires at least 17 and it is for normal trucks
  11. Mar 21, 2011 at 7:44 PM
    UpstateTRDTaco
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    so i have to buy new rims and tires now?!:mad::(:confused:
  12. Mar 21, 2011 at 7:46 PM
    jerretxx
    Jerret
    North Carolina
    you can run wheel spacers possibly, but, more than likely you'll have to upgrade, besides the fact that my truck had 17" opt wheel package, i went with 17 bc i knew i was doing 6" in future.
  13. Mar 21, 2011 at 7:47 PM
    UpstateTRDTaco
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    but i have 16 inch pro comps with 285s on them already on my truck and those wont do?
  14. Mar 21, 2011 at 7:52 PM
    tacoma44x44
    tacoma44x44 Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    i am running 16" s with spacers on my 6" fabtech lift. Clears everything fine.
  15. Mar 21, 2011 at 7:53 PM
    jerretxx
    Jerret
    North Carolina
    sweet, looks like your in luck! hopefully procomp and fabtech arent much different
  16. Mar 21, 2011 at 7:55 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    I dunno if the pro comp will work though the spindle setup is a little different then the fabtech spindles.
  17. Mar 21, 2011 at 7:56 PM
    UpstateTRDTaco
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    tacoma44x44 do you have any pics?
  18. Mar 21, 2011 at 7:56 PM
    UpstateTRDTaco
    Josh
    upstate NY
    2011 Black Tx Pro
    mods to come
    whats the difficulty with 16 inch rims? do they rub on something other than plastics?
  19. Mar 21, 2011 at 7:59 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    No i dont have any pictures but all snap some tomm when the lights better and send them to you. But the problem with smaller rims is clearing the tie rod ends.
  20. Mar 21, 2011 at 8:04 PM
    jerretxx
    Jerret
    North Carolina
    yep, if you have enough Backspacing or wheel spacers you may be fine though
